Mxsmanic writes:
gatt writes: I was wondering what was absorbing the kinetic energy of the aircraft, since normally a loss of altitude requires an increase in airspeed, if nothing absorbs the energy. Drag. In a slip you are sliding sideways through the air. This means you are trying to push the side of the fuselage through the air. It is not designed to be very aerodynamic going sideways, so when you do this you will create all sorts of extra drag which the plane does not normally have. Chris |
Christopher Brian Colohan wrote: Mxsmanic writes: gatt writes: I was wondering what was absorbing the kinetic energy of the aircraft, since normally a loss of altitude requires an increase in airspeed, if nothing absorbs the energy. Drag. In a slip you are sliding sideways through the air. This means you are trying to push the side of the fuselage through the air. It is not designed to be very aerodynamic going sideways, so when you do this you will create all sorts of extra drag which the plane does not normally have. And lift! |
Christopher Brian Colohan writes:
Drag. In a slip you are sliding sideways through the air. This means you are trying to push the side of the fuselage through the air. It is not designed to be very aerodynamic going sideways, so when you do this you will create all sorts of extra drag which the plane does not normally have. That explains it. Thanks. Slips may come in handy for me since I never seem to be able to roll out to final with any reasonable alignment with the runway. I suppose in real life I could look out a side window and estimate my alignment better, but somehow I think it might still be difficult for me. The other legs work out okay; I'm flying nice rounded rectangles now (MSFS lets you analyze your ground track and altitude profiles, so you can easily check your work). -- Transpose mxsmanic and gmail to reach me by e-mail. |
![]() "Mxsmanic" wrote in message ... Three basic rules about slipping on final are 1) Don't stall, 2) Don't stall and 3) Don't stall. And how do I avoid stalls while slipping? Stay a few knots above stall speed and don't make any abrupt control changes. If you're in a high performance airplane and have to go around or something, don't throw in full power and torque yourself over. -c |
Make sure you have the flaps fully deployed when you do it....
![]() wrote in message ups.com... Make sure you have the flaps fully deployed when you do it.... ![]() Especially if it is a C-172N with the placard that says "Avoid Slips with the Flaps Extended" while on a checkride... :-) |
![]() Especially if it is a C-172N with the placard that says "Avoid Slips with the Flaps Extended" while on a checkride... :-) Interesting...the earlier models omitted the checkride reference. Fortunately, cross wind correction seemed to be permitted... :-) Peter |
![]() Mxsmanic wrote: What's the proper procedure to execute a forward slip, how should the aircraft be expected to react when it is performed, and what are the main uses of the forward slip? And why is it called a _forward_ slip? http://en.wikipedia.org/wiki/Slip_(aerodynamic) Somebody said that MSFS cannot simulate forward slips correctly. What is missing in the simulation? I've read it has something to do with its inability to calculate the lift, or perhaps just the default aircraft don't handle it. However, I believe some third party aircraft explicity address the slip issue. What's that C172 realistic addon? Drat. I've forgotten, but it's a far better 172 than the stock one. Note that, by default, MSFS is configured to link the rudder to the ailerons. All turns are forced into coordinated turns, and there's no independent rudder control. That's a major reason why simmers who don't own rudder pedals get little of the realism that the sim can sometimes offer. Kev |
![]() wrote in message ups.com... Mxsmanic wrote: What's the proper procedure to execute a forward slip, how should the aircraft be expected to react when it is performed, and what are the main uses of the forward slip? And why is it called a _forward_ slip? http://en.wikipedia.org/wiki/Slip_(aerodynamic) Somebody said that MSFS cannot simulate forward slips correctly. What is missing in the simulation? I've read it has something to do with its inability to calculate the lift, or perhaps just the default aircraft don't handle it. However, I believe some third party aircraft explicity address the slip issue. What's that C172 realistic addon? Drat. I've forgotten, but it's a far better 172 than the stock one. Note that, by default, MSFS is configured to link the rudder to the ailerons. All turns are forced into coordinated turns, and there's no independent rudder control. Not true. You can deselect "Auto Rudder" and have independant rudder control. I believe the add-on 172 you are trying to think of is this one from Flight 1: http://www.flight1.com/products.asp?product=esd172 That's a major reason why simmers who don't own rudder pedals get little of the realism that the sim can sometimes offer. Now that's a true statement. Jay B |
![]() Jay Beckman wrote: I believe the add-on 172 you are trying to think of is this one from Flight 1 http://www.flight1.com/products.asp?product=esd172 Thanks for that, but I finally recalled the one I was thinking of: the "RealAir 172SP". It can do slips and spins, and felt pretty realistic compared to the stock one. Kev |
The smell of a decomposing mouse somewhere forward of the firewall | Peter R. | Owning | 23 | February 1st 06 03:52 AM |
What is a "Forward Skip"? | Gary G | Piloting | 57 | January 7th 05 10:09 PM |
Dennis Fetters Mini 500 | EmailMe | Home Built | 70 | June 21st 04 09:36 PM |
B-17 forward guin positions | zxcv | Military Aviation | 13 | March 16th 04 12:04 AM |
Forward Swept Wings | Canuck Bob | Home Built | 16 | October 3rd 03 05:50 PM |
