I was wondering if the excessive fuel flow indication changes with pump on
vs off. "Robert M. Gary" wrote in message oups.com... Stan Prevost wrote: Robert, does it matter whether the boost pump is on or not? No, pressure holds solid at 22lbs. -Robert |
Your turbine JPI device may only report to the JPI display.
The fuel pressure indicator/fuel flow that was original equipment shows high pressure is there is a blockage and low fuel flow. But the higher indicated pressure is also interpreted as a higher fuel flow. If you have EGT on each cylinder, checking temperatures and thus fuel being burned can help determine if the cylinders are rich or lean. "Robert M. Gary" wrote in message ps.com... |I just spoke with Lycoming regarding my very high fuel flow. Recently | I've had a problem where I'm getting almost double my normal fuel flow | at idle even with the mixture at the edge of cut-off. I suspected a | servo but called Lycoming. They said I may have a nozzel with a | blockage and the other nozzles are streaming because of it. | Does this make any sense? Could a blockage cause an *INCREASE* in fuel | flow? | I have a JPI fuel transducor wheel that measures fuel flow that has | shown to be very accurate. | | -Robert | |
Does Lycoming make any sense? | Robert M. Gary | Piloting | 22 | October 24th 06 12:01 AM |
Which overhauled Lycoming 0-360 A4M Engine To Fit In My Archer ? | Roy Page | Owning | 7 | February 2nd 06 02:19 AM |
MAKE THOUSANDS NO SCAM | [email protected] | Home Built | 0 | February 28th 05 02:06 AM |
millionaire on the Internet... in weeks! | Malcolm Austin | Soaring | 0 | November 5th 04 11:14 PM |
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 0 | September 2nd 04 05:15 AM |
