Light twins not using contra-rotating propellers
Old December 1st 06, 07:29 PM posted to rec.aviation.piloting
Mxsmanic
Default Light twins not using contra-rotating propellers
Stefan writes:
The most simple solution would be the possibility to trim all
three axis.
Hmm ... is trim in all three axes uncommon? The Baron has aileron,
elevator, and rudder trim.
On the more expensive level (much more expensive, I would guess), you
can overcome the P-factor effects by using two contra-rotating coaxial
propellors. This would not only overcome the effects of the P-factor,
but also those caused by torque. Kamov helicopters are an example of
such a design.
With a single powerplant turning in one direction, there would still
be some residual torque from the engine itself.
Old December 1st 06, 07:31 PM posted to rec.aviation.piloting
Mxsmanic
Neil Gould writes:
The question becomes which options a buyer might find more attractive,
for example would you prefer 3-axis trim or better avionics and moving
map GPS?
How about a three-axis autopilot with three-axis trim?
Old December 1st 06, 07:32 PM posted to rec.aviation.piloting
Mxsmanic
Steve Foley writes:
By your standards, are bicycles poorly designed because they are unstable at
slow speeds?
They aren't unstable at slow speeds.
Old December 1st 06, 07:35 PM posted to rec.aviation.piloting
Steve Foley
Default MXX - Light twins not using contra-rotating propellers
"Mxsmanic" wrote in message
Steve Foley writes:
at
slow speeds?
I see you know about as much about bicycles as you do about airplanes
Old December 1st 06, 07:46 PM posted to rec.aviation.piloting
Mxsmanic
Steve Foley writes:
I think I know slightly more about airplanes, but I do know the basic
principles of bicycles.
Old December 1st 06, 08:07 PM posted to rec.aviation.piloting
Neil Gould
Recently, Mxsmanic posted:
Neil Gould writes:
It is a simple matter accounted for by Newtonian physics.
Apparently, the "designer" of that aspect of the real world doesn't
see a problem with it, as "real world version 2.0 has yet to be
released, AFAIK.
It is more likely that nobody wants to pay to fix it.
Who (or what) is in the position to "fix" Real World 1.0 that couldn't
easily afford the cost?
BTW, pilots of propeller-driven aircraft don't see a problem with it
either.
So if they had a choice between two otherwise identical aircraft, with
identical prices, they'd just flip a coin to choose between the one
with P-factor and torque and the one without?
Sorry, I prefer the Real World, the one in which such choices are unlikely
and the market has chosen their preferences.
Neil
Old December 1st 06, 08:09 PM posted to rec.aviation.piloting
Neil Gould
Neil Gould writes:
There is no violation at all. Such twins are designed to take
advantage of the laws of physics.
Then the design defect of propellers that rotate in the same direction
is not a violation of the laws of physics, QED.
Your paraphrase is incorrect. It should be, "The design using propellers
that rotate in the same direction is not a defect".
Neil
Old December 1st 06, 08:10 PM posted to rec.aviation.piloting
Neil Gould
Neil Gould writes:
attractive, for example would you prefer 3-axis trim or better
avionics and moving map GPS?
On your salary? You must be joking.
Neil
  #29
Old December 1st 06, 08:17 PM posted to rec.aviation.piloting
Stefan
We were talking about singles. Of course, you can always fly the baron
on one engine...
Yawn. You're talking to a former Moto Guzzi driver.
Stefan
  #30
Old December 1st 06, 09:30 PM posted to rec.aviation.piloting
Steve Foley
Steve Foley writes:
When you approach stop, a bicycle will fall over to one side or the other.
(unless yours still has training wheels).
- Note - MXX is intended as a flag to anyone wishing to block my responses
to Anthony.
Light twins not using contra-rotating propellers RomeoMike Piloting 6 December 2nd 06 01:47 AM
Light twins not using contra-rotating propellers Newps Piloting 0 November 30th 06 07:40 PM
Light twins not using contra-rotating propellers Greg Farris Piloting 0 November 30th 06 07:25 PM
HOW MANY GLIDER PILOTS DOES IT TAKE TO CHANGE A LIGHT BULB Mal Soaring 59 October 4th 05 05:39 AM
The light bulb Greasy Rider Military Aviation 6 March 2nd 04 12:07 PM
