OTOH, jet pilots pitch to the glideslope, power to the airspeed...the way
the autopilot (with speed control) does it. There is a difference between high drag/low power available and low drag/high power available. Bob Gardner "John Gaquin" wrote in message . .. "Mxsmanic" wrote in message For example, lately I've had a tendency to adjust climb or descent rates (and altitude to a lesser extent) by making thrust adjustments, rather than changes in pitch. I seem to recall someone telling me that this was legitimate, but now I can't find the reference. In general, you're on the right track. Power is altitude; pitch is airspeed. |
I don't understand what you mean by "cheating".
In real life there is no "cheating". It's a question of flying safely and with the appropriate amount of stress on the various components of your airplane to balance the results (eg: most efficient flying to save money on gas, or fastest possible flight without reducing engine life, etc). Mxsmanic wrote in : Lately I have modified my flying methods in the sim in ways that seem to produce better results, but I don't know if I'm learning to do things correctly or simply acquiring bad habits. I want to make sure that I don't "cheat" too much when flying. |
Power is altitude and pitch is airspeed is not always true but the
grain of truth is this. Come down at 60, with power to give VSI of 200fpm. Now increase power and leave pitch alone. Your VSI decreases. Conversly, pitch down, and your airspeed increases. So for approaches its sorta true, although of course both power and pitch influence both altitude and airspeed. It's all interelated. |
Judah writes:
I don't understand what you mean by "cheating". By "cheating," I mean doing something that either would not be possible in real life (but can be done in simulation), or doing somethign that seems to work but actually isn't the best way to accomplish the goal, usually because of some hidden drawbacks that only become obvious in certain situations. An example would be using the rudder inappropriately to turn the plane. In some cases, you may get away with it, but in other cases, it may have sudden unpleasant consequences that you could avoid by always turning the aircraft in a different, more generally applicable way. In real life there is no "cheating". It's a question of flying safely and with the appropriate amount of stress on the various components of your airplane to balance the results (eg: most efficient flying to save money on gas, or fastest possible flight without reducing engine life, etc). Some people still cheat in real life. If they are lucky, they get away with it indefinitely. If they are not, they get stuck in a situation where their cheat method doesn't work quite right, and then they die. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote in
: By "cheating," I mean doing something that either would not be possible in real life (but can be done in simulation), or doing somethign that seems to work but actually isn't the best way to accomplish the goal, usually because of some hidden drawbacks that only become obvious in certain situations. An example would be using the rudder inappropriately to turn the plane. In some cases, you may get away with it, but in other cases, it may have sudden unpleasant consequences that you could avoid by always turning the aircraft in a different, more generally applicable way. What do you mean? What sudden unpleasant consequences are you referring to? Some people still cheat in real life. If they are lucky, they get away with it indefinitely. If they are not, they get stuck in a situation where their cheat method doesn't work quite right, and then they die. Are you claiming that turning a plane using only the rudder kills? |
Judah writes:
What do you mean? What sudden unpleasant consequences are you referring to? A departure from controlled flight, such as a stall or spin, or in some cases simply slips or other uncoordinated movements that may make passengers queasy. Are you claiming that turning a plane using only the rudder kills? Apparently so, in some cases, based on what I've read. The stuff I'm reading claims that it's a common mistake in phases such as landings, and sometimes it kills the pilot. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote in
: A departure from controlled flight, such as a stall or spin, or in some cases simply slips or other uncoordinated movements that may make passengers queasy. Slips and uncoordinated flight are not caused by turning the plane with only the rudder, unless perhaps done very sharply. Aileron input is required in order to maintain a slip or uncoordinate flight. Without aileron input the plane will bank by itself during the turn. There are aerodynamic reasons for this phenonmenon that I will let you look up online somewhere. Apparently so, in some cases, based on what I've read. The stuff I'm reading claims that it's a common mistake in phases such as landings, and sometimes it kills the pilot. No. This is inaccurate. Stalls and spins are not caused by the turning of the plane with the only the rudder. Incorrect coordination of rudder and ailerons can turn a stall into a spin, but that doesn't cause the stall. |
... Judah writes: I don't understand what you mean by "cheating". By "cheating," I mean doing something that either would not be possible in real life (but can be done in simulation), or doing somethign that seems to work but actually isn't the best way to accomplish the goal, usually because of some hidden drawbacks that only become obvious in certain situations. An example would be using the rudder inappropriately to turn the plane. In some cases, you may get away with it, but in other cases, it may have sudden unpleasant consequences that you could avoid by always turning the aircraft in a different, more generally applicable way. In real life there is no "cheating". It's a question of flying safely and with the appropriate amount of stress on the various components of your airplane to balance the results (eg: most efficient flying to save money on gas, or fastest possible flight without reducing engine life, etc). Some people still cheat in real life. If they are lucky, they get away with it indefinitely. If they are not, they get stuck in a situation where their cheat method doesn't work quite right, and then they die. -- Transpose mxsmanic and gmail to reach me by e-mail. You can fly most airplanes with rudder and throttle, and/or rudder and elevator, and it won't harm the airplane or cause you to crash. However, a more smoothly coordinated approach is preferred in most situations; so you "won't get no respect" and passengers may be unwilling to fly with you. If you've ever ridden in a car with a driver who is less than smooth, then you know the feeling. Peter |
Peter Dohm writes:
If you've ever ridden in a car with a driver who is less than smooth, then you know the feeling. There's a certain type of auto driver who is constantly pressing and releasing the accelerator, even on smooth, uninterrupted highway, and after a while that can make me queasy. Surely it cannot be that difficult to find a set speed and maintain it. -- Transpose mxsmanic and gmail to reach me by e-mail. |
rates (and altitude to a lesser extent) by making thrust adjustments, rather than changes in pitch. I've been using the throttle to adjust descent rate rather than pitch... That is the way the U.S. Navy teaches it. vince norris |
Cheating the ILS | [email protected] | Instrument Flight Rules | 6 | September 3rd 06 04:22 PM |
Cheating the Reaper! | JJS | Piloting | 7 | July 19th 06 03:34 PM |
Blair Manipulated Intelligence to Justify War, says BBC film | [email protected] | Naval Aviation | 4 | March 22nd 05 06:45 PM |
Date of effect now 1 April 2004 for revised IGC-approval for certain legacy types of GNSS flight recorder | Ian Strachan | Soaring | 56 | December 2nd 03 08:08 AM |
