Percent power altitude
Old October 25th 06, 02:30 PM posted to rec.aviation.ifr
Stan Prevost
Default Percent power altitude
"Doug" wrote in message
ever having to run the engine at peak (which is too hot and hazardous
in itself).
For my 1999 Saratoga TC, all the cruise performance charts are given for
peak EGT, including the ones for maximum performance cruise.
Old October 25th 06, 04:46 PM posted to rec.aviation.ifr
John R. Copeland
"Thomas Borchert" wrote in message ...
Doug,
Thus you have found 100 or so degrees rich of peak without
in itself).
Come again? That part in parenthesis is completely wrong.
Thomas Borchert (EDDH)
Thomas, I think you snipped away an important part of Doug's post.
He was trying to stress the need for leaning to a temperature limit.
Stainless steels approach their softening points above 900C (1650F).
Doug's "too hot and hazardous" remark referred only to the peak EGT
reached at a high power setting, where the peak temperature is high
enough to enter the softening region of the exhaust collectors.
Doug's advice about never leaning above a safe temperature
is well advised, and it's exactly what I've followed for 25 years.
In fact, I found that leaning to RAM's recommended 1550F
still results in a little exhaust-system distortion, and I've held to
1525F max for the last ten years or so, with better results.
Old October 25th 06, 07:16 PM posted to rec.aviation.ifr
Allen[_1_]
"John R. Copeland" wrote in message
I believe their recommendation at 75% power is 100 degrees rich of "peak",
not 100 degrees rich of 1650 degrees. Most engines will peak at a
temperature less than 1650 degrees.
Allen
Old October 25th 06, 11:44 PM posted to rec.aviation.ifr
John R. Copeland
"Allen" wrote in message et...
Allen
OK, let me try to rephrase what Doug already said correctly...
*At the higher power settings*, say about 70% and above,
the peak EGT *will* rise above steel's softening temperatures.
If your EGT gauge is calibrated for temperature,
never lean above 900C/1650F, except for very brief time.
Preferably, lean directly to the desired temperature and fuel flow.
RAM recommends operating at 850C/1550F, but my experience says
that's slightly too high, and I lean to about 25F cooler than that.
My penalty is less than 5% additional fuel flow above RAM's figures.
Yes, avgas is expensive, but replacing exhaust parts is expensive, also.
My engines certainly will peak above 1650F at high power settings,
but not so when operated down around economy power settings,
which would typically be below 65%.
I normally cruise my TSIO320s at about the 50% power level,
and even there, my peak EGTs remain above my personal target of 1525F.
From my cockpit, I can see down through louvers in the tops of my
engine nacelles, into the areas around the turbochargers.
I've had passengers at night ask me why I have yellow-orange lights
turned on in the engine compartments. :-/
When you've seen your exhaust components glowing in the dark,
you get a better appreciation of the stress they endure hour after hour.
They are more than red-hot, they are nearly yellow-hot.
Don't abuse your exhaust system any more than necessary.
Old October 26th 06, 01:07 AM posted to rec.aviation.ifr
Jim Macklin
Very true. On a turbocharged airplane the EGT is calibrated
and called a TIT [an a jet it is ITT or TPT]
The turbo has designed temperature limits and because it is
rotating at 35,000 to 120,000 rpm it needs very good
strength to stay in one piece. It also needs to be cooled
at a moderate idle speed for 4-5 minutes to allow it to
spool down, cool off and have good oil pressure. A closed
throttle idle doesn't supply enough oil volume to cool the
turn bearing, and a fast idle, particularly a simple fixed
waste gate type won't let it slow down enough.
Bottom line, RTFM for the particular model and serial
number.
message . ..
et...
message
temperature
25 years.
I've held to
results.
rich of "peak",
peak at a
Allen
correctly...
temperatures.
fuel flow.
says
than that.
figures.
expensive, also.
settings,
of 1525F.
of my
lights
dark,
after hour.
Old October 26th 06, 01:50 AM posted to rec.aviation.ifr
Doug[_1_]
I agree I didn't say it right. But the procedure has some value. You
lean to peak at 10000', you are leaning to a safe EGT. THAT EGT will be
well rich (or lean) of peak at "dangerous" power settings (like 75% or
more) and you have found this rich (or lean) of peak by never leaning
all the way to peak.
That is what I meant. Sorry about the poor (actually incorrect) wording.
Old October 26th 06, 01:53 AM posted to rec.aviation.ifr
John R. Copeland
Beechcraft, for example, calls it "TIT" instead of "EGT".
Some others still call it "EGT" on turbocharged airplanes.
But they all mean the same measurement.
"Jim Macklin" wrote in message ...
number.
message . ..
et...
message
temperature
25 years.
I've held to
results.
rich of "peak",
peak at a
Allen
correctly...
temperatures.
fuel flow.
says
than that.
figures.
expensive, also.
settings,
of 1525F.
of my
lights
dark,
after hour.
Old October 26th 06, 04:26 AM posted to rec.aviation.ifr
Jim Macklin
Not exactly. It depends on whether the gauge is calibrated
to an exact temperature or whether the gauge is used only to
find relative peak and degrees above and below. It also
depends on where the probe(s) are installed. EGT has the
probes about 4 inches past the exhaust valves, TIT has THE
probe at the inlet to the turbocharger. ITT has the probe
located between two turbine wheels in a jet engine.
They all measure the temperature of the combustion process
and thus relate to the fuel/air ratio. But how that relates
to the engine operation will vary. On a turbine engine the
critical temp limit is the start temperature. But in a King
Air for example, some models have the temperature probe in
the tail pipe and some have it in the hot section. With the
tail pipe measurement location the start temp limit might be
only 400°C, but it could run continuously at 650° and in
reality, the engine might actually be at the same
temperature.
message ...
"Jim Macklin" wrote
in message ...
calibrated
is
number.
message
et...
in
message
temperature
for
25 years.
1550F
and
I've held to
results.
degrees
rich of "peak",
peak at a
Allen
correctly...
temperatures.
fuel flow.
says
than that.
RAM's
figures.
expensive, also.
settings,
settings,
level,
target
of 1525F.
tops
of my
yellow-orange
lights
dark,
hour
after hour.
  #29
Old October 26th 06, 02:27 PM posted to rec.aviation.ifr
Allen[_1_]
number.
John's airplane, a Cessna 340, came from the factory with an EGT (when
installed), not TIT. EGT is located forward of the turbo and actually has a
higher temperature than the TIT. Some airplanes, such as the P-Baron and
58TC have TIT, the probe is actually located in the turbo inlet. I was just
commenting to John that I have never seen RAM recommend any particular EGT,
only the 1650 degree max. I agree with the rest of your post.
Allen
  #30
Old October 26th 06, 02:39 PM posted to rec.aviation.ifr
Allen[_1_]
On single-probe EGT systems such as on John's Cessna 340 the probe is
located toward the tail end of the exhaust riser, well ahead of the turbo
but past the 4" point. This was determined (by Cessna) to be the point
where the exhaust gas is hottest. Cessna POH for the 340 recommends running
at peak for many power settings below about 62%. Cessna designed their own
exhaust systems on their twins, Beechcraft had TCM design their exhaust as a
unit with the engine.
Allen
Backup Flight Data Recorder? Fox Two Soaring 14 August 27th 06 09:42 AM
The Deaf vs. The Colorblind Bret Ludwig Piloting 17 August 21st 06 02:08 AM
Catastrophic Decompression; Small Place Solo Aviation Piloting 193 January 13th 04 08:52 PM
Change in TAS with constant Power and increasing altitude. Big John Home Built 6 July 13th 03 03:29 PM
