Corky's engine choice
Old July 23rd 03, 07:34 PM
Corky Scott
Default Corky's engine choice
Someone expressed surprise that I was now working on a Ford 3.8L V-6
for my engine. Last they'd heard, I was trying to find a certified
type.
I thought I'd bring everyone up to date. It's true that I had
basically given up on using an auto conversion as I was having trouble
justifying the cost of the PSRU. I'd started with a Buick/Olds 215
cid aluminum block V-8 and then switched to the Mazda 13B. I disliked
all the problems associated with the 13B so I sold that too.
I then actively searched for an aircooled aircraft engine. I mean I
really looked hard. But every single engine I looked at was really
tough to examine. I'd basically have to be an expert engine examiner
(which I wasn't) and be ready to travel all over the country to look
at it. Some had logs, most didn't. I eventually ended up with a
brand new piclkled 0-470-15. This turned out to be a military version
of the 0-470 and there was a LOT missing. I forget now what I paid
for it but it was too much and it would have cost me more than twice
that to get the thing running with all the parts missing. And
besides, it was REALLY heavy.
So I resold it.
I kept looking for a good low priced aircraft engine and just could
not find one close enough to get or I was unwilling to risk paying $7K
to $8K for someone to ship me an engine that had not been inspected.
I am an ex auto mechanic and have built several engines, but I am
totally unfamiliar with aircraft engines other than to understand from
a mechanical point of few. It's just that there is SO MUCH that can
be wrong with them and you don't know it until you've completely
dismantled them and zygloed them or x-rayed them or whatever to fully
inspect them. Then if anything is actually wrong, your bargain engine
is suddenly a financial black hole.
So I finally decided that I had to turn back to the auto coversion
again. At this point, things began to go right. Bruce Frank pointed
out why the Ford V-6 makes sense: millions of them out there, hundreds
of PSRU's and a lot of running time with a good record and it's a
light weight engine.
I found an engine salvager who was willing to ship any number of Ford
V-6's to me for $150 each. At that price, I took two, thinking that
if I found a problem part, I could just yank it from the other engine.
I also found a local machine shop who's owner had been building Fords
and just about everything else for half his life. He was willing to
take the block, crank, heads etc and clean them up and bring them to
specification. I needed all six intake valves, it turned out,
couldn't save them, they were pitted from water damage. I would have
used them in a street car but not my aircraft engine. They cost about
$16 each. The exhaust valves were fine.
At this point I found other parts suppliers. I found Morana racing in
Canada. They cater to the Ford V-6 and had all kinds of parts I
needed like new valve springs, keepers and caps. They also had roller
rockers. I bought a set of them too.
I found ARP which stands for Automobile Racing Parts. They make high
strength studs for engine assembly. They are used in a majority of
the racing world's engines. A set of studs for the cylinder heads and
main bearings cost me $145. I also bought new lifters, a new oil pump
kit and machined the intake manifold to accept the two barrel Holley
carb. Then I bought the carb and the McNeilly leaning block so the
mixture can be leaned.
All this was made possible because Bruce contacted me telling me that
he'd heard about a PSRU that was for sale at a good price. It was
less than half price.
I will be reporting the total bill for the engine and peripherals and
how things are working when I get there.
But for now, the process will be to assemble the engine and PSRU and
hang it off the firewall so I can get the rest of the airplane
finished. I already fabricated the engine mount, I used the second
block to mock that up. I also welded the Piper Tripacer landing gear
to the engine mount. That went well.
Corky Scott
Old July 24th 03, 01:17 AM
BRUCE FRANK
Uh-oh, duck!!! Here comes BOb!
Bruce A. Frank
"Corky Scott" wrote in message
type.
So I resold it.
Corky Scott
Old July 24th 03, 03:38 AM
Barnyard BOb --
Bruce A. Frank
Nah.
I'm reasonably up to date on Corky's misadventures.
FWIW --
When it comes to car engines, I will never, ever own another Ford
with a V-6 as they currently make 'em.... much less be soooo nuts
as to shoehorn such a POS into a perfectly useable airframe.
Barnyard BOb -- don't 'axe' me what I really think )
Old July 24th 03, 03:43 AM
Barnyard BOb --
Bruce A. Frank
Nah.
FWIW --
P.S.
At $150 per copy, the Ford V-6 is waaaay overpriced.
Old July 24th 03, 04:33 AM
clare @ snyder.on .ca
On Wed, 23 Jul 2003 20:43:46 -0500, Barnyard BOb --
Bruce A. Frank
Nah.
FWIW --
P.S.
Apparently it IS possible to make a silk purse out of a sow's ear -
and the 3.8 as supplied by Ford IS a sow's ear. The current crop, from
198? on is leak prone and fragile. The commonly supplied antifreeze,
when it gets into today's oil, makes short work of the factory
supplied bearings.
There are gaskets and build procedures that can make a relatively
leak-proof 3.8. Is there a combination of oil, antifreeze, and bearing
that will not result in instant death when they are combined????
For this reason I have reservations about the 3.8.
Old July 24th 03, 02:46 PM
Corky Scott
supplied bearings.
I'm well aware of the problems Ford has had with leaking cylinderhead
gaskets with this engine. That's why I bought the ARP cylinderhead
studs instead of replacement cylinderhead bolts from Ford.
Studs allow a more accurate torque setting because the only thing
turning is the nut against the washer, not the entire bolt. ARP
recommends that you use either their lubricant between the nut and
washer or oil. If you use their lubricant, the torque value is a LOT
less than if you use oil. In addition, you get to use all the threads
available to hold the stud in: you thread it down till it bottoms.
The nice thing about having a cast steel block is you don't have to
worry about stripping the threads out of the block.
ARP also recommends that you install "throw away" head gaskets for the
first torque of the cylinderhead, then fire up the engine, bring it to
temperature and then shut it down and let it cool to room temperature.
Once it's completely cooled, remove the heads, replace the head
gaskets with new, reinstall the heads, retorque and you're good to go
for the rest of the life of the engine.
What this does, they said, is get the studs initially stretched, after
which they will hold constant pressure.
They were suggesting I use the old head gaskets for the initial
startup as it really didn't matter what you used. Cardboard would
work (they said) since you are just running it to temperature then
shutting it down again. Of course, I did not save the original
gaskets when I dismantled the two engines so I'll have to buy an extra
two.
Just another one of those tricks to remember when building engines.
I'm sure Lycoming and Continental engine rebuilders have their own
tricks.
By the way, the block was decked to true the surface, and the
cylinderheads were planed. I know that at least initially, I'll have
two flat surfaces to mate together.
The great majority of the Ford auto conversions have run reliably IF
(the big IF) the builder followed the conversion manual and
information that has accumulated.
Corky Scott
Old July 24th 03, 07:51 PM
baltobernie
clare @ snyder.on .ca wrote in message
Bruce A. Frank
Nah.
FWIW --
P.S.
supplied bearings.
1988 Sable
1993 Thunderbird
nearly half a million miles between them using petroleum engine oil changed
@ 5k
zero reliability and maintenance issues
just one man's experience; YMMV
baltobernie
Old July 24th 03, 05:39 AM
Ben Haas
Hey Corky, can ya email me the dimension from the pad of your Holley
where it mounts on the intake manifold to the top of the carb. If ya
want send it straight to my email address and I will send you some
pics of the all aluminum beast..
Ben Haas N801BH..
(Corky Scott) wrote in message ...
type.
So I resold it.
Corky Scott
Old July 25th 03, 03:56 AM
Jay
Hey Corky,
What was your beef with the 13B? I have to replace a car coming off
lease in the next few months and I'm seriously looking at older RX-7s
just to get a flavor for the power plant.
I like the idea of a no-seize failure mode and the idea of it being 2
co-axial engines in one. The higher fuel burn I can deal with,
especially since its mogas.
Regards
Old July 25th 03, 08:09 AM
BRUCE FRANK
There is nothing wrong with the Mazda engine. All of the earlier problems
have been dealt with effectively and you are likely to see more and more
installations as the word gets out that the Mazda DOESN'T use excessive fuel
or burn up properly designed exhaust systems. But it is loud and most
builders seem to eventually opt for a muffler of some kind. Pound for pound
here is no higher horse power output in a normally aspirated auto conversion
than that of the Mazda Wankel.
Bruce A. Frank, Editor "Ford 3.8/4.2L Engine and V-6 STOL
Homebuilt Aircraft Newsletter"
| Publishing interesting material
| on all aspects of alternative
| engines and homebuilt aircraft.
"Jay" wrote in message
om...
Hey Corky,
Regards
Engine weights Salem Farm & Garden Home Built 5 July 22nd 03 05:27 AM
Gasflow of VW engine Veeduber Home Built 4 July 14th 03 09:06 AM
Continental A65 engine Philippe Vessaire Home Built 0 July 10th 03 06:49 PM
mercedes engine Joa Home Built 1 July 8th 03 01:26 PM
Homebuilt Aircraft Frequently-Asked Questions (FAQ) Ron Wanttaja Home Built 0 July 4th 03 05:50 PM
