Icing conditions
Old December 1st 06, 02:41 AM posted to rec.aviation.piloting,rec.aviation.student
Dave[_1_]
Default Icing conditions
No argument on that!
Dave
On Thu, 30 Nov 2006 08:31:16 -0800, "Al G"
"Mxsmanic" wrote in message
crap snipped...
It's been my experience that any aircraft once exposed to ice, will
naturally seek out warmer air below.
Al G
Old November 29th 06, 07:30 PM posted to rec.aviation.piloting,rec.aviation.student
Ron Garret
Mxsmanic wrote:
From what I understand, icing protection should be turned on if the
outside temperature is 5° C or less. However, what is the reason for
not having it on all the time? Does it overheat in normal weather, or
what?
No, it just wastes resources and puts unnecessary wear and tear on
things.
I read that turning on icing protection before "sufficient ice has
accumulated" may prevent the protection from working to remove the
ice. Why?
That applies only to boots. If the ice layer is too thin it may remain
adhered to the boot.
Also, what types of anti-icing stuff should I turn on? Just
everything that deals with ice (wing, prop, pitot, fuel vent, etc.),
or is there an accepted order or hierarchy for these things?
Except for boots, the safest policy is to just turn it all on if there's
any possibility of ice.
rg
Old November 29th 06, 10:04 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Ron Garret writes:
And how do I recognize a possibility of ice? Should I assume that any
time I enter a cloud? Is there a safe external temperature above
which ice is never an issue? Logically I'd assume that ice would form
at zero degrees Celsius, but I don't know what margin above that to
provide. At the same time, I don't want to wear things out (even
though they never wear out in the sim) by running them when there's no
real chance of ice.
If ice starts to collect on places like the wings, what's the first
thing I would notice in the way the aircraft behaves? I do have a
light that shines on the wing so I can look at it, but I need to know
what the symptoms are of ice build-up as well.
Old November 29th 06, 10:47 PM posted to rec.aviation.piloting,rec.aviation.student
Ron Garret
Mxsmanic wrote:
Ron Garret writes:
Correction: TKS should also be used sparingly because the amount of
fluid is limited.
Obviously not. It has to be cold too.
provide.
Yes you do. You stated it yourself when you first asked the question.
Once again I have to ask: you do this a lot (dropping the context of the
conversation). Why? Do you have some mental deficiency that prevents
you from remembering what you have said previously in a conversation?
Or do you do it intentionally? If so, why? I really want to know.
real chance of ice.
These things are ultimately judgement calls, and depend on the risk
profile you wish to adopt. Since you're flying a sim it's a moot point.
Pick a policy; one is as good as another.
In my first icing encounter the first thing I noticed was that less air
was coming through the vent. I didn't realize I had ice for another few
minutes.
I do have a
That depends on your sim. I'd consult the manual.
rg
Old November 30th 06, 12:09 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Ron Garret writes:
Yes, but the leading edge of the wing might be colder than the cloud.
When water drops hit it, they solidify, then you have ice on the wing.
This is similar to the problem with cold-soaked wings on airliners
when they land at a warm and humid airport.
Sims crash, too.
The manual doesn't describe symptoms.
Old November 30th 06, 05:01 AM posted to rec.aviation.piloting,rec.aviation.student
Ron Garret
Mxsmanic wrote:
Ron Garret writes:
Yes, that is possible. Nonetheless, it has to be cold. Exactly how
cold depends a lot on the particular circumstances. The first time I
had ice my OAT read 3C (which is why it took me by surprise). YMMV.
There is no such problem. (This is not to say that no ice forms under
such conditions, only that it is never a problem, especially not in an
airliner.)
Sims crash, too.
Yes, especially when they run on Windows.
Then I'd say you're screwed. It is unlikely in the extreme that your
sim has anything remotely approaching a realistic model of ice
formation. Absent documentation, the only way I can think of to figure
out what kind of crude hack it has it to reverse-engineer the code.
You did say you are a computer expert, right?
rg
Old November 29th 06, 09:11 PM posted to rec.aviation.piloting,rec.aviation.student
N2310D
what?
ice. Why?
Once again, you are revealing your stupidity to us by the inane questions
you ask. You are such an idiot.
Since you said in another post (quoting exactly) about the sources of your
information:
"I also get a lot from textbooks, manuals, standard reference materials, and
reliable online resources. In some cases I get it directly from people I
believe to be qualified to provide it (which is not the same as people who
_claim_ to be qualified--there isn't always a lot of overlap)."
I suggest you go to those sources for this information. Few of us are
quailified to answer your questions since most of us possess airmen's
certificates and fly airplanes, not MSFS and the ilk.
Old November 29th 06, 09:15 PM posted to rec.aviation.piloting,rec.aviation.student
A Lieberma
"N2310D" wrote in
news:mImbh.15988$Uz.3908@trnddc05:
FINALLY a reply that makes sense..... Unfortunately, it will fall on the
deaf ears of Mx.....
Soooo, the best reply to Mx would be no reply.....
Allen
Old November 29th 06, 09:41 PM posted to rec.aviation.piloting,rec.aviation.student
N2310D
"A Lieberma" wrote in message
. 18...
"N2310D" wrote in
Allen
Hi Allen. Well, I sat back in the shadows and ignored Mx's stupidity for a
long time. In this case, I wasn't really replying to his post, only pointing
out to him what a dullard he is.
Old November 29th 06, 11:00 PM posted to rec.aviation.piloting,rec.aviation.student
Morgans[_2_]
OK, in my book. Dullard does not even begin, IMHO. g
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 03:55 AM
FAR 91.157 Operating in icing conditions O. Sami Saydjari Instrument Flight Rules 98 December 11th 03 06:58 AM
