The birth of a quieter, greener plane: 35% more fuel-efficient; Cambridge-MIT Institute's 'Silent' Aircraft Initiative
Old November 9th 06, 02:28 AM posted to rec.aviation.piloting
Grumman-581[_3_]
Default The birth of a quieter, greener plane: 35% more fuel-efficient; Cambridge-MIT Institute's 'Silent' Aircraft Initiative
"Bob Noel" wrote in message
The "negative" g's would probably bother people way more.
Very good point... When the drinks start coming out of the glasses and
floating towards the ceilings, people are going to notice... I suspect that
accelerations will be such that it won't interfere with drinking...
Old November 9th 06, 07:56 AM posted to rec.aviation.piloting
Peter Duniho
"Jose" wrote in message
t...
I don't usually fly in the tail of a commercial airliner. However, some
time ago I had that opportunity, and was quite surprised at the horizontal
components I was feeling during taxi on the ground. I was also amused, as
it was in the opposite direction of the turn.
Be that as it may, I don't see how that's relevant to the question at hand.
I doubt the horizontal acceleration was even close to 1g, and on top of that
most people are already accustomed to horizontal accelerations, since motor
vehicles cause those any time they turn. I'm not a fast driver, and I still
quite often turn quickly enough to cause packages loose in the trunk to
slide from one side to the other. Not that it takes a LOT of force to do
that, but it probably takes at least as much force as you experience in the
tail of the airplane.
One more time though: even though I believe that the acceleration would be
significant, I doubt people will put up much of a fight.
Pete
Old November 9th 06, 01:53 PM posted to rec.aviation.piloting
Larry Dighera
Here's a little update:
AVwebFlash Volume 12, Number 45b -- November 9, 2006
"SILENT AIRCRAFT" DEBUTS LOUDLY
(http://www.avweb.com/eletter/archive...ll.html#193664)
Plans for a quiet, energy-efficient airliner that could be flying
in less than 25 years were unveiled Monday afternoon
(http://www.cambridge-mit.org/cgi-bin...495&NewsID=368)
by researchers from Cambridge University and the Massachusetts
Institute of Technology (MIT). The design uses technology that
should be ready to fly by 2030. Besides reducing noise around
airports, the airplane would require about 25 percent less fuel.
It would use a flying-wing design, eliminate flaps and slats,
simplify the landing gear, improve its aerodynamics and mount the
engines above the fuselage to screen the noise from the ground.
Variable-size jet nozzles would allow for slower jet propulsion
during takeoff and climb for low noise, and would be optimized for
maximum efficiency during cruise.
Old November 9th 06, 04:46 PM posted to rec.aviation.piloting
Jose[_1_]
Default The birth of a quieter, greener plane: 35% more fuel-efficient;Cambridge-MIT Institute's 'Silent' Aircraft Initiative
Only anecdotally.
A more serious problem may be the slight oscillations that an ariplane
goes through staying level. At the edges, they may become strong enough
over a five hour flight to induce seasickness.
Or not. Dunno. But better to think of it before placing the order.
Jose
"Never trust anything that can think for itself, if you can't see where
it keeps its brain." (chapter 10 of book 3 - Harry Potter).
Old November 9th 06, 11:05 PM posted to rec.aviation.piloting
Morgans[_2_]
m...
Only anecdotally.
A more serious problem may be the slight oscillations that an ariplane goes
through staying level. At the edges, they may become strong enough over a
The original YB program had a problem with oscillations, making it a problem for
bombing runs. The B-2 has that problem licked, with super fast fly by wire
flight controls.
I can not see any reason that they would not be able to solve any passenger
comfort issues, with the correct subroutines applied to the flight control
computers.
I look forward to a new type of aircraft. If it is destine to come, I wish they
would get more serious about starting some scaled down aircraft testing program.
If Boeing is really serious about kicking Airbus' butt, that would be the way to
start looking. There is no way to find out, short of starting the first steps.
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 09:02 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 03:07 AM
