Gentle take-offs at high speed
Old November 11th 06, 06:00 AM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic
Default Gentle take-offs at high speed
Ron Wanttaja writes:
If the sim doesn't give the opportunity for a "gentle" takeoff at lower speeds,
there's something wrong with the modeling.
I'm sure it does; I'm probably just doing something wrong. I'm better
than I used to be.
Old November 11th 06, 03:45 AM posted to rec.aviation.student,rec.aviation.piloting
Friction. Think to yourself, which is going to be less draggy..
a) speeding along the ground, tyres creating friction with the ground
b) speeding along in ground effect, tyres not creating friction with
the ground
get off the ground, accellerate in ground effect to desired climb
speed, climb away and enjoy. Especially when the surface is less than
perfect.
Old November 11th 06, 03:48 PM posted to rec.aviation.student,rec.aviation.piloting
TxSrv
Mxsmanic wrote:
Staying in ground effect has been really tough for me thus far. Once
I'm in the air, the aircraft really wants to climb very badly, it
seems. If I try to hold it low enough to stay in ground effect, I
risk accidentally plowing it back down into the runway. However, I'll
try to practice this more.
Enjoy wasting your time. MSFS doesn't know ground effect. It
doesn't know the height of the wings above the ground. Couldn't
feel it anyway, nor see any screen indication it's happening.
F--
Old November 11th 06, 09:31 PM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic
TxSrv writes:
Recent versions do simulate ground effect, as I recall. I'm not sure
of the details. I know that the aircraft I fly will hover for an
unusually long time just above the ground, which sounds an awful lot
like ground effect.
Old November 12th 06, 01:36 AM posted to rec.aviation.student,rec.aviation.piloting
TxSrv
like ground effect.
Airplanes don't hover, and "I recall" isn't proof of anything.
If ground effect is modeled, you can prove with flight testing
and reporting back the numbers. How would you know you're in
ground effect in MSFS? Why would the programmers waste valuable
CPU time doing something 99% of simmers don't understand?
F--
Old November 12th 06, 11:38 AM posted to rec.aviation.student,rec.aviation.piloting
mike regish
Hover? What kind of wind? What kind of craft? Alien?
mike
"Mxsmanic" wrote in message
like ground effect.
Old November 11th 06, 04:28 PM posted to rec.aviation.student,rec.aviation.piloting
BT
that's because the take off trim setting is for a climb at power
Old November 11th 06, 02:44 PM posted to rec.aviation.student,rec.aviation.piloting
Viperdoc[_3_]
A good technique to stay in ground effect in the Baron that I fly is to push
forward on the yoke as you accelerate to between 100-120 K, and then retract
the gear. This guarantees that you will remain in ground effect.
A brisk pull back on the yoke will then establish a climb attitude.
the ground
perfect.
Old November 11th 06, 04:26 PM posted to rec.aviation.student,rec.aviation.piloting
Scott
On Sat, 11 Nov 2006 14:44:56 GMT, in rec.aviation.student, "Viperdoc"
Until the engine quits, anyway.
My gut tells me that I should't retract my gear until I have enough altitude
that, in the event of engine failure, there's enough time to extend the gear
again before landing. But I'm not a pilot yet, and I could be wrong.
-Scott
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 03:55 AM
Crosswind Landings... But airspeed? Jmarc99 Soaring 21 October 4th 05 07:54 PM
Space Elevator Big John Home Built 111 July 21st 04 04:31 PM
IVO pireps wanted.. high performance/high speed... Dave S Home Built 8 June 2nd 04 04:12 PM
High Speed Passes & the FAA (long) JJ Sinclair Soaring 17 October 15th 03 12:16 AM
