#21
I took mine apart when the left brake stopped working (it turned out that a
wire had broken; I reconnected it and it worked fine). Hmmm. That's not exactly a ringing endorsement for their durability. With so many different people using the pedals, in my application, I wonder how long they'll last? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
"Jay Honeck" wrote in message
ups.com... I took mine apart when the left brake stopped working (it turned out that a wire had broken; I reconnected it and it worked fine). Hmmm. That's not exactly a ringing endorsement for their durability. With so many different people using the pedals, in my application, I wonder how long they'll last? I don't recall just how long I had mine before the wire broke, but it was years (and the problem was easily fixed). Not bad for a toy. --Gary |
wire had broken; I reconnected it and it worked fine). Hmmm. That's not exactly a ringing endorsement for their durability. That's an amusing statement from a Lightspeed apologist. Maybe they're working now, but in the early days when you had so much trouble with them you chafed at similar comments. Jose -- "Never trust anything that can think for itself, if you can't see where it keeps its brain." (chapter 10 of book 3 - Harry Potter). for Email, make the obvious change in the address. |
![]() Morgans wrote: "Stefan" wrote in message http://home.balcab.ch/stefan/public/Flugsimulator.jpg Man, that is ...Scary! Is that your setup? How do you link that many monitors (and computers?) to run off of one program? With "WIdeView". It lets you network as many computers as you'd like, all running MS Flight Sim, and all moving in sync. Most use it to give side images so that you can turn your head and look out the side windows of the cockpit, giving a far more realistic experience to flying a landing pattern. Someone built a sim of an airliner, with cockpit _and_ several passenger rows. They used WideView to run monitors placed outside the passenger windows, thus giving a family-flight experience ![]() http://www.wideview.it/ The other program used a lot is WideFS, which allows other computers access to MSFS variables. Grab an old cheap laptop with small screen and tie it into the net as your Garmin avionics, for example. These days, there's no reason a pilot can't use a cheap sim to pre-fly a route and ILS to a srange airport. Kev |
To solve many of your sensitivity problems and be able to add all sorts
of cool things, be sure to get the #1 FS addon: FSUIPC: http://www.schiratti.com/dowson.html Wow, what a perfect example of a poorly designed webpage. No where on the page do they bother to explain what "FSUIPC" is -- although you *can* download FSUIPC (and other flight sim stuff) from there. After a little searching, I found the answer here, on another webpage: http://simmarket.com/product_info.php?products_id=2068 Thanks for the other links, BTW. Lots of good stuff there. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
I've spent some time day-dreaming over a motion simulator. Take a look
at: http://www.acesim.com/main.html Jeff Kev wrote: Jay Honeck wrote: Until now, flying MS Flight Sim '04 using the big screen projector at the hotel has been cool, but, well, unreal. A joystick -- even a force-feedback stick, like we used -- is simply a bad compromise Yes, far better with yoke and rudder pedals with toe brakes. To solve many of your sensitivity problems and be able to add all sorts of cool things, be sure to get the #1 FS addon: FSUIPC: http://www.schiratti.com/dowson.html Next, order up your local scenery and better terrain from someone like: http://www.pcaviator.com/megascenery/ http://portal.fsgenesis.net/ I can actually follow the roads and lakes around northern NJ on the sim! Personally, I use a sim to pre-plan flights (hey, look there's a ridge ... So here comes some radio links, which should make you drool a bit: http://www.flyelite.com/hardware.php http://www.goflightinc.com/order/index.php http://sim.itra.de/default_en.htm http://www.simkits.com/ Best, Kev |
at: http://www.acesim.com/main.html Cool! A tad pricey, at $1800 (pre-built; less if you build it yourself), but cool nonetheless. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
In article .com,
"Jay Honeck" wrote: To solve many of your sensitivity problems and be able to add all sorts of cool things, be sure to get the #1 FS addon: FSUIPC: http://www.schiratti.com/dowson.html Wow, what a perfect example of a poorly designed webpage. No where on the page do they bother to explain what "FSUIPC" is -- although you *can* download FSUIPC (and other flight sim stuff) from there. After a little searching, I found the answer here, on another webpage: http://simmarket.com/product_info.php?products_id=2068 Thanks for the other links, BTW. Lots of good stuff there. and you don't even tell us... sheeesssh. -- Bob Noel Looking for a sig the lawyers will hate |
#30
Morgans schrieb:
http://home.balcab.ch/stefan/public/Flugsimulator.jpg Man, that is ...Scary! Is that your setup? No. No time nor desire to sim, because I devote my limited amount of spare time and spare money to real flying. I just pulled the picture off the net because I thought it was funny. Stefan |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
CRS: V-22 Osprey Tilt-Rotor Aircraft | Mike | Naval Aviation | 0 | August 30th 06 02:11 PM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
