#21
Steven P. McNicoll wrote:
SVFR is also not available at airports outside of a surface area, but neither is a contact approach. Surface areas and contact approaches both require weather observations. A surface area isn't necessary for a contact approach. |
![]() Ron Natalie wrote: A surface area isn't necessary for a contact approach. I didn't say it was. |
![]() Jim Macklin wrote: Gee, there sure are a lot of contact approaches made to airports. It would do you well to actually read what you copy and paste. |
Ron Natalie wrote: A surface area isn't necessary for a contact approach. I didn't say it was. You said: SVFR is also not available at airports outside of a surface area, but neither is a contact approach. The "but neither is a contact approach" seems to imply that. |
![]() Steven P. McNicoll wrote: I didn't say it was. Upon further review, I did misspeak. I wrote, "SVFR is also not available at airports outside of a surface area, but neither is a contact approach. Surface areas and contact approaches both require weather observations." If you're approaching an airport where SVFR is not available it's probably because it's outside of a surface area. I see no advantage then in picking up an IFR clearance in order to request a contact approach as the minimums for a contact approach are the same as VFR in Class G airspace. |
![]() Ron Natalie wrote: You said: SVFR is also not available at airports outside of a surface area, but neither is a contact approach. The "but neither is a contact approach" seems to imply that. You're right. I was apparently writing my followup as you were writing what's above. |
Good point... Most of the approaches I fly do not involve vectoring
close to the airport before going back out and coming in again, so I did not think of this. --Dan Steven P. McNicoll wrote: Dan wrote: Since a contact approach requires the airport to have an IFR approach, I fail to see the advantage of a contact approach. If visibility is at 1 mile, I think I would rather just fly the approach than pick around for the airport in those conditions - too risky. Where is the advantage? Following other traffic visually? Suppose you're abeam the runway while being vectored for an IFR approach when you sight the field. The current weather observation is below VFR minimums so a visual approach is not available. Would a contact approach present an advantage in that situation? |
#29
Jim Macklin wrote:
A visual approach may be instigated by the controller if the weather is good VFR. What is good VFR? Just VFR? I thought MVFR or better was required for PIC request? Is that the requirement for ATC to assign? That is to say they won't assign in MVFR? Thanks, ak. |
#30
VFR position reporting | Mxsmanic | Piloting | 154 | November 26th 06 04:45 PM |
OLV GPS 36 approach question | A Lieberma | Instrument Flight Rules | 59 | August 15th 06 12:32 AM |
Trust those Instruments.... Trust those Instruments..... | A Lieberman | Instrument Flight Rules | 1 | May 2nd 06 03:54 PM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
"Cleared Straight-In Runway X; Report Y Miles Final" | Jim Cummiskey | Piloting | 86 | August 16th 04 06:23 PM |
