Removing oil galley plug
Old November 9th 06, 05:55 PM posted to rec.aviation.owning
Jim Burns[_1_]
Default Thanks... was Removing oil galley plug
Well, tonight I'll finish cleaning up the install of the wiring harnesses,
EGT, & CHT probes and tackle the oil galley plug.
I've already warned my A&P that he'll be expected to lead the way... and
he's already warned me that it might not be a pleasant path.
I'll report back with news of our adventure.
Thanks for all the great advice, I'm sure that we'll put more than a little
of it to use this evening.
Old November 10th 06, 12:25 AM posted to rec.aviation.owning
zatatime
On Thu, 9 Nov 2006 11:55:16 -0600, "Jim Burns"
Good luck Jim.
z
Old November 11th 06, 05:12 AM posted to rec.aviation.owning
Jim Burns
GOT IT!
Well, thanks to all of you for your great advice, here's how we approached
it.
Strip out 3/16" internal hex head as expected.
Fit a 3/16" EZ out into the plug and we found that it bottomed out in the
plug without gripping the sides.
Ground about 1/4" off of the EZ out so it wouldn't bottom out and fit snug.
Heat the dog **** out of the case with a propane torch and an electric heat
gun, being sure to keep the heat moving and not burning the paint.
Tapped the EZout into the plug.
The EZ out I used had a 1/2" hex head, so we used a socket and ratchet to
turn the EZ out. This helped us keep it square and apply pressure against
it, driving it into the plug. As it tightened, we removed the socket,
tapped the EZout in further, applied more heat, turned the EZ out a little
more, more tapping, more heating, more turning slightly, more tapping....
finally we "thought" that something was giving... but we didn't know if it
was the EZout or the plug, OR if the exterior portion of the plug had began
to split! nope, I swear I saw the plug turn... ever so slightly... keep
turning...
YEP! bingo! Didn't have to drill... didn't have to pull the prop and the
ring gear... whew!
Thanks again for everybody's advice.
"zatatime" wrote in message
news
little
Good luck Jim.
z
Old November 11th 06, 05:37 PM posted to rec.aviation.owning
David Lesher
"Jim Burns" writes:
GOT IT!
it.
Bravo.
[Too bad no one makes Torx head pipe plugs.]
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Old November 13th 06, 02:13 PM posted to rec.aviation.owning
Jim Burns[_1_]
In this location, I can see no reason in the world that it has to be an
internal hex plug. I think it could just as easily be an external square
headed plug.
"David Lesher" wrote in message
"Jim Burns" writes:
GOT IT!
approached
it.
Bravo.
Old November 11th 06, 07:15 PM posted to rec.aviation.owning
Kyle Boatright
"Jim Burns" wrote in message
GOT IT!
it.
snug.
heat gun, being sure to keep the heat moving and not burning the paint.
began to split! nope, I swear I saw the plug turn... ever so
slightly... keep turning...
ring gear... whew!
A follow-up question... Looking back, would it have been easier to pull the
prop and ring gear in the first place? One thing that I hate is working in
awkward and/or confined areas. That kind of thing seems to lead to stripped
heads, busted knuckles, etc.
I have a fixed pitch prop and with the cowl off, I can have the spinner,
prop, and ring gear sitting on the hangar floor in 20 minutes or less.
Old November 13th 06, 01:58 PM posted to rec.aviation.owning
Jim Burns[_1_]
I had to pull the forward metal baffle (2 screws plus 2 bolts) This gave us
approximately 4 inches of space between the plug and the back of the ring
gear. If we had a fixed pitch prop, I wouldn't have hesitated pulling it
and the ring gear, but with the adjustable prop I would have had to replace
the O ring and there's always a risk of creating an oil leak.
I've got another plug to pull when I get the other engine wired, hopefully
it will come out just as easy. We'll see.
"Kyle Boatright" wrote in message
in
stripped
Old November 11th 06, 07:43 PM posted to rec.aviation.owning
zatatime
On Fri, 10 Nov 2006 23:12:56 -0600, "Jim Burns"
GOT IT!
You must've felt like you won the lottery after it came out for you!
Glad it worked out.
z
Old November 13th 06, 02:08 PM posted to rec.aviation.owning
Jim Burns[_1_]
That's an understatement!
Friday 6:30pm My A&P and I both arrive at the hanger at the same time. I
had plans to fly down to Jay H's Saturday afternoon after work, so to meet
my self imposed deadline, everything had to be completed and buttoned up
before I left the hanger that night.
We had the plug out in under an hour. My A&P looked everything over and
gave me a thumbs up then left for another job.
By 9pm I had everything recowled, tools accounted for, and every nut, bolt,
and screw double and triple checked. Plugged in the engine heaters,
preflighted the airplane, and was home by 10pm.
Some times things just work out.
GOT IT!
Glad it worked out.
z
Fouled plug IO 470 [email protected] General Aviation 7 January 29th 06 06:03 PM
Plug fouled Denny Owning 9 September 2nd 05 05:58 AM
Plug replacements for O-360-A3A [email protected] Owning 3 August 20th 05 10:39 PM
ICOM Headset Adaptor Plug Ron Wanttaja Home Built 3 June 2nd 05 07:54 AM
Helicopter headset plug - help needed NewsGroups Home Built 4 September 8th 04 05:21 PM
