How fast does the skin of the airplane cool to surrounding temperatures?
Old December 8th 06, 06:19 PM posted to rec.aviation.piloting
M[_1_]
Default How fast does the skin of the airplane cool to surrounding temperatures?
The NASA online icing course addressed part of this question:
http://aircrafticing.grc.nasa.gov/courses.html
Peter R. wrote:
A question for those of you more adept at chemistry/physics than I: How
fast does the aluminum skin of the standard single engine GA aircraft take
to cool to surrounding air temperatures? For example, how long would it
take for the skin to cool from a heated hangar at 65 degrees F to outside
air at 20 degrees F?
This is my first winter where my airplane sits at my destination airport
(Buffalo, NY) all week in a heated hangar. The problem I just inherited
is that if I desire to depart during a lake effect snowfall event, falling
snow could melt on the wings and fuselage and then turn to ice.
Peter
Old December 9th 06, 02:06 PM posted to rec.aviation.piloting
Peter R.
Thanks for the link.
Peter
Old December 9th 06, 02:50 PM posted to rec.aviation.piloting
Stubby
Buy ($80) or borrow an infrared remote thermometer and get some data.
NB: The laser only tells where the center of the cone is. It is not
involved in the measurement at all.
Old December 10th 06, 10:28 PM posted to rec.aviation.piloting
Danny Dot
"Peter R." wrote in message
You might be better off to taxi out with 20 degree wings that will not have
the snow melt and attach.
Danny
Peter
Old December 10th 06, 11:14 PM posted to rec.aviation.piloting
Mxsmanic
Danny Dot writes:
The wings couldn't melt snow _and_ freeze it. They could freeze water
droplets, or melt ice particles, but not both.
Old December 11th 06, 08:10 PM posted to rec.aviation.piloting
Mxsmanic wrote:
Danny Dot writes:
Have you tried this with your simulator?
We have six airplanes here, and when we take them out of a warm
hangar into falling snow, the snow melts on the airplane, and then the
resultant water freezes as the structure cools off. Makes a mess. Works
better to open the hangar door and let the airplanes cool off first
before moving them outside.
Maybe you should take your computer outside in various weather
conditions and see frost form or snow melt and refreeze. Be sure it's
turned off, like the real airplane.
I bet you've never seen ice fog generated by an airplane
propeller. An aircraft on runup can trugger fog over the whole airport
in a minute or two under the right conditions. Maybe the fan on your
computer could be made to duplicate it?
Dan
Old December 11th 06, 02:10 AM posted to rec.aviation.piloting
Tony
The snow would most likely melt over the fuel tanks (if it's a wet
skinned tank) then flow aft and freeze again. I don't remember ever
having the problem, but the only time our Mooney saw the inside of a
heated hanger was when it needed to have snow and ice melted from it.
At least once I climbed aboard after it was hanger heat soaked then
took off in fairly light snow (vis at least a half mile.) I wasn't
smart enough to worry about snow melting and refreezing -- my concern
was braking, or lack of it! It couldn't have been too bad though, the
airplane didn't move during run up.
I think even with warm fuel tanks, the convective cooling would pretty
quickly get the wing surfaces cool enough to keep the white stuff
solid.
On Dec 10, 5:28 pm, "Danny Dot" wrote:
"Peter R." wrote in ...
--You might be better off to taxi out with 20 degree wings that will not have
Danny
Peter- Hide quoted text -- Show quoted text -
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 07:29 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 03:04 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 2nd 04 11:41 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 09:02 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 03:07 AM
