GPS vs ADF
Old October 24th 06, 03:57 PM posted to rec.aviation.ifr
Michael[_1_]
Default GPS vs ADF
Thomas Borchert wrote:
I find that those without an engineering
background find it counterintuitive and need a lot of time to get used
to it.
If I may: So what? Who says things in life have to be easy or
"intuitive"?
Wow, you sound like an engineer.
Who says it has to be easy or intuitive? Well, the customer. He's the
one who matters. In the software industry (at least the successful
parts of it) software is tested by intended end-users. When the
software doesn't behave the way they expect, you don't retrain them -
you rewrite the software. Of course the developers always bitch about
this, but it's not a grey area. The customers are right and the
developers are wrong. Unfortunately, in this FAA-driven environment,
the customer doesn't matter.
A GPS does very complex things. So it is complex to use.
I said the same thing when I was told to make the doppler non-invasive
flowmeter simple to use. I was told that it wasn't acceptable, and to
make it easy to use. Seven years later, it's still the industry
leader. You CAN make a device that does complex things easy and
intuitive to use. It's just a lot of work.
Is
any of those people you teach really of the opinion that a CDI or an ADF
are more "intutitive" than a moving map? Yeah, right...
Yes. They are. But not to an engineer.
Michael
Old October 24th 06, 04:21 PM posted to rec.aviation.ifr
Thomas Borchert
Default GPS vs ADF
Michael,
Not quite.
You got that right.
Yes, within limits. What I was trying to get at was that indeed many people
complain about very complex things being, well, complex. I tried to point
out that such is life - and that's what makes it so exciting. I feel there's
a trend to "dumb down" things in an increasingly complex world. And I'm not
a fan of that. I'm not trying to make excuses for bad interface design, not
at all. But in my experience, there are limits to what you can do in that
arena. Also, things simply change. To expect everything to remain the same
in life without any new stuff coming in is, well, not very smart.
Is
Excuse me, but that's just not true. Anyone who has gone through instrument
training will tell you that an ADF is anything but intuitive. It's just
something a pilot may be more used to, that's all.
Thomas Borchert (EDDH)
Old October 24th 06, 04:35 PM posted to rec.aviation.ifr
Jose[_1_]
Default GPS vs ADF
The problem is when things are =unnecessarily= complex. This often
results from attempting to impose an inappropriate paradigm on the user
interface, or from some limitations on the hardware, or from an
ill-conceived idea of what "complex" means. (I have an answering
machine that has just one button. It is a pain in the ass to use. The
one that has ten buttons is lots simpler. Each button does one thing.
Jose
"Never trust anything that can think for itself, if you can't see where
it keeps its brain." (chapter 10 of book 3 - Harry Potter).
Old October 24th 06, 05:13 PM posted to rec.aviation.ifr
Sam Spade
Default GPS vs ADF
Jose wrote:
What I was trying to get at was that indeed many people complain about
Jose
Panel mount navigators are actually much more complex (and far less
capable) than FMS/LNAV systems on high-end biz jets and modern
airliners. This is the result of cost and panel space limitations in
small, light aircraft.
Old October 25th 06, 08:37 AM posted to rec.aviation.ifr
Thomas Borchert
Default GPS vs ADF
Jose,
True.
Old November 7th 06, 12:12 AM posted to rec.aviation.ifr
[email protected][_1_]
Default GPS vs ADF
Sam Spade wrote:
Michael wrote:
I wouldn't even attempt to use any other panel mount without a similar
amount of learning and practice. I also find using the 530 in a single
pilot environment without an autopilot to be a excessive knob twisting,
bad human-factors situation.
*** A decent controller will know it too. "Turn left 270, direct CEDES
when able".
Key to comfort with the 430 for me was to get proficient at flying
pieces of flight
plans and approaches. ATC will "help" you by giving you shortcuts. At
SQL they
always give me "direct AMEBY", which is not an IAF. Or they will give
you a vector
to join an airway.
It's important to know how to do these things before blasting off
into IMC.
(Hint: [FPL][DIRECT] or [FPL][DIRECT][DIRECT] )
- Jerry Kaidor ( )
Old November 7th 06, 09:10 PM posted to rec.aviation.ifr
Ron Natalie
Default GPS vs ADF
Sam Spade wrote:
Nonetheless, there is far too much knob twisting required to enter or
modify a flight plan, etc, for one person to do it and try to hand fly
the aircraft at the same time.
Less knob twisting on the 480. Once you're at a known place, the
possible Airways out are on hot keys and the exit points from those
airways are easily scrolled up.
