VFR position reporting
Old November 20th 06, 12:30 PM posted to rec.aviation.piloting,rec.aviation.student
Neil Gould
Default VFR position reporting
Recently, Mxsmanic posted:
I'm still not clear on the exact procedure for position reports if you
are flying VFR over long distances without flight following. To whom
do you report your position, and what information should it include?
Which positions do you report and how often?
Why don't you just take a ground school course? It can be less expensive
than an intro flight, though not nearly as much fun, but it would answer
many of this type of question for you. You could even start arguing with
the instructor about what s/he doesn't know about aviation and get a real
interactive response.
As to this particular primitive question: there is no need to report your
position to anyone unless you are experiencing some problem, regardless of
whether you have flight following. This should be obvious, and easy to
understand by asking yourself, "Who would care to know this information?"
Neil
Old November 20th 06, 01:48 PM posted to rec.aviation.piloting,rec.aviation.student
Steve Foley
"Neil Gould" wrote in message news:Odh8h.27713
The only time I've done position reporting is flying the Hudson River VFR
corridor.
Old November 20th 06, 02:12 PM posted to rec.aviation.piloting,rec.aviation.student
Jim Macklin
Position reports are made to FSS radio, the same place VFR
flight plans are filed. The purpose is to reduce the size
of the area search and rescue would have to search should
you become lost or overdue.
If a VFR flight plan is filed and opened, for a 4 hour, 650
mile flight and you have made position reports, S&R will be
much faster to find you.
It is pretty simple... "Wichita Radio, Piper 12345 with a
position report on 122.2"
When they answer they will probably say. Piper 12345 go
ahead.
You say "Piper 12345 VFR from Ardmore to Lincoln, present
position over Hutchinson, 6500, at 1835, eta Lincoln revised
2130 hours, please advise Lincoln." You can add all kinds
of reports known as PIREPS and you can also request updates
on weather, NOTAMS and TFR.
From the AIM...
5-1-1. Preflight Preparation
a. Every pilot is urged to receive a preflight
briefing and to file a flight plan. This briefing should
consist of the latest or most current weather, airport, and
en route NAVAID information. Briefing service may be
obtained from an FSS either by telephone or interphone, by
radio when airborne, or by a personal visit to the station.
Pilots with a current medical certificate in the 48
contiguous States may access toll-free the Direct User
Access Terminal System (DUATS) through a personal computer.
DUATS will provide alpha-numeric preflight weather data and
allow pilots to file domestic VFR or IFR flight plans.
REFERENCE-
AIM, FAA Weather Services, Paragraph 7-1-2, lists
DUATS vendors.
NOTE-
Pilots filing flight plans via "fast file" who desire
to have their briefing recorded, should include a statement
at the end of the recording as to the source of their
weather briefing.
b. The information required by the FAA to process
flight plans is contained on FAA Form 7233-1, Flight Plan.
The forms are available at all flight service stations.
Additional copies will be provided on request.
REFERENCE-
AIM, Flight Plan- VFR Flights, Paragraph 5-1-4.
AIM, Flight Plan- IFR Flights, Paragraph 5-1-8.
c. Consult an FSS or a Weather Service Office (WSO)
for preflight weather briefing. Supplemental Weather Service
Locations (SWSLs) do not provide weather briefings.
d. FSSs are required to advise of pertinent NOTAMs if
a standard briefing is requested, but if they are
overlooked, don't hesitate to remind the specialist that you
have not received NOTAM information.
NOTE-
NOTAMs which are known in sufficient time for
publication and are of 7 days duration or longer are
normally incorporated into the Notices to Airmen Publication
and carried there until cancellation time. FDC NOTAMs, which
apply to instrument flight procedures, are also included in
the Notices to Airmen Publication up to and including the
number indicated in the FDC NOTAM legend. Printed NOTAMs are
not provided during a briefing unless specifically requested
by the pilot since the FSS specialist has no way of knowing
whether the pilot has already checked the Notices to Airmen
Publication prior to calling. Remember to ask for NOTAMs in
the Notices to Airmen Publication. This information is not
normally furnished during your briefing.
REFERENCE-
AIM, Notice to Airmen (NOTAM) System, Paragraph 5-1-3.
e. Pilots are urged to use only the latest issue of
aeronautical charts in planning and conducting flight
operations. Aeronautical charts are revised and reissued on
a regular scheduled basis to ensure that depicted data are
current and reliable. In the conterminous U.S., Sectional
Charts are updated every 6 months, IFR En Route Charts every
56 days, and amendments to civil IFR Approach Charts are
accomplished on a 56-day cycle with a change notice volume
issued on the 28-day midcycle. Charts that have been
superseded by those of a more recent date may contain
obsolete or incomplete flight information.
REFERENCE-
AIM, General Description of Each Chart Series,
Paragraph 9-1-4.
f. When requesting a preflight briefing, identify
yourself as a pilot and provide the following:
1. Type of flight planned; e.g., VFR or IFR.
2. Aircraft's number or pilot's name.
3. Aircraft type.
4. Departure Airport.
5. Route of flight.
6. Destination.
7. Flight altitude(s).
8. ETD and ETE.
g. Prior to conducting a briefing, briefers are
required to have the background information listed above so
that they may tailor the briefing to the needs of the
proposed flight. The objective is to communicate a "picture"
of meteorological and aeronautical information necessary for
the conduct of a safe and efficient flight. Briefers use all
available weather and aeronautical information to summarize
data applicable to the proposed flight. They do not read
weather reports and forecasts verbatim unless specifically
requested by the pilot. FSS briefers do not provide FDC
NOTAM information for special instrument approach procedures
unless specifically asked. Pilots authorized by the FAA to
use special instrument approach procedures must specifically
request FDC NOTAM information for these procedures. Pilots
who receive the information electronically will receive
NOTAMs for special IAPs automatically.
REFERENCE-
AIM, Preflight Briefings, Paragraph 7-1-4, contains
those items of a weather briefing that should be expected or
requested.
h. FAA by 14 CFR Part 93, Subpart K, has designated
High Density Traffic Airports (HDTAs) and has prescribed air
traffic rules and requirements for operating aircraft
(excluding helicopter operations) to and from these
airports.
REFERENCE-
Airport/Facility Directory, Special Notices Section.
AIM, Airport Reservation Operations and Special
Traffic Management Programs, Paragraph 4-1-21.
i. In addition to the filing of a flight plan, if the
flight will traverse or land in one or more foreign
countries, it is particularly important that pilots leave a
complete itinerary with someone directly concerned and keep
that person advised of the flight's progress. If serious
doubt arises as to the safety of the flight, that person
should first contact the FSS.
REFERENCE-
AIM, Flights Outside the U.S. and U.S. Territories,
Paragraph 5-1-10.
j. Pilots operating under provisions of 14 CFR Part
135 and not having an FAA assigned 3-letter designator, are
urged to prefix the normal registration (N) number with the
letter "T" on flight plan filing; e.g., TN1234B.
REFERENCE-
AIM, Aircraft Call Signs, Paragraph 4-2-4.
5-1-2. Follow IFR Procedures Even When Operating VFR
a. To maintain IFR proficiency, pilots are urged to
practice IFR procedures whenever possible, even when
operating VFR. Some suggested practices include:
1. Obtain a complete preflight and weather briefing.
Check the NOTAMs.
2. File a flight plan. This is an excellent low cost
insurance policy. The cost is the time it takes to fill it
out. The insurance includes the knowledge that someone will
be looking for you if you become overdue at your
destination.
3. Use current charts.
4. Use the navigation aids. Practice maintaining a
good course-keep the needle centered.
5. Maintain a constant altitude which is appropriate
for the direction of flight.
6. Estimate en route position times.
7. Make accurate and frequent position reports to the
FSSs along your route of flight.
b. Simulated IFR flight is recommended (under the
hood); however, pilots are cautioned to review and adhere to
the requirements specified in 14 CFR Section 91.109 before
and during such flight.
c. When flying VFR at night, in addition to the
altitude appropriate for the direction of flight, pilots
should maintain an altitude which is at or above the minimum
en route altitude as shown on charts. This is especially
true in mountainous terrain, where there is usually very
little ground reference. Do not depend on your eyes alone to
avoid rising unlighted terrain, or even lighted obstructions
such as TV towers.
5-1-3. Notice to Airmen (NOTAM) System
a. Time-critical aeronautical information which is of
either a temporary nature or not sufficiently known in
advance to permit publication on aeronautical charts or in
other operational publications receives immediate
dissemination via the National NOTAM System.
NOTE-
1. NOTAM information is that aeronautical information
that could affect a pilot's decision to make a flight. It
includes such information as airport or primary runway
closures, changes in the status of navigational aids, ILSs,
radar service availability, and other information essential
to planned en route, terminal, or landing operations.
2. NOTAM information is transmitted using standard
contractions to reduce transmission time. See TBL 5-1-1 for
a listing of the most commonly used contractions.
b. NOTAM information is classified into three
categories. These are NOTAM (D) or distant, NOTAM (L) or
local, and Flight Data Center (FDC) NOTAMs.
1. NOTAM (D) information is disseminated for all
navigational facilities that are part of the National
Airspace System (NAS), all public use airports, seaplane
bases, and heliports listed in the Airport/ Facility
Directory (A/FD). The complete file of all NOTAM (D)
information is maintained in a computer database at the
Weather Message Switching Center (WMSC), located in Atlanta,
Georgia. This category of information is distributed
automatically via Service A telecommunications system. Air
traffic facilities, primarily FSSs, with Service A
capability have access to the entire WMSC database of
NOTAMs. These NOTAMs remain available via Service A for the
duration of their validity or until published. Once
published, the NOTAM data is deleted from the system.
2. NOTAM (L)
(a) NOTAM (L) information includes such data as
taxiway closures, personnel and equipment near or crossing
runways, and airport lighting aids that do not affect
instrument approach criteria, such as VASI.
(b) NOTAM (L) information is distributed locally only
and is not attached to the hourly weather reports. A
separate file of local NOTAMs is maintained at each FSS for
facilities in their area only. NOTAM (L) information for
other FSS areas must be specifically requested directly from
the FSS that has responsibility for the airport concerned.
3. FDC NOTAMs
(a) On those occasions when it becomes necessary to
disseminate information which is regulatory in nature, the
National Flight Data Center (NFDC), in Washington, DC, will
issue an FDC NOTAM. FDC NOTAMs contain such things as
amendments to published IAPs and other current aeronautical
charts. They are also used to advertise temporary flight
restrictions caused by such things as natural disasters or
large-scale public events that may generate a congestion of
air traffic over a site.
(b) FDC NOTAMs are transmitted via Service A only once
and are kept on file at the FSS until published or canceled.
FSSs are responsible for maintaining a file of current,
unpublished FDC NOTAMs concerning conditions within 400
miles of their facilities. FDC information concerning
conditions that are more than 400 miles from the FSS, or
that is already published, is given to a pilot only on
request.
NOTE-
1. DUATS vendors will provide FDC NOTAMs only upon
site-specific requests using a location identifier.
2. NOTAM data may not always be current due to the
changeable nature of national airspace system components,
delays inherent in processing information, and occasional
temporary outages of the U.S. NOTAM system. While en route,
pilots should contact FSSs and obtain updated information
for their route of flight and destination.
c. An integral part of the NOTAM System is the Notices
to Airmen Publication (NTAP) published every four weeks.
Data is included in this publication to reduce congestion on
the telecommunications circuits and, therefore, is not
available via Service A. Once published, the information is
not provided during pilot weather briefings unless
specifically requested by the pilot. This publication
contains two sections.
1. The first section consists of notices that meet the
criteria for NOTAM (D) and are expected to remain in effect
for an extended period and FDC NOTAMs that are current at
the time of publication. Occasionally, some NOTAM (L) and
other unique information is included in this section when it
will contribute to flight safety.
2. The second section contains special notices that
are either too long or concern a wide or unspecified
geographic area and are not suitable for inclusion in the
first section. The content of these notices vary widely and
there are no specific criteria for their inclusion, other
than their enhancement of flight safety.
3. The number of the last FDC NOTAM included in the
publication is noted on the first page to aid the user in
updating the listing with any FDC NOTAMs which may have been
issued between the cut-off date and the date the publication
is received. All information contained will be carried until
the information expires, is canceled, or in the case of
permanent conditions, is published in other publications,
such as the A/FD.
4. All new notices entered, excluding FDC NOTAMs, will
be published only if the information is expected to remain
in effect for at least 7 days after the effective date of
the publication.
d. NOTAM information is not available from a
Supplemental Weather Service Locations (SWSL).
TBL 5-1-1
NOTAM CONTRACTIONS
A
AADC
Approach and Departure Control
ABV
Above
A/C
Approach Control
ACCUM
Accumulate
ACFT
Aircraft
ACR
Air Carrier
ACTV/ACTVT
Active/Activate
ADF
Automatic Direction Finder
ADJ
Adjacent
ADZ/ADZD
Advise/Advised
AFD
AFSS
Automated Flight Service Station
ALS
Approach Light System
ALTM
Altimeter
ALTN/ALTNLY
Alternate/Alternately
ALSTG
Altimeter Setting
AMDT
Amendment
APCH
Approach
APL
Airport Lights
ARFF
Aircraft Rescue & Fire Fighting
ARPT
Airport
ARSR
Air Route Surveillance Radar
ASDE
Airport Surface Detection Equipment
ASOS
Automated Surface Observing System
ASPH
Asphalt
ASR
Airport Surveillance Radar
ATC
Air Traffic Control
ATCT
Airport Traffic Control Tower
ATIS
Automated Terminal Information Service
AVBL
Available
AWOS
Automatic Weather Observing System
AZM
Azimuth
B
BC
Back Course
BCN
Beacon
BERM
Snowbank/s Containing Earth/Gravel
BLO
Below
BND
Bound
BRAF
Braking Action Fair
BRAG
Braking Action Good
BRAN
Braking Action Nil
BRAP
Braking Action Poor
BYD
Beyond
C
CAAS
Class A Airspace
CAT
Category
CBAS
Class B Airspace
CBSA
Class B Surface Area
CCAS
Class C Airspace
CCLKWS
Counterclockwise
CCSA
Class C Surface Area
CD
Clearance Delivery
CDAS
Class D Airspace
CDSA
Class D Surface Area
CEAS
Class E Airspace
CESA
Class E Surface Area
CFA
Controlled Firing Area
CGAS
Class G Airspace
CHG
Change
CLKWS
Clockwise
CLNC
Clearance
CLSD
Closed
CMSN/CMSND
Commission/Commissioned
CNCL/CNCLD/CNL
Cancel/Canceled/Cancel
CNTRLN
Centerline
CONC
Concrete
CONT
Continue/Continuously
CRS
Course
CTAF
Common Traffic Advisory Frequency
CTLZ
Control Zone
D
DALGT
Daylight
DCMS/DCMSND
Decommission/Decommissioned
DCT
Direct
DEP
Depart/Departure
DEPT
Department
DH
Decision Height
DISABLD
Disabled
DLA/DLAD
Delay/Delayed
DLT/DLTD
Delete/Deleted
DLY
Daily
DME
Distance Measuring Equipment
DMSTN
Demonstration
DP
Instrument Departure Procedure
DPCR
Departure Procedure
DRCT
Direct
DRFT/DRFTD
Drift/Drifted Snowbank/s Caused By Wind Action
DSPLCD
Displaced
DSTC
Distance
DWPNT
Dew Point
E
E
East
EBND
Eastbound
EFAS
En Route Flight Advisory Service
EFF
Effective
ELEV
Elevate/Elevation
ENG
Engine
ENTR
Entire
EXCP
Except
F
FA
Final Approach
FAC
Facility
FAF
Final Approach Fix
FDC
Flight Data Center
FM
Fan Marker
FREQ
Frequency
FRH
Fly Runway Heading
FRZN
Frozen
FRNZ SLR
Frozen Slush on Runway/s
FSS
G
GC
Ground Control
GCA
Ground Controlled Approach
GOVT
Government
GP
Glide Path
GPS
Global Positioning System
GRVL
Gravel
GS
Glide Slope
H
HAA
Height Above Airport
HAT
Height Above Touchdown
HAZ
Hazard
HEL
Helicopter
HELI
Heliport
HF
High Frequency
HIRL
High Intensity Runway Lights
HIWAS
Hazardous Inflight Weather Advisory Service
HOL
Holiday
HP
Holding Pattern
I
IAP
Instrument Approach Procedure
IBND
Inbound
ID
Identification
IDENT
Identify/Identifier/Identification
IFR
Instrument Flight Rules
ILS
Instrument Landing System
IM
Inner Marker
IN
Inch/Inches
INDEFLY
Indefinitely
INOP
Inoperative
INST
Instrument
INT
Intersection
INTST
Intensity
IR
Ice On Runway/s
L
L
Left
LAA
Local Airport Advisory
LAT
Latitude
LAWRS
Limited Aviation Weather Reporting Station
LB
Pound/Pounds
LC
Local Control
LCL
Local
LCTD
Located
LDA
Localizer Type Directional Aid
LDIN
Lead In Lighting System
LGT/LGTD/LGTS
Light/Lighted/Lights
LIRL
Low Intensity Runway Edge Lights
LLWAS
Low Level Wind Shear Alert System
LMM
Compass Locator at ILS Middle Marker
LNDG
Landing
LOC
Localizer
LOM
Compass Locator at ILS Outer Marker
LONG
Longitude
LRN
LORAN
LSR
Loose Snow on Runway/s
LT
Left Turn After Take-off
M
MALS
Medium Intensity Approach Lighting System
MALSF
Medium Intensity Approach Lighting System with
Sequenced Flashers
MALSR
Runway Alignment Indicator Lights
MAP
Missed Approach Point
MCA
Minimum Crossing Altitude
MDA
Minimum Descent Altitude
MEA
Minimum En Route Altitude
MED
Medium
MIN
Minute
MIRL
Medium Intensity Runway Edge Lights
MLS
Microwave Landing System
MM
Middle Marker
MNM
Minimum
MOCA
Minimum Obstruction Clearance Altitude
MONTR
Monitor
MSA
Minimum Safe Altitude/Minimum Sector Altitude
MSAW
Minimum Safe Altitude Warning
MSL
Mean Sea Level
MU
Designate a Friction Value Representing Runway
Surface Conditions
MUD
Mud
MUNI
Municipal
N
N
North
NA
Not Authorized
NBND
Northbound
NDB
Nondirectional Radio Beacon
NE
Northeast
NGT
Night
NM
Nautical Mile/s
NMR
Nautical Mile Radius
NOPT
No Procedure Turn Required
NTAP
Notice To Airmen Publication
NW
Northwest
O
OBSC
Obscured
OBSTN
Obstruction
OM
Outer Marker
OPER
Operate
OPN
Operation
ORIG
Original
OTS
Out of Service
OVR
Over
P
PAEW
Personnel and Equipment Working
PAJA
Parachute Jumping Activities
PAPI
Precision Approach Path Indicator
PAR
Precision Approach Radar
PARL
Parallel
PAT
Pattern
PCL
Pilot Controlled Lighting
PERM/PERMLY
Permanent/Permanently
PLA
Practice Low Approach
PLW
Plow/Plowed
PN
Prior Notice Required
PPR
Prior Permission Required
PREV
Previous
PRIRA
Primary Radar
PROC
Procedure
PROP
Propeller
PSGR
Passenger/s
PSR
Packed Snow on Runway/s
PT/PTN
Procedure Turn
PVT
Private
R
RAIL
RCAG
Remote Communication Air/Ground Facility
RCL
Runway Centerline
RCLS
Runway Centerline Light System
RCO
Remote Communication Outlet
RCV/RCVR
Receive/Receiver
REF
Reference
REIL
Runway End Identifier Lights
RELCTD
Relocated
RMDR
Remainder
RNAV
Area Navigation
RPRT
Report
RQRD
Required
RRL
Runway Remaining Lights
RSVN
Reservation
RT
Right Turn after Take-off
RTE
Route
RTR
Remote Transmitter/Receiver
RTS
Return to Service
RUF
Rough
RVR
Runway Visual Range
RVRM
RVR Midpoint
RVRR
RVR Rollout
RVRT
RVR Touchdown
RVV
Runway Visibility Value
RY/RWY
Runway
S
S
South
SBND
Southbound
SDF
Simplified Directional Facility
SE
Southeast
SECRA
Secondary Radar
SFL
Sequenced Flashing Lights
SI
Straight-In Approach
SIR
Packed or Compacted Snow and Ice on Runway/s
SKED
Scheduled
SLR
Slush on Runway/s
SNBNK
Snowbank/s Caused by Plowing
SND
Sand/Sanded
SNGL
Single
SNW
Snow
SPD
Speed
SR
Sunrise
SS
Sunset
SSALF
Simplified Short Approach Lighting System with
Sequenced Flashers
SSALR
SSALS
STAR
Standard Terminal Arrival
SVC
Service
SW
Southwest
SWEPT
Swept or Broom/Broomed
T
TACAN
Tactical Air Navigational Aid
TDZ/TDZL
Touchdown Zone/Touchdown Zone Lights
TFC
Traffic
TFR
Temporary Flight Restriction
TGL
Touch and Go Landings
THN
Thin
THR
Threshold
THRU
Through
TIL
Until
TKOF
Takeoff
TMPRY
Temporary
TRML
Terminal
TRNG
Training
TRSA
Terminal Radar Service Area
TRSN
Transition
TSNT
Transient
TWEB
Transcribed Weather Broadcast
TWR
Tower
TWY
Taxiway
U
UNAVBL
Unavailable
UNLGTD
Unlighted
UNMKD
Unmarked
UNMON
Unmonitored
UNRELBL
Unreliable
UNUSBL
Unusable
V
VASI
Visual Approach Slope Indicator
VDP
Visual Descent Point
VFR
Visual Flight Rules
VIA
By Way Of
VICE
Instead/Versus
VIS/VSBY
Visibility
VMC
Visual Meteorological Conditions
VOL
Volume
VOLMET
Meteorlogical Information for Aircraft in Flight
VOR
VHF Omni-Directional Radio Range
VORTAC
VOR and TACAN (collocated)
VOT
VOR Test Signal
W
W
West
WBND
Westbound
WEA/WX
Weather
WI
Within
WKDAYS
Monday through Friday
WKEND
Saturday and Sunday
WND
Wind
WP
Waypoint
WSR
Wet Snow on Runway/s
WTR
Water on Runway/s
WX
Weather
And
In Addition/Also
5-1-4. Flight Plan - VFR Flights
a. Except for operations in or penetrating a Coastal
or Domestic ADIZ or DEWIZ a flight plan is not required for
VFR flight.
REFERENCE-
AIM, National Security, Paragraph 5-6-1.
b. It is strongly recommended that a flight plan (for
a VFR flight) be filed with an FAA FSS. This will ensure
that you receive VFR Search and Rescue Protection.
REFERENCE-
AIM, Search and Rescue, Paragraph 6-2-7 gives the
proper method of filing a VFR flight plan.
c. To obtain maximum benefits from the flight plan
program, flight plans should be filed directly with the
nearest FSS. For your convenience, FSSs provide aeronautical
and meteorological briefings while accepting flight plans.
Radio may be used to file if no other means are available.
NOTE-
Some states operate aeronautical communications
facilities which will accept and forward flight plans to the
FSS for further handling.
d. When a "stopover" flight is anticipated, it is
recommended that a separate flight plan be filed for each
"leg" when the stop is expected to be more than 1 hour
duration.
e. Pilots are encouraged to give their departure times
directly to the FSS serving the departure airport or as
otherwise indicated by the FSS when the flight plan is
filed. This will ensure more efficient flight plan service
and permit the FSS to advise you of significant changes in
aeronautical facilities or meteorological conditions. When a
VFR flight plan is filed, it will be held by the FSS until 1
hour after the proposed departure time unless:
1. The actual departure time is received.
2. A revised proposed departure time is received.
3. At a time of filing, the FSS is informed that the
proposed departure time will be met, but actual time cannot
be given because of inadequate communications (assumed
departures).
f. On pilot's request, at a location having an active
tower, the aircraft identification will be forwarded by the
tower to the FSS for reporting the actual departure time.
This procedure should be avoided at busy airports.
g. Although position reports are not required for VFR
flight plans, periodic reports to FAA FSSs along the route
are good practice. Such contacts permit significant
information to be passed to the transiting aircraft and also
serve to check the progress of the flight should it be
necessary for any reason to locate the aircraft.
EXAMPLE-
1. Bonanza 314K, over Kingfisher at (time), VFR flight
plan, Tulsa to Amarillo.
2. Cherokee 5133J, over Oklahoma City at (time),
Shreveport to Denver, no flight plan.
h. Pilots not operating on an IFR flight plan and when
in level cruising flight, are cautioned to conform with VFR
cruising altitudes appropriate to the direction of flight.
i. When filing VFR flight plans, indicate aircraft
equipment capabilities by appending the appropriate suffix
to aircraft type in the same manner as that prescribed for
IFR flight.
REFERENCE-
j. Under some circumstances, ATC computer tapes can be
useful in constructing the radar history of a downed or
crashed aircraft. In each case, knowledge of the aircraft's
transponder equipment is necessary in determining whether or
not such computer tapes might prove effective.
If playing a game in a PC sim, a position report of,
VFR Cape Kennedy to the Moon with two lunatics aboard is
appropriate.
"Steve Foley" wrote in message
news:mmi8h.764$ki3.434@trndny01...
news:Odh8h.27713
need to report your
this information?"
Hudson River VFR
| corridor.
Old November 20th 06, 02:49 PM posted to rec.aviation.piloting,rec.aviation.student
Steve Foley
"Jim Macklin" wrote in message
Is FSS radio now Lockheed-Martin? Has the wait time increased as much as
800-WX-BRIEF?
Old November 20th 06, 03:47 PM posted to rec.aviation.piloting,rec.aviation.student
Andrew Gideon
800-WX-BRIEF?
Dunno. Here in NJ, a lot of the VORs are still "broken" (ie. no voice)
due to the sudden closing of Millville. It makes me wonder how they have,
or will have, handled other FSS closings.
How much time should it take to redirect these "circuits" (whatever form
they take) from the old Millville FSS to whomever would own the VORs
(Williamssomething?)?
I do know that calling for NOTAMs is a joke. We get someone
(Williamssomething) that doesn't "officially" receive the local NOTAMs).
They get a FAX each morning from the FSS that does get them.
It's actually very strange, and I don't pretend to understand it. The FSS
specialists to whom I've spoken about it don't either.
- Andrew
Old November 20th 06, 04:35 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Neil Gould writes:
It would be in French, and I don't want to learn about French
aviation. It would be expensive, and I have no money for such things.
It would be very time-consuming, and I don't have enough time for
that. And it would probably be at an airport somewhere, for which I
have no transportation.
I read books when I can afford them, and I visit Web sites.
It can be less expensive than an intro flight, though not
nearly as much fun, but it would answer many of this type of
question for you.
I can't afford classes or intro flights.
Search and rescue teams. If you never provide a position report, they
won't know where you went down. If, like many VFR pilots, you don't
even bother to file a flight plan, they might not even know you are
missing. By the time they look for you and find you, you're dead.
Old November 20th 06, 05:05 PM posted to rec.aviation.piloting,rec.aviation.student
Travis Marlatte
"Mxsmanic" wrote in message
This is correct. From the pilots I have talked to, I see several
philosophies: 1) Flying over popluated areas, a crash is going to be known
and reported well before any automated trigger for search and rescue would
be initiated; 2) A wife/SO/friend knows to call FSS if they don't call/show
up by XX:XX; 3) File a flight plan so at least they will have a route path
to search; 4) File a flight plan and use flight following. ATC will prompt
for position reports if they don't have radar coverage. There are no
mandatory reporting points for VFR flights even on a flight plan; 5) Don't
do anything. Ce La Vie.
In terms of timing the start of search and rescue, 2) and 3) are about the
same. 1) is only good if the whole flight is over populated areas. 4) will
get the fastest response and has other benefits. 5) is unacceptable for my
personal minimums.
I tend not to file flight plans only because I don't typically go from point
A to point B. Sometimes, I don't know where I will end up or how I will get
there. A flight plan would only have them searching in the wrong place.
2) is always armed for me but then I have a loving partner and family. I
tend to write out my basic plan so that they can (while fighting back the
tears) convey to FSS the best places to search. Backing that up is either 1)
or 4).
Filing a flight plan with passengers on board is a mixed bag. On the one
had, I want to offer the most protection to my passengers as possible. On
the other hand, it is nice to be able to chit-chat and sightsee without
worring about ATC.
It is pretty unusual to just call FSS out of the blue with a position
report. They will certainly make a note of it but without 2), it won't do
much good until days later when you don't show up for work. Other than
filing a flight plan, there is no such thing as "N123 over podunk VOR. If
you don't hear from me in an hour, come looking."
Travis
Lake N3094P
PWK
Old November 20th 06, 05:06 PM posted to rec.aviation.piloting,rec.aviation.student
Thomas Borchert
Mxsmanic,
And the likelyhood of this what, based on which statistics? In other
words, are we talking about a real-world problem or something you made
up as a hypothetical scenario?
Thomas Borchert (EDDH)
Old November 20th 06, 06:15 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Thomas Borchert writes:
I like to keep safety on my side. You can do what you want.
Old November 20th 06, 07:18 PM posted to rec.aviation.piloting,rec.aviation.student
Thomas Borchert
Mxsmanic,
Well, you're sitting in a room. That should do it, no reporting
necessary.
GPS and old-fashioned thinking? G Farris Instrument Flight Rules 92 December 22nd 05 05:39 PM
ASRS/ASAP reporting systems - how confidential? Tim Epstein Piloting 7 August 4th 05 05:20 PM
