cost to install engine analyzer (4 cyl)?
Old October 2nd 06, 01:39 AM posted to rec.aviation.owning
Dan Luke
Default Why a rough engine? (Was: cost to install engine analyzer (4 cyl)?)
"Andrew Gideon" wrote:
On Sat, 30 Sep 2006 17:33:54 -0500, Dan Luke wrote:
One or more cylinders wiil get too lean before the others, causing uneven
power production.
So the rough running is called by cylinders generating different power
levels? Why can't that occur anywhere in the air/fuel mixture curve?
I guess it does, to some extent. The difference isn't detectable until the
leanest cylinder is about to flame out.
Old October 2nd 06, 03:59 AM posted to rec.aviation.owning
Newps
Default Why a rough engine? (Was: cost to install engine analyzer(4 cyl)?)
Assuming the moving metal parts are very close together in weights the
only other thing that will affect noticeable vibration is the cylinders
making different amounts of power. If you can get each cylinder to peak
within about .2 gph you will have a very smooth engine indeed.
Old October 2nd 06, 02:37 PM posted to rec.aviation.owning
Matt Barrow
news
power production.
Andrew, every question you asked is clearly answered, in depth, in John
Deakin's AvWeb series about engine operations, including graphs and charts.
In color!!
Do your homework, lad!
Matt B.
A nation can survive its fools, and even the ambitious, but it cannot
survive treason from within. An enemy at the gates is less formidable,
for he is known and carries his banner openly. But the traitor moves
amongst those within the gate freely, his sly whispers rustling through
all the alleys, heard in the very halls of government itself. For the
traitor
appears not a traitor; he speaks in accents familiar to his victims, and
he wears their face and their arguments, he appeals to the baseness
that lies deep in the hearts of all men. He rots the soul of a nation,
he works secretly and unknown in the night to undermine the pillars of
the city, he infects the body politic so that it can no longer resist. A
murderer is less to fear. -- Marcus Tullius Cicero
Old October 4th 06, 12:40 AM posted to rec.aviation.owning
randall g
On Sun, 01 Oct 2006 17:26:40 -0400, Andrew Gideon
power production.
When you are running at a typical rich setting, the maximum possible
combustion will be occurring in all cylinders. The excess unburned fuel
is blown out the exhaust. Since cylinders are about the same size and
compression, you have very similar powers being developed.
Once you start leaning though, the first cylinders to lean past max
power will begin developing less power while all the others are still at
max. This uneven distribution in power results in roughness. As you
continue leaning the cylinders get more unbalanced.
I have just installed Gamijectors in my engine and am about to receive a
second set. They iterate with you until you get peak power/temperatures
to coincide on all cylinders. Once this is done, you can lean quite
aggressively without unbalancing the power produced.
Read Deakins articles on the subject:
http://www.avweb.com/news/pelican/list.html
randall g =%^) PPASEL+Night 1974 Cardinal RG
http://www.telemark.net/randallg
Lots of aerial photographs of British Columbia at:
http://www.telemark.net/randallg/photos.htm
Vancouver's famous Kat Kam: http://www.katkam.ca
Old October 4th 06, 02:39 AM posted to rec.aviation.owning
Newps
Not quite. This only happens at a certain mixture setting. Any other
setting reduces power.
Old October 4th 06, 05:00 AM posted to rec.aviation.owning
randall g
Fair enough, but on the rich side of peak the power curve (vs fuel flow)
is fairly flat, so power differences are relatively minor. On the lean
side it drops much more quickly.
Towing Roger Fowler Soaring 6 August 11th 05 04:25 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 03:07 AM
