Looking at the cover of the current Soaring, Eric M. is clearly
operating in violation of CFR 14 Section 45.25. If he's submitted any flights to OLC this year, does he have to remove them all? 8^) Marc |
![]() Marc Ramsey wrote: Looking at the cover of the current Soaring, Eric M. is clearly operating in violation of CFR 14 Section 45.25. If he's submitted any flights to OLC this year, does he have to remove them all? 8^) Marc Well, actually you bring up a very good point with this, whether you meant to or not. This is analgous to the problem we are dealing with in the OLC. By publishing this photo, on the cover of Soaring no less, it damages the group by reinforcing incorrect behavior. Not only does it show non-glider pilots that we don't do the right thing (even when it's just as easy to do it right), it also shows glider pilots the wrong thing to do, which they may try to emulate. Now as far as OLC goes, there is no sporting aspect to the N-number placement. Putting N-numbers on the gear doors does not provide any meaningful competitive advantage. And it does not show up in the flight log. So we would not be concerned with this in the OLC. But I would expect that if the pilot showed up at a contest with this, and someone noted the problem, a reasonable pilot would correct the problem immediately. I think it would be unreasonable to take the position that since nobody specificaly told them in advance that they must display proper N-numbers, that they don't have to fix it until next year. |
Ramy wrote:
Doug, the sunset rule may have been on the books, but not on olc rules until recently. Violating FARs is unsportsmanlike. An IGC file provides definitive proof of the time and 3D location of the sailplane. The OLC has always stated or implied that one must adhere to local flight regulations. Doing anything else is unsportsmanlike. You decided to enforce it retroactively, which is unfair to say the least. I guess this is one way to win a contest, when someone is catching up - remove their flights... The OLC software developers *could* create various validation schemes, but have instead chosen to provide a method for peers to submit a complaint. The SSA put out a statement regarding the FARs sometime last fall, in Dennis' column in "Soaring" if I recollect correctly. There have been several statements made through various channels in the last year about the need for peer review of flying habits. Now, finally, Doug has found the time to go over claims made this year to identify some of the more obvious ones. simple fact is that OLC was great until SSA took over. It is simply a shame the way it has been administered. You managed to upset your most loyal promoters and contestants. What is a shame, is that some participants make what they feel are "harmless" violations of regulations, then make a record of this behavior available online. It is a shame that one pilot will choose to open the spoilers and land before sunset while another continues to climb in that last evening thermal, watch the sun set, then glide another 50 miles - and then claim the distance in a sporting competition. -Tom |
5Z wrote:
Violating FARs is unsportsmanlike. An IGC file provides definitive proof of the time and 3D location of the sailplane. The OLC has always stated or implied that one must adhere to local flight regulations. Doing anything else is unsportsmanlike. So what about FAR Part 91 Sec. 91.119(c) which keeps get violated on the ridges? Just look at the top scores in olc, there are some definite proof there as well. |
"Doug Haluza" wrote in message
oups.com... As far as changing the rules, the sunset rule has been on the books for longer than almost anyone can remember. Doug, I think you know very well which rules I refer to -- and those are not FARs. OLC has been designed and introduced as an open forum for the pilots worldwide to share and compare flight traces online. Their rules specifically said that they did not intend to police submitted traces for airspace violations, etc. *That* is what has changed since SSA took over. If you insist on quoting the rules, their rules, in particular, say (in the most current version dated 7/13/2006 available at http://www2.onlinecontest.org/regeln/2006/regeln.php): "10. Validation. Flights and scores will be accepted if no objections have been filed against them within 4 weeks after the corresponding weekly deadline". Why have some scored flights much older than that been quietly disappearing lately? *That* is what has changed since SSA took over. Another example, from your own presentation: "SSA has exclusive rights to OLC in US -- SSA Membership is now required." Makes me go Hmmm.... *That* is what has changed since SSA took over. The SSA did not make this [FAR] rule, they just decided not to ignore it. Exactly, they *just* decided. Just like that. They *just* decided to go back and check some of the flights for some of the violations and pull them. If it is indeed true that "the [SSA] Board has directed [you] to look at Sunset and Class-A", then, again, one has to wonder what rules will be pulled out of the hat (or out of the FAR) tomorrow. I gave you some ideas yesterday -- anybody on the Board listens? The aspect of it that strikes me most is that SSA came uninvited and took over this great public resource, this open forum for pilots, and started telling everybody what can and what can't be posted there -- and by whom. Here is an idea for you: why doesn't SSA take over the US part of rec.aviation.soaring as well? You could make another presentation and tell us that "SSA has exclusive rights to r.a.s. in US -- SSA Membership is now required." While you are at it, why not put a big SSA banner with commercial ads right on top of every posting. And then somebody on "the Board" could decide that some things posted here are "damaging to the image of our sport", and next thing we know is some appointed "SSA-r.a.s. Admin" telling us "you must remove these postings from the r.a.s. because they make us look bad as a group". This kind of things can be done to the Internet, you know -- just look at China. I'd like to send this new SSA-OLC dish back to the kitchen, and have my OLC the old way, the way we grew to like it. SSA on the side, if you insist, please, thank you. So that I can throw it away if I am being fed too much of it to my taste. -- Yuliy |
There are several factual inacuracies in this post, as noted below:
Yuliy Gerchikov wrote: "Doug Haluza" wrote in message oups.com... As far as changing the rules, the sunset rule has been on the books for longer than almost anyone can remember. Doug, I think you know very well which rules I refer to -- and those are not FARs. OLC has been designed and introduced as an open forum for the pilots worldwide to share and compare flight traces online. Their rules specifically said that they did not intend to police submitted traces for airspace violations, etc. *That* is what has changed since SSA took over. Actually, the OLC rules say they reserve the right to take action against the pilot for airspace violations, if they become aware of it. I have confirmed with the OLC International team that they do not wish to sanction flights that the national OLC team does not wish to sanction. If you insist on quoting the rules, their rules, in particular, say (in the most current version dated 7/13/2006 available at http://www2.onlinecontest.org/regeln/2006/regeln.php): "10. Validation. Flights and scores will be accepted if no objections have been filed against them within 4 weeks after the corresponding weekly deadline". Why have some scored flights much older than that been quietly disappearing lately? *That* is what has changed since SSA took over. The flights that have quietly disappeared were withdrawn voluntarily by the pilots, once the problems were pointed out to them in private. Most pilots have been quite reasoanble and decided to do the right thing. Only two pilots have refused, and taken their position public on r.a.s. Another example, from your own presentation: "SSA has exclusive rights to OLC in US -- SSA Membership is now required." Makes me go Hmmm.... *That* is what has changed since SSA took over. The SSA did not make this [FAR] rule, they just decided not to ignore it. Exactly, they *just* decided. Just like that. They *just* decided to go back and check some of the flights for some of the violations and pull them. No, the SSA has been checking since the beginning of the year, and reporting to the SSA ExCom at their request. We did find one flight early in the season that appeared to land too late in SeeYou, but not when checked against the USNO, so no action was taken. We did not become aware of any other cases until recently. No flights have been "pulled" but flights that have received formal complaints that appear to be valid have had the scores temporarily set to "null" and a note added in the offiicial comments to avoid duplicate complaints. If it is indeed true that "the [SSA] Board has directed [you] to look at Sunset and Class-A", then, again, one has to wonder what rules will be pulled out of the hat (or out of the FAR) tomorrow. I gave you some ideas yesterday -- anybody on the Board listens? Posting to r.a.s is not the proper way to put business before the Board. The aspect of it that strikes me most is that SSA came uninvited and took over this great public resource, this open forum for pilots, and started telling everybody what can and what can't be posted there -- and by whom. SSA was invited by the OLC organizers to sanction the OLC-US which was renamed the SSA-OLC. The two parties executed a formal Memorandum of Understanding on July 7, 2005. SSA has not restricted who can post (but only members will be elligible for awards). SSA has taken the position that flights above 18,000' without a proper ATC clearance, or flights after sunset without approved lighting should not be posted because it could damage the SSA's working relationship with the FAA (and is also unsporting conduct). Here is an idea for you: why doesn't SSA take over the US part of rec.aviation.soaring as well? You could make another presentation and tell us that "SSA has exclusive rights to r.a.s. in US -- SSA Membership is now required." While you are at it, why not put a big SSA banner with commercial ads right on top of every posting. And then somebody on "the Board" could decide that some things posted here are "damaging to the image of our sport", and next thing we know is some appointed "SSA-r.a.s. Admin" telling us "you must remove these postings from the r.a.s. because they make us look bad as a group". This kind of things can be done to the Internet, you know -- just look at China. I'd like to send this new SSA-OLC dish back to the kitchen, and have my OLC the old way, the way we grew to like it. SSA on the side, if you insist, please, thank you. So that I can throw it away if I am being fed too much of it to my taste. -- Yuliy |
ps.com... Actually, the OLC rules say they reserve the right to take action against the pilot for airspace violations Correct. But does it say anything about any other regulations that SSA seems to turn on and off on a whim, or, correction, "as directed by the Board"? , if they become aware of it. Correct. But SSA, apparently, had nothing better to do but to take it upon itself to *make* them aware of such cases -- apparently in a very selective and retroactive way. I have confirmed with the OLC International team that they do not wish to sanction flights that the national OLC team does not wish to sanction. Correct. *That* is what has changed since SSA took over. You call it sanctioning, I call it policing. The flights that have quietly disappeared were withdrawn voluntarily by the pilots, once the problems were pointed out to them in private. Most pilots have been quite reasoanble and decided to do the right thing. Correct. Now we have in SSA the authority to tell us what's the right thing to do. flights that have received formal complaints that appear to be valid have had the scores temporarily set to "null" Oh. Formal complaints, huh? Given that, I quote, "the SSA has been checking since the beginning of the year, and reporting to the SSA ExCom at their request", I can't help but wonder how many of those "formal complaints" came straight from the person or persons appointed by the SSA to "sanction" (your word) flights. Would SSA-OLC like to publish those "formal complaints", so that we don't have to speculate? If it is indeed true that "the [SSA] Board has directed [you] to look at Sunset and Class-A", then, again, one has to wonder what rules will be pulled out of the hat (or out of the FAR) tomorrow. I gave you some ideas yesterday -- anybody on the Board listens? Posting to r.a.s is not the proper way to put business before the Board. Excuse my improper ways, please. In fact, obviously, I was not trying to but any new business before the Board -- indeed, I would like to think that the Board has enough business before it at the moment. Quite the opposite, I was pointing out the fact that the Board has put too much business before itself trying to pick and choose which FARs to enforce, which *not* to enforce, and when. SSA was invited by the OLC organizers to sanction the OLC-US which was renamed the SSA-OLC. I don't blame them -- it takes money to run the OLC. However, I happen to think that inviting the SSA, if they indeed did so, might have been a mistake on their part. -- Yuliy |
Maybe the SSA should leave the postings alone, and just submit the
questionable ones to the FAA for enforcement action. That might be an even more effective strategy to solve the problem. Mike Schumann "Yuliy Gerchikov" and_.hope.it.travel wrote in message ... "Doug Haluza" wrote in message oups.com... As far as changing the rules, the sunset rule has been on the books for longer than almost anyone can remember. Doug, I think you know very well which rules I refer to -- and those are not FARs. OLC has been designed and introduced as an open forum for the pilots worldwide to share and compare flight traces online. Their rules specifically said that they did not intend to police submitted traces for airspace violations, etc. *That* is what has changed since SSA took over. If you insist on quoting the rules, their rules, in particular, say (in the most current version dated 7/13/2006 available at http://www2.onlinecontest.org/regeln/2006/regeln.php): "10. Validation. Flights and scores will be accepted if no objections have been filed against them within 4 weeks after the corresponding weekly deadline". Why have some scored flights much older than that been quietly disappearing lately? *That* is what has changed since SSA took over. Another example, from your own presentation: "SSA has exclusive rights to OLC in US -- SSA Membership is now required." Makes me go Hmmm.... *That* is what has changed since SSA took over. The SSA did not make this [FAR] rule, they just decided not to ignore it. Exactly, they *just* decided. Just like that. They *just* decided to go back and check some of the flights for some of the violations and pull them. If it is indeed true that "the [SSA] Board has directed [you] to look at Sunset and Class-A", then, again, one has to wonder what rules will be pulled out of the hat (or out of the FAR) tomorrow. I gave you some ideas yesterday -- anybody on the Board listens? The aspect of it that strikes me most is that SSA came uninvited and took over this great public resource, this open forum for pilots, and started telling everybody what can and what can't be posted there -- and by whom. Here is an idea for you: why doesn't SSA take over the US part of rec.aviation.soaring as well? You could make another presentation and tell us that "SSA has exclusive rights to r.a.s. in US -- SSA Membership is now required." While you are at it, why not put a big SSA banner with commercial ads right on top of every posting. And then somebody on "the Board" could decide that some things posted here are "damaging to the image of our sport", and next thing we know is some appointed "SSA-r.a.s. Admin" telling us "you must remove these postings from the r.a.s. because they make us look bad as a group". This kind of things can be done to the Internet, you know -- just look at China. I'd like to send this new SSA-OLC dish back to the kitchen, and have my OLC the old way, the way we grew to like it. SSA on the side, if you insist, please, thank you. So that I can throw it away if I am being fed too much of it to my taste. -- Yuliy |
"Mike Schumann" wrote in message
ink.net... Maybe the SSA should leave the postings alone, and just submit the questionable ones to the FAA for enforcement action. That might be an even more effective strategy to solve the problem. Gee, Mike, thanks! That's exactly what SSA should be doing. Many were wondering what SSA was actually doing for the members for their money. Somebody mentioned the magazine, others said group insurance rates. Well, no more guessing -- now we know ![]() BTW, that was exactly one of my points: leave enforcement to FAA. It's not up to SSA, OLC, r.a.s. or any of us to call violations. It's between the pilot and the feds. If SSA realized this, the world would be a better place. Now, if SSA wanted to take upon itself the burden of inspecting all (or, as it's been the case, some) of the flights for all (or some) violations and pass them to FAA, that, actually, would be totally fine with me. I've seen stranger hobbies. Except, not on my nickel. I just don't need to be a part of it. -- Yuliy |
12. Airspace Violations
The OLC organizers have to assume that the participants in the contest will not violate restricted airspace during their flights. ATC clearances are necessary to enter certain airspace. The OLC team will not check if a pilot has obtained the necessary clearance to enter airspace which needs ATC clearance. This is not within our competences and responsibilities. However, if we get to know that there has been an obvious violation of airspace then we reserve the right to carry out special actions against that pilot and his participation in the OLC. Of course every pilot is allowed to contact other pilots in case of a potential airspace violation. What rules are they changing? Is busting FAR's okay if they do not specify not to? Will your insurance pay a claim if you get hit at FL200 or flying after sunset? If we as a group knowingly allow cheating to occur, are we liable as well? If pilots want to fly illegally, they don't need to post logs for the rest of us to see. I wish pilots flew in accordance to the *privilege* of the license...then this discussion would be moot. Calling enforcement an issue is a weak argument. At 01:06 07 September 2006, Yuliy Gerchikov wrote: Doug, May I make some suggestions? (1) Do not change OLC rules mid-season. (2) If you insist on checking all traces for certain violations, do it at the time of claim -- automatically -- and reject those that do not pass, there and then. |
For Keith Willshaw... | robert arndt | Military Aviation | 253 | July 6th 04 05:18 AM |
S-TEC 60-2 audio warning | Julian Scarfe | Owning | 7 | March 1st 04 08:11 PM |
