![]() "Robert M. Gary" wrote in message oups.com... Steven P. McNicoll wrote: "Robert M. Gary" wrote in message oups.com... Since it was a practice approach (VFR I assume) it would be legal even if the loc was out of service. However, even as an acutal IFR approach it can still be given assuming you can identify the ADF on your GPS. Why would you need to identify the ADF? Well, in the case of the ILS SAC its because the course from the outer marker is one degree off the localizer. ![]() Why would you need to identify the ADF in this case? |
marker is one degree off the localizer. ![]() Why would you need to identify the ADF in this case? That's a good question. Steven, I actually thought you had said you were going to call the FAA on this one and question it. -Robert |
This was an "actual" approach. Much of my actual time comes from practicing
approaches on days like this one, and KAGC provides alot to offer close to home. The club planes I fly are all equipped with ADF's, but rarely is the station out of service. Because of radar, garmin 195,co-pilot and a ceiling well above ILS minimums, I felt comfortable flying this approach. Legal...no. Useful for quality practice...absolutely. "Robert M. Gary" wrote in message oups.com... Rick McPherson wrote: On Aug 28 I was practicing approaches at KAGC (FEW 008 BKN 012 OVR 025 4SM BR). My preflight brief indicated that the McKeesport NDB is out of service. Yet, the ATIS identified runway 28 as active and we were given the ILS 28 approach for practice (upon request). Is this approach legal without the beacon? http://download.aopa.org/ustprocs/20...ils_rwy_28.pdf As a side note, is the equipment that you fly still using ADF? Since it was a practice approach (VFR I assume) it would be legal even if the loc was out of service. However, even as an acutal IFR approach it can still be given assuming you can identify the ADF on your GPS. -Robert, CFII ----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
GPS can substitute for the ADF. Radar can substitute also.
So, if the acft has no ADF or the NDB is OTS, so, it could be. "Rick McPherson" wrote in message ... | On Aug 28 I was practicing approaches at KAGC (FEW 008 BKN 012 OVR 025 4SM | BR). My preflight brief indicated that the McKeesport NDB is out of service. | Yet, the ATIS identified runway 28 as active and we were given the ILS 28 | approach for practice (upon request). Is this approach legal without the | beacon? | http://download.aopa.org/ustprocs/20...ils_rwy_28.pdf | | As a side note, is the equipment that you fly still using ADF? | | Rick | | | | ----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==---- | http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups | ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
![]() Jim Macklin wrote: GPS can substitute for the ADF. Radar can substitute also. So, if the acft has no ADF or the NDB is OTS, so, it could be. Are you sure radar can be? When an ILS says "ADF Required" I believe you must either have ADF or GPS. Usually if radar is good enough it will say "ADF or Radar Required". -Robert |
Jim Macklin wrote:
GPS can substitute for the ADF. Radar can substitute also. So, if the acft has no ADF or the NDB is OTS, so, it could be. You cannot count on ATC identifying a fix on an IAP unless it is marked "radar." |
![]() "Sam Spade" wrote in message news ![]() You cannot count on ATC identifying a fix on an IAP unless it is marked "radar." That's not correct. Both ASR and ARSR may be used for identifying initial and intermediate approach fixes, only ASR may be used for identification of the final approach fix. There's no requirement that the fixes be marked "RADAR" on the IAP. |
"Sam Spade" wrote in message news ![]() You cannot count on ATC identifying a fix on an IAP unless it is marked "radar." That's not correct. Both ASR and ARSR may be used for identifying initial and intermediate approach fixes, only ASR may be used for identification of the final approach fix. There's no requirement that the fixes be marked "RADAR" on the IAP. Sure, they MAY be used but still need to meet some criteria in order to be ESTABLISHED as radar fixes. The TERPs specialist can't identify it as a radar fix on a procedure without the consent of ATC and verification by flight check. If the fix is marked "radar", that means flight check aircraft have verified the radar fix meets accuracy requirements and it's depicted properly on the scope. (Radar facilities do not have to depict or display all fixes on their scope.) It also means that the specialist has annotated the fix specifically as a radar fix on the 8260-2 forms that were submitted IAW FAR 97 requirements. So, as Sam says, you can't count on ATC identifying a fix on the IAP unless it's marked "radar". Reason? It may or may not be depicted on the scope (clutter) and they may or may not have agreed to be responsible for calling the fix passage. JPH |
![]() "JPH" wrote in message news:gE2Og.11816$Tl4.8274@dukeread06... Sure, they MAY be used but still need to meet some criteria in order to be ESTABLISHED as radar fixes. They do not need to be ESATALISHED as radar fixes in order for ATC to identify them. The TERPs specialist can't identify it as a radar fix on a procedure without the consent of ATC and verification by flight check. If the fix is marked "radar", that means flight check aircraft have verified the radar fix meets accuracy requirements and it's depicted properly on the scope. (Radar facilities do not have to depict or display all fixes on their scope.) It also means that the specialist has annotated the fix specifically as a radar fix on the 8260-2 forms that were submitted IAW FAR 97 requirements. So, as Sam says, you can't count on ATC identifying a fix on the IAP unless it's marked "radar". Reason? It may or may not be depicted on the scope (clutter) and they may or may not have agreed to be responsible for calling the fix passage. What Sam says if frequently wrong, as it is in this case. For example, take a look at the VOR or GPS-A approach at Blackhawk Airfield: http://map.aeroplanner.com/mapping/c...tab=approaches REINE is identified as a RADAR fix but this approach isn't depicted on ZAU ARTCC video maps at all. If the fix appears on the video map and it fits the criteria specified in FAAO 7110.65 the controller can call the fix, being identified as a RADAR fix on the IAP has nothing to do with it. |
![]() "Rick McPherson" wrote in message ... On Aug 28 I was practicing approaches at KAGC (FEW 008 BKN 012 OVR 025 4SM BR). My preflight brief indicated that the McKeesport NDB is out of service. Yet, the ATIS identified runway 28 as active and we were given the ILS 28 approach for practice (upon request). Is this approach legal without the beacon? http://download.aopa.org/ustprocs/20...ils_rwy_28.pdf Yes. As a side note, is the equipment that you fly still using ADF? Yes. |
General Aviation Legal Defense Fund | Dr. Guenther Eichhorn | Home Built | 3 | May 14th 04 11:55 AM |
General Aviation Legal Defense Fund | Dr. Guenther Eichhorn | Aerobatics | 0 | May 11th 04 10:43 PM |
General Aviation Legal Defense Fund | Dr. Guenther Eichhorn | Aviation Marketplace | 0 | May 11th 04 10:43 PM |
General Aviation Legal Defense Fund | Dr. Guenther Eichhorn | Owning | 0 | May 11th 04 10:43 PM |
General Aviation Legal Defense Fund | Dr. Guenther Eichhorn | Owning | 0 | May 11th 04 10:36 PM |
