#21
"RST Engineering" wrote in message ... "Morgans" wrote in message news ![]() "Scott" wrote in message .. . Nope, not really a concerning factor. Any of the "garden variety" diodes in the 1N400X series should be fine. Just be sure to put the cathode to the +12 or +24 volt side of the contactor coil and the anode to the ground side (assuming a negative ground system). Scott, at and above the 1N4004, the chip inside the case is physically more robust and will take a spike of current a little better than, say, a 1N4001. I am not very good with the electron understanding, but I would be grateful to understand this whole discussion. Is the cathode normally the downstream side of the diode? What does the installation like this, do, to help with the current spike? Jim, as you know, a diode conducts current in one direction and blocks it from conducting in the other direction. A positive voltage on the anode forward biases the diode and the voltage will appear as a positive voltage (less some small conduction drop of a volt or so) at the cathode. A negative voltage on the anode will reverse bias the diode and it will not appear as a negative voltage at the cathode. Likewise, a negative voltage at the cathode will appear as a negative voltage at the anode. When a coil has a collapsing field, it produces a spike of energy as the field attempts to keep the current through the coil constant. THis large negative spike can and will cause some of the aircraft electronics to fail catastrophically. One way of making sure that negative spike doesn't kill the avionics is to shunt it to ground through a forward biased diode. That way the most that can sneak through is a volt or so as opposed to several hundred volt spikes without the diode. How do you forward bias a diode with a negative voltage? You connect the CATHODE to the "hot" +12 volt terminal of the coil and the ANODE to ground. THe negative spike is effectively clipped at a volt or thereabouts. Jim I totally missread the initial question when this thread first started, and somehow I suspect that I may not have been the only reader who did so. The battery contactor, usually operated by the master switch, should normally be a trivial case with regard to voltage spikes the circuit is protected by the battery. It does no harm to protect the circuit and, if you want to be really anally retentive, you could measure the current drawn by the coil of the contactor and size the diode for a little more current than that. Once the current is flowing in an inductor, such as a contactor coil, it will try to continue flowing at the same rate when you first turn it off--which causes a voltage spike several times the normal operating voltage. The protection diode simply allows the current to flow around in a circle--through the diode and around back through the coil for a few milliseconds until the resistance of the wiring in the coil uses up the energy. Thus, presuming that the diode is located at the coil, the voltage spike should be limited to the forward voltage drop of the diode--usually about six tenths of a volt. With regard to possible damage to avionics, the contactors which have their coils powered from the master buss (which presumably is activated by the battery contactor) are the greater issue and all should be protected by diodes--although capacitors may also work. Technically this is airframe wiring and therefore in the mechanic's job description--so that is who to see in the case of a certified aircraft. Otherwise, nearly every EAA chapter has members who are or were mechanics as well as members who are or were avionics technicians--and a couple of cups of coffee with the three of you together, and maybee a couple of additional members, will quickly solve a lot of problems. Remember that is a lot of the original and continuing reason for chapters! BTW the 1N400X series of diodes are 1 amp, and I believe that the next common size is/was around 3 amps. Regards, Peter |
I could'na said it better myself.
Jim wrote in message ups.com... Any sensitive electronic device (like an expensive radio) without its own internal protection goes poof. Poof. THat's a technical term. Stick around long enough and you'll get it. That magneto won't work worth a hoot without the capacitor (sometimes called condenser). Hoot's a technical term also. See answer above. For the advanced student, do the calculation of the inductive reactance of the magneto coil, the capacitive reactance of the magneto capacitor, the frequency of the coil spark (RPM adjusted for seconds and the number of cylinders) and see where the resonant frequency of that inductor and capacitor are. For the Master's thesis, factor in the resistance of the coil and see how broad the Q of the resonant circuit is. For the PhD dissertation, calculate the velocity of the flame front and demonstrate the maximum cylinder pressure for two magnetos timed "x" degrees apart. Jim Jim |
Please do not listen to this person. (S)he understands nothing about
reverse emf, nor about reverse voltage spikes. The forward current drawn by the coil has no bearing on the multiple hundreds of amps that a reverse polarity diode needs to conduct to keep a large NEGATIVE voltage spike from frapping (that's a technical term, you'll get used to it) your radios. Jim The battery contactor, usually operated by the master switch, should normally be a trivial case with regard to voltage spikes the circuit is protected by the battery. It does no harm to protect the circuit and, if you want to be really anally retentive, you could measure the current drawn by the coil of the contactor and size the diode for a little more current than that. |
The reverse emf spike, just like any other emf, is measured in volts only.
The reverse current required to damage electronics is very small--that means very very small. The coils of those little Ice Cube relays, with contact ratings less than about 10 amps, usually have coil currents of less than 100ma; which is why 1N4004 diodes are so popular--and really overkill but they weigh less than a gram. Larger relays, used to control more power, are part of the mechanical airframe wiring and I continue to recommend that you talk to one of the mechanics in your local chapter--one who also holds an IA. There are more than enough small type certified aircraft in the rental fleet to generate a highly reliable set of service bulletins with which a mechanic with IA will be quite familiar. I also continue to recommend that you include an electronics technician (preferably avionics) in the conversation because all three on you, and any other builders who attend, will come away with greater knowledge. Disclaimer: Clearly, my technical knowledge is gravely wanting, as I have no idea what "frapping" means. Peter "RST Engineering" wrote in message ... Please do not listen to this person. (S)he understands nothing about reverse emf, nor about reverse voltage spikes. The forward current drawn by the coil has no bearing on the multiple hundreds of amps that a reverse polarity diode needs to conduct to keep a large NEGATIVE voltage spike from frapping (that's a technical term, you'll get used to it) your radios. Jim The battery contactor, usually operated by the master switch, should normally be a trivial case with regard to voltage spikes the circuit is protected by the battery. It does no harm to protect the circuit and, if you want to be really anally retentive, you could measure the current drawn by the coil of the contactor and size the diode for a little more current than that. |
I couldn't agree more.
Jim Weir Avionics Technician 1963 - 1967 Avionics Engineer 1967 - 20- A&P, IA "Peter Dohm" wrote in message news
I continue to recommend that you talk to one of the mechanics in your local chapter--one who also holds an IA. There are more than enough small type certified aircraft in the rental fleet to generate a highly reliable set of service bulletins with which a mechanic with IA will be quite familiar. I also continue to recommend that you include an electronics technician (preferably avionics) in the conversation because all three on you, and any other builders who attend, will come away with greater knowledge. |
"Peter Dohm" wrote: Disclaimer: Clearly, my technical knowledge is gravely wanting, as I have no idea what "frapping" means. Peter Acronym.... **** FRAP Fluorescence Recovery After Photobleaching **** FRAP Fire and Resource Assessment Program (California) **** FRAP Facilitated Risk Analysis Process **** FRAP Frame Relay Access Probe (Tylink) **** FRAP Free Route Airspace Project (aeronautical) *** FRAP Frenetic Random Activity Period (dog behavior *** FRAP Fuel Rod Analysis Program *** FRAP Fragmenting Payload *** FRAP Flat Rate Access Promotion (Sprint) *** FRAP Fleet Reliability Assessment Program *** FRAP Facilitated Risk Analysis Procedure * FRAP Frame Relay Access Point American Heritage Dictionary - Middle English frapen, to strike, from Old French fraper. 8o) - Barnyard BOb - |
| Thread Tools | |
| Display Modes | |
| Electric maned airplane | Flyingmonk | Home Built | 26 | July 20th 06 06:43 AM |
| battery self-destruct | [email protected] | Owning | 13 | June 14th 06 12:04 AM |
| Battery Question | [email protected] | Soaring | 19 | September 15th 05 02:38 AM |
| 14 Volt Gel Cell? | Joe Allbritten | Soaring | 32 | May 11th 04 02:37 AM |
| Icom A5 Battery Tester ?? | Harry Gordon | Piloting | 5 | January 10th 04 02:29 PM |
