![]() "Dave Butler" wrote in message ... Jay Beckman wrote: Dave, snip Could you possibly do a quick and dirty 172 Vs Warrior and why the Piper fits better? I'm not *that* Dave, but here's my q-and-d: The capabilities of the two are very closely the same. The price of Cherokees is lower due to lower demand from all the buyers who did their initial training in Cessnas. Dave Shoot, sorry... Did I mis-atribute the original post...? My Bad. Jay B |
Hehe.. sure..
At the risk of starting something... but looks like I did any way. ![]() OK.. the misssion of both aircraft is about the same, same engine, (both 150 hp) We had the 172 for 2 yrs, into our 2nd year with the Warrior..... Cessna 172,(1974) Pros - better at short field, better glide ratio (lighter wing loading), easier to assist pax getting in . High wing is an umbrella in rain. Fun to fly, less stable, probably a better trainer, spinable (miss that!!) 172 Cons, - lightly/loosely built, squeaked and groaned. Ventilation- awful , the "pop can controls" were umm... awful. Opening the window (s) worked well though.. ![]() Drafty, although ours was warmer than others we have flown... Heater.. what heater? Could never convince the rear seat pax that it had one.... Cockpit lighting seemed to be an afterthought.. The overhead red light "lens" was a poor arrangement that had to be adjusted if you changed the bulb, was sensitive to a change in filiment position.. Warrior.(1976) Pros - Tougher, stiffer, no squeaks/groans while taxing, stabilator has better authority in the flare. Seems that everywhere we looked, (we had the interiors out /replaced etc. in both planes) the piper is built stronger, stiffer, closer spacing between structural members etc. Wider landing gear stance, ....would not hesitate tackling a cross wind with the Warrior that I would be aprehensive to try in the 172. The oleos on the Warrior allow me to "plant" the Warrior down firmly in difficult winds without getting kicked back into the air. (the Cessna spring steel gear would reward me with a bounce) More comfortable cross country aircraft. More stable in the roll axis, (more dihedral) and HAS RUDDER TRIM! Cruise climb, - 3/4 turn of the knob and keep your feet on the floor. Had to keep pressure with your right foot with the 172 during climbs/decents. Good cockpit lighting. Overhead red light has a proper (glass) lens, light hits the right places. Separate controls for radio and instrument lighting. Better seat tracks/rollers.. no more needs to be said here... Smoother ride in rough air, requires less attenton to keep upright..(probably due to higher wing loading and less flat side area) Controls feel more direct, responsive - yoke tube is an inch diameter, or more, - Cessna yoke tube is 3/4 in dia... flexible by comparison. Interior is quieter, we can speak to each other with headsets off.. There is more fabric/vinyl in the Warrior interior, it absorbs some sound..(.new Airtex headliner is wool) The 172's headliner was hard plastic, in fact , most of the interior finish was hard plastic, not very sound absorbing... Faster than the 172 at same power settings (but not by much) Ventilation is great! Overhead duct with individual, controllable vents for each person, high volume floor (side) vents. And they can all be truly "shut off" (no more 200 mph tape over the vents in the winter) A real heater! Will roast you if you crank it up. Has REAL heat ducts! and rear seat pax have ducts too...(I live in Canada, we get winter here) Connection to nosewheel steering is more direct (no springs) Warrior Cons... Longer takeoff/landing distances, most difference noticed at heaver weights, less if lighter Other owners tell us that the Mattson VG's and gap seals (to be installed soon) will close this gap significantly. Ya HAFTA manage yer fuel! (no "both" setting) ![]() Stalls are not much fun, can't spin it.. (rats!) Single door... I can't help a (elderly?) pax much, I have to get in first... Oleo struts require care & maintenance. Now, having said all this, remember, the is my OPINION, based on ONE Cessna 172, and ONE Warrior. - ONLY They are both good aircraft, but for the reasons/preferences above the Warrior is my runaway choice..of the two designs. Note I have tried to stay away from the high vs low wing thingy.... ![]() I am not an aircraft design engineer, but I have looked into every cavity of both aircraft, and (God forbid) if I had to put down in the trees some night, I would sooner be in the Piper. YMMV! (Dave struggles into flame suit) ![]() Dave On Tue, 31 Oct 2006 15:55:17 -0700, "Jay Beckman" wrote: I realize much of what people value in their planes if often very personal but I don't think I've read anything comparitive between the two that was spawned from first hand experience. Could you possibly do a quick and dirty 172 Vs Warrior and why the Piper fits better? TIA, Jay Beckman PP-ASEL Chandler, AZ |
Dave wrote in
: Hey Dave, Some "fixes" to two of your cons listed below *big smile* Warrior Cons... Single door... I can't help a (elderly?) pax much, I have to get in first... Get a Sundowner. Two doors. I help the passenger in, and I close the door. I am not an aircraft design engineer, but I have looked into every cavity of both aircraft, and (God forbid) if I had to put down in the trees some night, I would sooner be in the Piper. Get a Sundowner. Built like a tank By the way, did I say get a Sundowner *big smile*. Pros Huge cabin for creature comfort. Back passengers even have leg room after seats are moved up for front passengers. Can take 4 adult passengers and full fuel. This doesn't allow for luggage! If luggage, 3 adults and luggage. Trailing link gears cushion your landings and make you look like a pro on landings. Performance like a 172 on low MANLY wings. Not nearly as pricey as a Warrior or Cessna (that I have seen with what I bought in mine) Cons EXPENSIVE when it comes to parts. Ownership = priceless Allen |
You don't need your flame suit Dave. Given all the off-topic posts and
the posts from "let's-see-how-many-posts-I-can-from-these-over-eager-pilots" known as Mxsmanic, your post is refreshing. I've never owned a Cessna so I can only agree with the second-half of your post but thanks for posting it. I don't think I've ever seen anyone bring up many of the issues you have in this newsgroup. Makes me glad I chose the -161. Marco Dave wrote: Hehe.. sure.. At the risk of starting something... but looks like I did any way. ![]() OK.. the misssion of both aircraft is about the same, same engine, (both 150 hp) We had the 172 for 2 yrs, into our 2nd year with the Warrior..... Cessna 172,(1974) Pros - better at short field, better glide ratio (lighter wing loading), easier to assist pax getting in . High wing is an umbrella in rain. Fun to fly, less stable, probably a better trainer, spinable (miss that!!) 172 Cons, - lightly/loosely built, squeaked and groaned. Ventilation- awful , the "pop can controls" were umm... awful. Opening the window (s) worked well though.. ![]() Drafty, although ours was warmer than others we have flown... Heater.. what heater? Could never convince the rear seat pax that it had one.... Cockpit lighting seemed to be an afterthought.. The overhead red light "lens" was a poor arrangement that had to be adjusted if you changed the bulb, was sensitive to a change in filiment position.. Warrior.(1976) Pros - Tougher, stiffer, no squeaks/groans while taxing, stabilator has better authority in the flare. Seems that everywhere we looked, (we had the interiors out /replaced etc. in both planes) the piper is built stronger, stiffer, closer spacing between structural members etc. Wider landing gear stance, ....would not hesitate tackling a cross wind with the Warrior that I would be aprehensive to try in the 172. The oleos on the Warrior allow me to "plant" the Warrior down firmly in difficult winds without getting kicked back into the air. (the Cessna spring steel gear would reward me with a bounce) More comfortable cross country aircraft. More stable in the roll axis, (more dihedral) and HAS RUDDER TRIM! Cruise climb, - 3/4 turn of the knob and keep your feet on the floor. Had to keep pressure with your right foot with the 172 during climbs/decents. Good cockpit lighting. Overhead red light has a proper (glass) lens, light hits the right places. Separate controls for radio and instrument lighting. Better seat tracks/rollers.. no more needs to be said here... Smoother ride in rough air, requires less attenton to keep upright..(probably due to higher wing loading and less flat side area) Controls feel more direct, responsive - yoke tube is an inch diameter, or more, - Cessna yoke tube is 3/4 in dia... flexible by comparison. Interior is quieter, we can speak to each other with headsets off.. There is more fabric/vinyl in the Warrior interior, it absorbs some sound..(.new Airtex headliner is wool) The 172's headliner was hard plastic, in fact , most of the interior finish was hard plastic, not very sound absorbing... Faster than the 172 at same power settings (but not by much) Ventilation is great! Overhead duct with individual, controllable vents for each person, high volume floor (side) vents. And they can all be truly "shut off" (no more 200 mph tape over the vents in the winter) A real heater! Will roast you if you crank it up. Has REAL heat ducts! and rear seat pax have ducts too...(I live in Canada, we get winter here) Connection to nosewheel steering is more direct (no springs) Warrior Cons... Longer takeoff/landing distances, most difference noticed at heaver weights, less if lighter Other owners tell us that the Mattson VG's and gap seals (to be installed soon) will close this gap significantly. Ya HAFTA manage yer fuel! (no "both" setting) ![]() Stalls are not much fun, can't spin it.. (rats!) Single door... I can't help a (elderly?) pax much, I have to get in first... Oleo struts require care & maintenance. Now, having said all this, remember, the is my OPINION, based on ONE Cessna 172, and ONE Warrior. - ONLY They are both good aircraft, but for the reasons/preferences above the Warrior is my runaway choice..of the two designs. Note I have tried to stay away from the high vs low wing thingy.... ![]() I am not an aircraft design engineer, but I have looked into every cavity of both aircraft, and (God forbid) if I had to put down in the trees some night, I would sooner be in the Piper. YMMV! (Dave struggles into flame suit) ![]() Dave On Tue, 31 Oct 2006 15:55:17 -0700, "Jay Beckman" wrote: I realize much of what people value in their planes if often very personal but I don't think I've read anything comparitive between the two that was spawned from first hand experience. Could you possibly do a quick and dirty 172 Vs Warrior and why the Piper fits better? TIA, Jay Beckman PP-ASEL Chandler, AZ |
Jay Beckman wrote:
I realize much of what people value in their planes if often very personal but I don't think I've read anything comparitive between the two that was spawned from first hand experience. Could you possibly do a quick and dirty 172 Vs Warrior and why the Piper fits better? 1) Best comparison be between models in the same time frame. It's not fair to compare a current 172 that's fuel injected, G1000, and so on (at $250K+ USD) with an older PA28, etc. 2) Assuming same time frame - let's define it as early-mid 70s. C172 advantages: high wing sun shade better for photos looking down 2 door access PA28 advantages 2 gal. more fuel slightly heavier more stable in crosswind slightly higher service ceiling (I live in Colorado-important!) glareshield lower - don't need as many pillows to look over manual flaps (well, I think that's an advantage) easier to fill the gas tanks & wash the windows - no need for a ladder Overall, it's really your personal religious decision. Go fly in each and see what you like/dislike. |
: 1) Best comparison be between models in the same time frame. It's
: not fair to compare a current 172 that's fuel injected, G1000, : and so on (at $250K+ USD) with an older PA28, etc. : 2) Assuming same time frame - let's define it as early-mid 70s. : C172 advantages: : high wing sun shade : better for photos looking down : 2 door access : PA28 advantages : 2 gal. more fuel : slightly heavier : more stable in crosswind : slightly higher service ceiling (I live in Colorado-important!) Even *I* don't know if I buy that. The Hershey-bar wing is pretty slug-like compared to the 172. It helps in turbulence, stall characteristics, and crosswind, but not in climb-related things. In the early-mid 70's are you talking about taper-wing? Then that might be the case (dunno... I'm only calibrated to Hershey-wing PA28's). : glareshield lower - don't need as many pillows to look over : manual flaps (well, I think that's an advantage) : easier to fill the gas tanks & wash the windows - no need for : a ladder -Cory -- ************************************************** *********************** * Cory Papenfuss, Ph.D., PPSEL-IA * * Electrical Engineering * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
In article , Blanche
wrote: as a cherokee owner and having had a hangar for a little while, any high wing aircraft has an advantage vs low wing aircarft wrt hangars. It's way easier to walk around in the hangar. -- Bob Noel Looking for a sig the lawyers will hate |
The Cherokee 140 I used to own is now again for sale. It used to be the
famous orange and white checkerboard Cherokee. It received a brand new paint, interior, and tinted windows in January of 2006. The fellow who I sold it to last year, tragically perished in the crash of another aircraft a couple months ago, and I'm assisting with the sale of the aircraft for the estate since I know a lot about this particular airplane. It's one of the sweetest flying and dependable little Cherokees in the country. I wish I was financially equipped to buy it back myself because me and my father had probably what will be our last great father-son adventure in her, but alas, I cannot afford another plane for probably at least another six more months at best. N4646R needs to find a new owner who'll cherish her as much as I did. Ad with pics at TAP: http://www.trade-a-plane.com/unprote...ecs/46996.html |
Good-bye, My Good Friend | Capt.Doug | Home Built | 2 | August 12th 05 02:47 AM |
Any good aviation clip-art? | zingzang | Piloting | 2 | August 11th 05 01:32 AM |
We lost a good one.... | [email protected] | Piloting | 10 | May 28th 05 05:21 AM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
Commander gives Navy airframe plan good review | Otis Willie | Military Aviation | 0 | July 8th 03 09:10 PM |
