Setting altimeters with no radio
Old November 12th 06, 10:11 PM posted to rec.aviation.piloting,rec.aviation.student
Robert Chambers
Default Setting altimeters with no radio
How about doing a touch and go at an airport with a known altitude,
while you are retracting flaps, quick twist of the dial to set field
elevation and away you go.
(this was a joke by the way, much as the original question)
Neil Gould wrote:
Recently, Mxsmanic posted:
"Jim Macklin" writes:
GPS, even a $100 hikers model will solve the problem. But I
just say, look at the ground, you can judge 1,000 feet
pretty well and you only need to apply the hemisphere rule
above 3,000 AGL.
GPS is far less accurate than an altimeter, and I don't think the
regulations say "if you have no radio, use GPS."
I'm not sure why you think that "GPS is far less accurate than an
altimiter...", as an altimeter only need be accurate to 75' to be legal.
GPS can do much better than that, and are unaffected by barometric
pressure; the result is a potential source of problems that require pilots
to fly by the altimeter, not the GPS. None of this has anything to do
with regulations, of course.
To answer your original question, the prudent pilot will take the
barometric pressure of their destination into consideration during
preflight planning, and adjust the altimeter accordingly. Most of the
time, the pressure won't change all that drastically at the destination in
the time it takes to fly 100 miles, and non-radio VFR pilots aren't likely
to fly in weather where the pressure is changing too rapidly.
Neil
Old November 13th 06, 05:12 AM posted to rec.aviation.piloting,rec.aviation.student
Travis Marlatte
"Mxsmanic" wrote in message
above 3,000 AGL.
The regs don't say a lot of things. You asked the question. Besides the OT
debate, you got two basic responses 1) It doesn't matter 'cause you're VFR
anyway and 2) any old GPS could give you an altitude to use a reference in
the case where the local pressure was significantly different from the
departure.
Travis
Lake N3094P
PWK
Old November 12th 06, 04:11 AM posted to rec.aviation.piloting,rec.aviation.student
BT
you land every 100 miles or less
reset your altimeter to field elevation
and then fly another 100 miles
Since it is possible to fly without voice radio equipment, and given
that (if I understand correctly) pilots are supposed to have their
altimeters set correctly to a reference located not more than 100
miles from their position, how does an aircraft without a radio keep
its altimeter properly set as it travels?
Old November 12th 06, 05:13 AM posted to rec.aviation.piloting,rec.aviation.student
Jim Logajan
I presume you're trying to pull his leg?
Old November 12th 06, 05:30 AM posted to rec.aviation.piloting,rec.aviation.student
BT
he's flying a friggin sim..
"Jim Logajan" wrote in message
Old November 12th 06, 07:20 PM posted to rec.aviation.piloting,rec.aviation.student
Jim Logajan
This forum is open to everyone, clued and clueless, sane and insane, so
it's impossible to tell by the absurdity of a post whether it is being
posted in jest or is sincerely believed by the poster. Hence my question.
Old November 12th 06, 04:35 AM posted to rec.aviation.piloting,rec.aviation.student
Doug[_1_]
There is no 100 mile rule, IFR or VFR. There is a rule that IFR you
have to have a radio, and an adjustable altimeter (and a bunch of other
stuff).
Like the guy said. Land and set the altimeter to the field elevation.
Old November 12th 06, 05:15 AM posted to rec.aviation.piloting,rec.aviation.student
Jim Logajan
You can find the answer in FAR 91.121(a)(iii).
Old November 12th 06, 09:59 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Jim Logajan writes:
Found it, thanks. I'm surprised that just setting it at the airport
would suffice--one could conceivably fly for hundreds of miles VFR,
and the altimeter could change significantly along the way.
Old November 12th 06, 11:32 AM posted to rec.aviation.piloting,rec.aviation.student
Neil Gould
Jim Logajan writes:
That really isn't as likely as you think, as the flights you're referring
to only takes a couple of hours. If the pressure is changing significantly
faster than that, it's likely to look pretty ugly outside either before
you leave or en-route.
Neil
I Hate Radios Ron Wanttaja Home Built 9 June 6th 05 05:39 PM
(sorta OT) Free Ham Radio Course RST Engineering Piloting 43 January 24th 05 08:05 PM
1944 Aerial War Comes to Life in Radio Play Otis Willie Military Aviation 0 March 25th 04 10:57 PM
Ham Radio In The Airplane Cy Galley Owning 23 July 8th 03 03:30 AM
