Tire tread wear vs inflation pressure
Old October 5th 06, 04:43 AM posted to rec.aviation.owning
Dave Stadt
Default Tire tread wear vs inflation pressure
"Roger (K8RI)" wrote in message
On 3 Oct 2006 21:16:37 -0700, "Jay Honeck" wrote:
90% of the planes in the air have under-inflated tires. Seems to be
systemic.
That's because 90% of all GA aircraft are stuck with stupid,
1930s-technology inner tubes.
Of all the dumb things in aviation, that seems to be one of the
dumbest. Mary and I fill our tires every 14 days, and it's a pain in
the butt.
As I've said before, spend the money for the new "low leak"
innertubes. They are well worth the money and the time to install.
I have them and they are a vast improvement and they came free (that's what
the ad said anyway) with the tires from Desser.
If I had a tire like that on my car, it would be classified as a "slow
leak" and be repaired or replaced.
You can do the same with the ones on the airplane albeit the tubes are
a bit more than the ones for cars.
www.rogerhalstead.com
Old October 5th 06, 03:40 PM posted to rec.aviation.owning
Matt Barrow
"Newps" wrote in message
Marty Shapiro wrote:
Has anyone tried the Sporty's hub caps which have the little door to
permit you to check the pressure and/or add air without removing them?
I had them on my 182 and now have them on my Bo. Makes the gear looker
neater.
Hub caps on a Bo? SACRILIDGE!!
Old October 6th 06, 04:35 AM posted to rec.aviation.owning
Roger (K8RI)
On Thu, 05 Oct 2006 03:43:04 GMT, "Dave Stadt"
systemic.
the butt.
I purchased the new tires last winter and the tubes were *extra*.
Guess I bought too soon:-)) OTOH that flat spot was driving me nuts.
Pressure Altitude and Terminology Icebound Piloting 0 November 27th 04 09:14 PM
Why are TE probes so long? Duane Eisenbeiss Soaring 36 May 9th 04 06:58 AM
Tire inflation pressure Paul Lee Home Built 80 November 19th 03 07:56 AM
Tire Stiffness & trailer swaying - resolution chris Soaring 6 October 26th 03 03:50 PM
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance [email protected] Owning 5 July 22nd 03 12:35 AM
