Aircraft antennas
Old October 23rd 06, 04:12 PM posted to rec.aviation.homebuilt
ccwillwerth
Default Aircraft antennas
Hi, I am about ready to cover my Cub type airframe, but need a place to
attach a com antenna. I was considering brazing a plate to the airframe so
that it would be just under the fabric. The antenna is the type that has a
ceramic insulator on the bottom of the antenna that insulates the stainless
steel antenna from the airframe. Does the antenna need a large plate for a
ground plane or will a small plate be sufficient? If a ground plane is
required, can the copper foil tape be used on the inside of the fabric as
the ground plane?
Charlie
Air Force Aerial Refueling Methods: Flying Boom versus Hose-and-Drogue Mike Naval Aviation 26 July 11th 06 11:38 PM
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 03:55 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 07:29 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 03:04 PM
