Contra-rotating engine revisited
Old December 3rd 06, 06:54 AM posted to rec.aviation.piloting
Bucky
Default Contra-rotating engine revisited
Morgans wrote:
And stop following that MX, from the sim group, where ever he goes.
huh?
Old December 2nd 06, 05:15 PM posted to rec.aviation.piloting
Morgans[_2_]
"Chris W" wrote in message
The previous post on this topic got me wondering. Just how different would
the two engines need to be? I'm no expert, but it seems to me cam shaft(s),
magnetos, and prop are the parts that would be different from one side to the
other. I almost forgot, reverse the polarity on the starter motor. What am I
missing?
Not speaking to the other items, but electric motors seldom run as well in both
directions. It has to do with the timing, or how far ahead of the rotation that
the magnetic fields, or windings are switched.
Old December 2nd 06, 05:24 PM posted to rec.aviation.piloting
tom
With two stroke engines it is easy. I did this once. All I needed to
do was exchange the field wires in the starter to turn it backwards,
and modify the advance mechanism in the distributor so the spark was
advanced in the new direction. It ran fine. This was to enable a
motorcycle engine to be used in a go kart, where the engine was mounted
backwards, behind the rear wheels. It was a twin Yamaha and the go
kart would pop wheelies like crazy.
tom
would the two engines need to be? I'm no expert, but it seems to me
cam shaft(s), magnetos, and prop are the parts that would be different
from one side to the other. I almost forgot, reverse the polarity on
the starter motor. What am I missing?
Chris W
KE5GIX
"Protect your digital freedom and privacy, eliminate DRM,
learn more at http://www.defectivebydesign.org/what_is_drm"
Gift Giving Made Easy
Get the gifts you want &
give the gifts they want
One stop wish list for any gift,
from anywhere, for any occasion!
http://thewishzone.com
Old December 2nd 06, 09:41 PM posted to rec.aviation.piloting
Capt.Doug
Prop governor and oil pump drive gears if not on camshaft. Floating
crankshaft balance weights may be slightly different if those are used.
D.
Gyrocopter Speed Mark Rotorcraft 36 August 16th 05 11:28 PM
Towing Roger Fowler Soaring 6 August 11th 05 04:25 AM
What if the germans... Charles Gray Military Aviation 119 January 26th 04 11:20 PM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 04:29 AM
