Flight Following question
Old December 10th 06, 04:03 PM posted to rec.aviation.ifr
Newps
Default Flight Following question
Jim Carter wrote:
Do you have any quick references for that Milen? I've never heard of an
IFR flight plan with "VFR" in the enroute altitude box. Or are you
referring to filing VFR-on-top? If so, that's a lot different than just
requesting flight following for VFR flights.
OTP is similar but different. OTP is also an altitude you can file but
you'll get an IFR clearance.
Old December 10th 06, 04:05 PM posted to rec.aviation.ifr
Newps
A Lieberma wrote:
Sounds to me that what he is doing is fudging the system by filing an IFR flight plan
and annotating it with VFR references in the remarks.
No, he puts "VFR" into the altitude box, not in the remarks.
I know when you select the IFR box, it does generate a flight strip to ATC, and that
would be an IFR filing naturally.
Selecting VFR does not generate a flight strip to ATC,
Putting VFR in the altitude box does generate a strip to ATC, 30 minutes
prior to the P time.
Old December 10th 06, 04:10 PM posted to rec.aviation.ifr
Newps
Stan Prevost wrote:
As Milen says, check IFR (it is not an IFR flight plan, that is just a
routing flag for ATC vs FSS), put VFR or VFR/120 for 12,000 feet or whatever
your filed altitude is.
Use a VFR altitude. Such as VFR/125, VFR/075, etc.
Old December 10th 06, 04:12 PM posted to rec.aviation.ifr
Newps
A Lieberma wrote:
"Stan Prevost" wrote in
Call it what you want, but the form on top says FAA Flight plan.
1.Type is either VFR or IFR.
If you select IFR, you are filing a IFR flight plan. No grey zone about
it, all you are doing is fudging the system to get a plan routed to ATC.
VFR flight plans are not routed to ATC period.
You're wrong. Do it as he says and I get a strip printed for me. That
is the exact procedure I use when I enter a flight plan into the system
for a pilot. There's no IFR/VFR box to check so the altitude
information is the only way the computer knows if you are IFR or getting
VFR flight following.
Old December 10th 06, 04:23 PM posted to rec.aviation.ifr
A Lieberma
Newps wrote in
minutes prior to the P time.
But he is SELECTING in box 1.type IFR. I was always told that if you
select VFR in box 1, no strip is generated to ATC, thus an IFR filing.
Altutude is box 7 on the FAA flight plan.
Allen
Old December 10th 06, 04:25 PM posted to rec.aviation.ifr
Mitty
On 12/9/2006 8:16 PM, Jim Carter wrote the following:
My question for the group is: is there a special terminology that should
be used when requesting full-enroute flight following? Or, why do some
controllers provide that service automatically and others seemingly only
under duress? (I don’t think it is a controller issue, however it might
be a facility policy issue).
Normally here in Minneapolis I say something like "... requesting traffic
advisories to KXXX, six thousand, five hundred." And I get a through code in
the 4xxx block.
To do this, I think my local ground control guy (KMIC) has to telephone the KMSP
TRACON for the code. Maybe the call goes to a desk rather than to a
possibly-busy controller where there could be a workload issue?
One time out of Ames, IA talking to the Des Moines TRACON I got a local code
(0xxx). When I was leveled out I asked the TRACON controller "Can you give me a
code that will get me to Minneapolis?" Got a "stand by" and in a couple of
minutes he called back and gave me the code. At the appropriate time he then
handed me off to Center, no problem.
Old December 10th 06, 04:31 PM posted to rec.aviation.ifr
A Lieberma
Newps wrote in
That is the exact procedure I use when I enter a flight plan into the
system for a pilot. There's no IFR/VFR box to check so the altitude
getting VFR flight following.
Please see the FAA flight plan form the pilot completes. See box 1. type.
It's either VFR ir IFR.
If I check IFR on 1.type of the FAA flight plan, I get a center control
number that is filed into the ATC system via DUATS.
I DO NOT get a center control number when I FILE VFR. I get a remark the
plan is forwarded to the servicing FSS.
Maybe FSS forwards something to you when I file through FSS, but when I
file via DUATS, it's a very distinct difference on the electronic response.
There may not be any IFR / VFR box on your end, but there sure is on the
pilot's end filing the plan.
I also notice that the website Flight Aware NEVER picks up my VFR flight
plan filings, where as when I file IFR, it shows scheduled one hour before,
so I know there is some meat to my theory in that VFR selection on the FAA
flight plan does not get passed on to the ATC system.
Allen
  #29
Old December 10th 06, 05:42 PM posted to rec.aviation.ifr
Newps
A Lieberma wrote:
Newps wrote in
Irrelavant for ATC. The altitude box takes precedence.
That's true. It's a routing question. We are a regional cargo hub for
UPS and DHL. We have lots of small aircraft running cargo. Twin
Cessnas, Barons, Beech 99's and 1900's, Metroliners, etc. They all have
prefiled IFR flight plans that spit out the same time every day. They
always go VFR when they can, which is about 90% of the time. For those
who's ops specs require flight following we simply change the altitude
on their IFR strip to a VFR one. Change 120 to VFR/125. The altitude
box holds 7 characters. When he tags up on the radar there is now a V
on the tag indicating he is VFR.
Same as on the FAA computer controllers use.
  #30
Old December 10th 06, 05:45 PM posted to rec.aviation.ifr
Newps
the KMSP TRACON for the code. Maybe the call goes to a desk rather than
to a possibly-busy controller where there could be a workload issue?
It depends. Does MIC have a DBRITE? If so then they more than likely
will have something set up with MSP so MIC can get their own codes so a
call doesn't have to be made.
code (0xxx). When I was leveled out I asked the TRACON controller "Can
you give me a code that will get me to Minneapolis?" Got a "stand by"
and in a couple of minutes he called back and gave me the code. At the
appropriate time he then handed me off to Center, no problem.
He didn't call MSP, he simply input a VFR flight plan into the FDIO
which spit out a center code.
IFR use of handheld GPS [email protected] Instrument Flight Rules 251 May 19th 06 02:04 PM
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 03:55 AM
ramifications of new TSA rules on all non-US and US citizen pilots paul k. sanchez Piloting 19 September 27th 04 11:49 PM
PC flight simulators Bjørnar Bolsøy Military Aviation 178 December 14th 03 12:14 PM
