First IFR flight after checkride
Old August 24th 04, 08:28 PM
john smith
Dave Butler wrote:
Newps wrote:
Dave Butler wrote:
AFAIK there is no term "VFR departure" that means what you said.
He meant VFR climb. That makes you responsible for terrain and
possibly traffic. This is very common out here in the West to
expedite getting on course, you don't have to follow a cumbersome DP
to clear terrain.
OK. VFR climb I am familiar with. I've never seen it used when issued a
clearance prior to takeoff, though. Must be a regional thing. I can see
where it could be convenient where terrain is an issue. DGB
No, the exact language in the book is VFR DEPARTURE. (Where did I post
it, I typed the wording exactly as it appeared in the book?)
It is also explained on one of the recent PILOT'S AUDIO UPDATE CD'S.
Old August 24th 04, 08:31 PM
john smith
to clear terrain.
Found it. Accidently got posted a couple threads down.
This from the newly issued INSTRUMENT PROCEDURES HANDBOOK (FAA-H-8261-1)
Page 2-32...
VFR DEPARTURE
There may be times when you need to fly an IFR flight plan due to the
weather you will encounter at a later time (or if you simply wish to fly
IFR to remain proficient), but the weather outside is clearly VFR. It
may be that you can depart VFR, but you need to get an IFR clearance
shortly after departing the airport. A VFR departure can be used as a
tool that allows you to get off the ground without having to wait for a
time slot in the IFR system, however, departing VFR with the intent of
receiving and IFR clearance in the air can also present serious hazards
worth considering.
A VFR departure dramatically changes the takeoff responsibilities for
you and for ATC. Upon receiving clearance for a VFR departure, you are
cleared to depart; however, you must maintain separation between
yourself and other traffic. You are responsible for maintaining terrain
and obstruction clearance as well as remaining in VFR weather
conditions. You cannot fly in IMC without first receiving your IFR
clearance. Likewise, a VFR departure relieves ATC of these duties, and
basically requires them only to provide you with safety alerts as
workload permits.
Maintain VFR until you have obtained your IFR clearance and have ATC
approval to proceed on course in accordance with your clearance. If you
accept this clearance and are below the minimum IFR altitude for
operations in the area, you accept responsibiility for
terrain/obstruction clearance until you reach that altitude.
Old August 24th 04, 09:16 PM
Dave Butler
to clear terrain.
a clearance prior to takeoff, though. Must be a regional thing. I can
see where it could be convenient where terrain is an issue. DGB
Yes, and the language you posted makes it very clear that it is not an IFR
operation. Read what it says. A VFR departure is simply departing VFR and
getting a clearance later.
Old August 25th 04, 01:42 AM
john smith
to clear terrain.
IFR operation. Read what it says. A VFR departure is simply departing
VFR and getting a clearance later.
As I understand it, you have already obtained your IFR clearance, you
are just being held for release until the other inbound/outbound traffic
is assured to be clear of the airspace. You have your IFR clearance, you
depart VFR to provide the separation/obstruction/terrain clearance.
Similar to a VFR ON TOP clearance. You are IFR, but you are at a VFR
altitude and assume separation/obstruction/terrain clearance until such
time as you elect to operate at an IFR altitude or encounter IFR conditions.
Old August 25th 04, 03:00 AM
PaulaJay1
In article , Dave Butler
writes:
Where I live, there's a clearance delivery phone number that's different from
the WX-BRIEF number. Not sure that's true everywhere, though. Never had the
"all
briefers are busy" message on the clearance delivery line.
Interesting, Dave. I scaned the 250 airports listed in Airguide Flight Guide
for Ohio and found only one (MGY) that had a phone number for DEL. Many of the
ASOS/AWOS have a phone number as well as a frequency but not DEL. What is your
airport? I'd like to see if it is listed in Airguide.
Chuck
Old August 25th 04, 03:42 AM
Newps
Yes, so far so good.
You are VFR at this point. Period. No ifs ands or buts. Your IFR
clearance is in no way in effect.
No. An OTP operation is an IFR operation. A VFR departure is just
that, VFR.
Old August 25th 04, 01:32 PM
Dave Butler
conditions.
That's not what the snippet you posted says. Have you read it?
Old August 25th 04, 01:41 PM
Dave Butler
writes:
"all
RDU. The statewide clearance delivery phone number for North Carolina is
800-548-3196.
Some of the clearance delivery numbers seem to be at
http://flighttraining.aopa.org/membe...g/pdfs/fss.pdf
  #29
Old August 25th 04, 02:35 PM
Stan Prevost
They are in the A/FD.
"Dave Butler" wrote in message
writes:
from
"all
Guide
of the
is your
800-548-3196.
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP vvcd Home Built 0 September 22nd 04 07:16 PM
FAA letter on flight into known icing C J Campbell Instrument Flight Rules 78 December 22nd 03 07:44 PM
Sim time loggable? [email protected] Instrument Flight Rules 12 December 6th 03 07:47 AM
IR checkride story! Guy Elden Jr. Instrument Flight Rules 16 August 1st 03 09:03 PM
