#21
Gary Drescher wrote: "Stubby" wrote in message . .. Don't forget the stall is caused by the elevator losing lift. No, that's incorrect. There is such a thing as an elevator stall, but it's very different from a normal stall. In typical small planes, an elevator stall does not occur unless there is tail icing, or else a CG that's too far forward when you apply substantial up elevator. If you have an elevator stall during a landing flare, the nose snaps abruptly downward, potentially damaging the nose gear. That's why the nose drops. No, not in a normal stall. Rather, the wings produce insufficient lift and so the plane accelerates downward. The plane weathervanes into the new relative wind, dropping the nose. There's more to it than that. The centre of pressure is well behind the centre of gravity in normal flight, and as the AOA is increased and the boundary layer begins to break up toward the aft wing surface, the centre of pressure moves forward somewhat, helping to raise the nose further. At the stall break, where the airflow over the wing more or less completely breaks down, the CP moves aft again, the stab/elevator can't hold the nose up against the suddenly increased nose-down force, and the nose drops. That's not to say the elevator stalled; it didn't, and elevators don't stall except under unusual circumstances such as airframe icing or poor design such as the early Cardinal's stabilator, where the thing would stall in the flare and drop the nosewheel hard on the runway, sometimes breaking it. Cessna added slots to the stab to fix that by preventing stab stall. A stalled elevator would result in the airplane nosing completely over onto its back in flight, since the stab/elevator's AOA would increase as it came up, stalling it further, and control would be totally lost. You'd never get that airplane certified. Dan |
Peter Duniho wrote: "Andrew Sarangan" wrote in message oups.com... If the normal stall speed is 50 knots, you can make it stall at 100 knots if you pull some positive g's, or you can make it stall at 25 knots if you pull some negative g's. On the same token, you can stall the airplane at higher or lower airspeeds depending on the aircraft weight. Minor nit: Replace "some negative g's" with "less than 1g". Or "between -1 and +1 g", if you want to get really particular. ![]() You are right. It is not negative g, but less than plus one g. |
Dave Doe wrote: The stall horn is preset to go off at a specific AOA. It does not give the pilot any indication of the actual AOA being flown. AOA indicator is typically used in large transport airplanes and military jets where the operating envelope is large. For typical GA airplanes, the envelope is so small that the airspeed indicator is a good indication of AOA under normal operating conditions. Isn't the texts on AOA about *critical* AOA? - the rest of it, is surely the other angle - within the load envelope. The stall warning provides a fixed measurement of the imminent critical AOA - what else does a pilot need? The only minor difference is that the stall warning does not tell you where the critical AOA is. It just goes off at some predetermined angle before reaching the critical AOA. However, as you say, a pilot of a GA airplane does not need to know the exact AOA. This is why we don't have AOA gauges in small airplanes. In fact, one could argue that you don't even need the stall warning horn. As long as you are not doing any high-g maneuvers, the ASI tells you how close you are to stall. The dilemma is the lengthy discussions about AOA in texts that deal with small airplanes. This causes all kinds of confusions that is not helpful for the beginning pilot. You can read the archives from this newsgroup and find how many people have been confused by this. We teach them about AOA in the classroom, and then use the airspeed indicator in the cockpit. |
Andrew Sarangan wrote: Dave Doe wrote: The stall horn is preset to go off at a specific AOA. It does not give the pilot any indication of the actual AOA being flown. AOA indicator is typically used in large transport airplanes and military jets where the operating envelope is large. For typical GA airplanes, the envelope is so small that the airspeed indicator is a good indication of AOA under normal operating conditions. Isn't the texts on AOA about *critical* AOA? - the rest of it, is surely the other angle - within the load envelope. The stall warning provides a fixed measurement of the imminent critical AOA - what else does a pilot need? The only minor difference is that the stall warning does not tell you where the critical AOA is. It just goes off at some predetermined angle before reaching the critical AOA. However, as you say, a pilot of a GA airplane does not need to know the exact AOA. This is why we don't have AOA gauges in small airplanes. In fact, one could argue that you don't even need the stall warning horn. As long as you are not doing any high-g maneuvers, the ASI tells you how close you are to stall. The dilemma is the lengthy discussions about AOA in texts that deal with small airplanes. This causes all kinds of confusions that is not helpful for the beginning pilot. You can read the archives from this newsgroup and find how many people have been confused by this. We teach them about AOA in the classroom, and then use the airspeed indicator in the cockpit. And too many students aren't taught that sudden pullups are deadly because of the load factor. They'll buzz a friend, or take off and hold the airplane low until they've got some "safe" airspeed, then yank back on the elevator to get the G rush or to impress someone. Once in a while the airplane will snap-roll right into the ground and the guy never knew what hit him. He thought he was well above the stall speed. Dan |
Andrew Sarangan schrieb:
dilemma is the lengthy discussions about AOA in texts that deal with small airplanes. This causes all kinds of confusions that is not helpful for the beginning pilot. One of the most difficult things in teaching is to explain things an a simple, but nonetheless correct way. Probably because this requires a really profound understanding which most teachers or writers don't have. Stefan |
Stefan wrote: Andrew Sarangan schrieb: dilemma is the lengthy discussions about AOA in texts that deal with small airplanes. This causes all kinds of confusions that is not helpful for the beginning pilot. One of the most difficult things in teaching is to explain things an a simple, but nonetheless correct way. Probably because this requires a really profound understanding which most teachers or writers don't have. Stefan The problem is not the method of teaching, but the relevance of the material being taught. We can talk at length about AOA, but we cannot show the student how to measure it or control it in the cockpit. You can fly the airplane just fine even if you knew nothing about AOA. It is important for understanding of the aerodynamics of an airfoil, but it does not help a presolo student fly an airplane. It is a concept best introduced after mastering the basics of airplane control. |
The problem is not the method of teaching, but the relevance of the material being taught. We can talk at length about AOA, but we cannot show the student how to measure it or control it in the cockpit. You can fly the airplane just fine even if you knew nothing about AOA. It is important for understanding of the aerodynamics of an airfoil, but it does not help a presolo student fly an airplane. It is a concept best introduced after mastering the basics of airplane control. Of course. But it must be taught at a later stage, because a pilot must understand understand that stall speed depends on weight and g-load. And, especially with laminar profiles, a lot on surface cleanness. No scientific details needed, but this dependence must be taught and understood. Stefan |
#29
"Dave Doe" wrote in message
. nz... Isn't the texts on AOA about *critical* AOA? - the rest of it, is surely the other angle - within the load envelope. The stall warning provides a fixed measurement of the imminent critical AOA - what else does a pilot need? Calibrated correctly, an AOA indicator could be useful for a variety of flight regimes, particularly when it comes to maximizing performance (best glide, for example). It's true that the usual student aviation texts don't discuss these things. But that may be more about the lack of a suitable indicator in the airplane than anything else. Pete |
#30
"Peter Duniho" wrote in message ... "Aluckyguess" wrote in message ... Bottom line the wing needs airspeed to fly. At a certain speed the wing starts to lift, when it loses this speed, losing lift it stalls. IMHO, this is a misleading description of stalling, and in fact will lead to just the confusion the original poster describes. Specifically, the wing's speed is really not directly related to stalling at all. As others have explained, the reason a stall speed is published is that it is true that at a given weight and load factor (eg max gross and 1g), there is a specific amount of lift required, and there is a specific speed associated with the angle of attack that can produce that lift. The published stalling speed is simply a speed at which the angle of attack required to achieve the necessary lift at that speed is the same as the critical (stalling) angle of attack. It is not true that under all conditions, at that speed, the wing is stalled (or "when it loses this speed, losing lift it stalls"). The wing loses lift because it stalls, not the other way around. And the wing will only stall at a given airspeed if its angle of attack exceeds the critical angle of attack. This is true of any airspeed, above or below the published stall speed(s). Stick your hand out the window of your car shape it like a wing at a certain speed it will lift all by itself and basically be weightless. However, as long as you keep your "hand wing" angle of attack below the critical angle of attack, it will generate lift at ANY speed above 0. There is no "stalling speed" for your hand in that scenario, as your hand is not required to support itself with lift, and so there is no speed at which the required angle of attack equals or exceeds the critical angle of attack. (That is, there's not even a concept of "the required angle of attack" in that case...your hand will fly along quite happily at any amount of lift, or even zero lift). Pete Try it. It wont lift until you have enough airspeed. At 0 it doesnot lift. The higher the airspeed the higher angle of attack you can have. |
| Thread Tools | |
| Display Modes | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| THOMAS MOORER, EX-JOINT CHIEFS CHAIR DIES | Ewe n0 who | Naval Aviation | 4 | February 21st 04 10:01 PM |
| THOMAS MOORER, EX-JOINT CHIEFS CHAIR DIES | Ewe n0 who | Military Aviation | 2 | February 12th 04 01:52 AM |
| Lift and Angle of Attack | Peter Duniho | Simulators | 9 | October 2nd 03 11:55 PM |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 02:27 PM |
