#21
John R. Copeland wrote:
"Sam Spade" wrote in message ... John R. Copeland wrote: "Sam Spade" wrote in message ... With LPV, the sensitivity continues to increase (course width decreases) from the FAF to the runway. That causes LPV to be an angular system from the FAF to the runway. Not so with other RNAV. Thanks. I didn't know of the difference. I'll watch for it. I getting up to speed on the 145/146 spec. The LNAV approach also reduces in the lateral mode similar to the laternal mode of the LPV approach. When you reach the MAP, it is only 350 feet full scale deflection, instead of the 0.3 mile defection for TSO 129 LNAV final. I'm definitely gonna have to set up an experiment over that! I'd expect to have noticed it, if my CNX80 behaved that way. Is that a behavior demanded by TSO-C145/146, or merely allowed? Stay tuned. |
"Sam Spade" wrote in message ... John R. Copeland wrote: "Sam Spade" wrote in message ... With LPV, the sensitivity continues to increase (course width decreases) from the FAF to the runway. That causes LPV to be an angular system from the FAF to the runway. Not so with other RNAV. Thanks. I didn't know of the difference. I'll watch for it. I getting up to speed on the 145/146 spec. The LNAV approach also reduces in the lateral mode similar to the laternal mode of the LPV approach. When you reach the MAP, it is only 350 feet full scale deflection, instead of the 0.3 mile defection for TSO 129 LNAV final. I'm definitely gonna have to set up an experiment over that! I'd expect to have noticed it, if my CNX80 behaved that way. Is that a behavior demanded by TSO-C145/146, or merely allowed? The following language suggests that LNAV must always be 350 feet at the MAP. Both Figures 2-12 and 2-13 show 350 at the MAP. 2.2.3.3.1 Approach Path Definition If the pilot has not selected a VTF approach, deviations shall be provided with respect to the active leg of the approach procedure. See Figure 2-12. If the pilot has selected a VTF approach, deviations shall be provided relative to the inbound course to the FAF. See Figure 2-13. The active waypoint shall initially be the FAWP. The equipment should also account for short turns onto the final approach where the FAWP may not be crossed. Note 1: A VTF approach can be selected at any time. |
On Sun, 17 Dec 2006 06:59:39 -0800, Sam Spade wrote:
Ron Rosenfeld wrote: I've not noted a "step change" in my CNX80. The changes in sensitivity are supposed to be gradual, and at the FAF I believe the "scaling" goes to angular, to mimic an ILS. But maybe I've just missed it. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) As I understand it, it first ramps down to 0.3 from 1.0 starting at 2 miles from the LPV FAF, then it does a continuous angular "ramp down" from the FAF to the runway so it will be ILS-like close in. Have you noted that doing small incremental "stepping" on an LPV IAP during final approach? Well, I'm hand-flying most of the approaches, and the CDI is generally centered prior to the FAF, so I wouldn't note a sudden change in sensitivity on the final segment. I do, of course, note the change going from enroute to terminal mode, and from terminal to approach mode if I have any CDI deflection. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
On Sun, 17 Dec 2006 06:59:39 -0800, Sam Spade wrote: Well, I'm hand-flying most of the approaches, and the CDI is generally centered prior to the FAF, so I wouldn't note a sudden change in sensitivity on the final segment. I do, of course, note the change going from enroute to terminal mode, and from terminal to approach mode if I have any CDI deflection. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) I am playing with the new Garmin 400/500W trainer and the needle movement is very smooth. I also verified the great difference between when the scaling becomes localizer-like with VTF and own-nav. I flew the LPV into KIXD Runway 36. Using VTF, I did an intercept 8 miles prior to JIKLA (the FAF). The CDI scaling was already well below 1 mile. Then I did an intercept at the same position with ANQUIM (the IF) to JIKLA as the active leg. The needle came off the peg at 1 mile crosstrack error. The 530W also has a nice feature, not present in th 530. When there is a course change at a waypoint it shows a broken magenta line, which is the flyby course that will be flown if on autopilot. Positive course gudiance in holds and procedure turns using highly accurate roll-steering is great, too. (For FD or autopilot, those too need to have roll steering to get the most out of these curved flight paths.) |
On Fri, 22 Dec 2006 09:10:02 -0800, Sam Spade wrote:
Ron Rosenfeld wrote: On Sun, 17 Dec 2006 06:59:39 -0800, Sam Spade wrote: Well, I'm hand-flying most of the approaches, and the CDI is generally centered prior to the FAF, so I wouldn't note a sudden change in sensitivity on the final segment. I do, of course, note the change going from enroute to terminal mode, and from terminal to approach mode if I have any CDI deflection. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) I am playing with the new Garmin 400/500W trainer and the needle movement is very smooth. I also verified the great difference between when the scaling becomes localizer-like with VTF and own-nav. I flew the LPV into KIXD Runway 36. Using VTF, I did an intercept 8 miles prior to JIKLA (the FAF). The CDI scaling was already well below 1 mile. Then I did an intercept at the same position with ANQUIM (the IF) to JIKLA as the active leg. The needle came off the peg at 1 mile crosstrack error. The 530W also has a nice feature, not present in th 530. When there is a course change at a waypoint it shows a broken magenta line, which is the flyby course that will be flown if on autopilot. Positive course gudiance in holds and procedure turns using highly accurate roll-steering is great, too. (For FD or autopilot, those too need to have roll steering to get the most out of these curved flight paths.) I have no experience with anything other than the 480, so can't comment. I also do not have a roll-steering a/p. The 480 does show a solid curved magenta line for course changes at waypoints representing the expected flight path. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
![]() "Sam Spade" wrote in message ... The 530W also has a nice feature, not present in th 530. ......snip... Positive course gudiance in holds and procedure turns using highly accurate roll-steering is great, too. (For FD or autopilot, those too need to have roll steering to get the most out of these curved flight paths.) According to the GNS430W manual, the unit does not provide positive course guidance in holds except on the inbound leg, which is not a change from the 430, and does not provide positive course guidance on a PT except on the outbound and inbound portions (not during the reversal itself), which is also not a change from the 430. Regarding roll steering, it says "For roll steering autopilots: roll steering is terminated when approach mode is selected on the autopilot and is available once the missed approach is initiated." I don't really understand this statement. I didn't read the 530W manual. Is it different? |
Stan Prevost wrote:
"Sam Spade" wrote in message ... The 530W also has a nice feature, not present in th 530. ......snip... Positive course gudiance in holds and procedure turns using highly accurate roll-steering is great, too. (For FD or autopilot, those too need to have roll steering to get the most out of these curved flight paths.) According to the GNS430W manual, the unit does not provide positive course guidance in holds except on the inbound leg, which is not a change from the 430, and does not provide positive course guidance on a PT except on the outbound and inbound portions (not during the reversal itself), which is also not a change from the 430. Regarding roll steering, it says "For roll steering autopilots: roll steering is terminated when approach mode is selected on the autopilot and is available once the missed approach is initiated." I don't really understand this statement. I didn't read the 530W manual. Is it different? It says the same thing. I don't understand the limitation, either. It will have to be changed if they want to take advantage of RF legs, which will eventually appear in some Basic RNP IAPS, when the criteria are changed. High end birds that have roll steering do not have such a limitation. As to the PCG, in spite of what the manual says, it works in the trainer. The trainer historically has been accurate. |
![]() Sam Spade wrote: Dave Butler wrote: Yes, LPV IAP. Jeppesen is so full of it. Those LPV approaches are for any database in a TSO 145/146 set, which means the GNS480. I haven't given any instruction in the 480's since the TSO. I'm waiting for the G1000 to get approved. -Robert |
#29
Robert M. Gary wrote:
Sam Spade wrote: Dave Butler wrote: Yes, LPV IAP. Jeppesen is so full of it. Those LPV approaches are for any database in a TSO 145/146 set, which means the GNS480. I haven't given any instruction in the 480's since the TSO. I'm waiting for the G1000 to get approved. -Robert Just for the record, despite the words "Dave Butler wrote:", nothing in this article contains any of my words. Dave Butler |
#30
Dave Butler wrote:
Robert M. Gary wrote: Sam Spade wrote: Dave Butler wrote: Yes, LPV IAP. Jeppesen is so full of it. Those LPV approaches are for any database in a TSO 145/146 set, which means the GNS480. I haven't given any instruction in the 480's since the TSO. I'm waiting for the G1000 to get approved. -Robert Just for the record, despite the words "Dave Butler wrote:", nothing in this article contains any of my words. Dave Butler Those were my words. |
Haven't flown in a long while... | Flyingmonk | Piloting | 33 | April 5th 06 06:30 AM |
Total cross country distance flown | Bill Daniels | Soaring | 9 | November 4th 05 11:53 AM |
If there are any pilots here that have ever flown aerial surveys.... | terrygeosearch | Piloting | 1 | February 8th 05 06:45 PM |
If there are any pilots here that have ever flown aerial surveys.... | terrygeosearch | General Aviation | 0 | February 2nd 05 04:11 AM |
Most aircraft types flown by 1 pilot? | Chad Irby | Military Aviation | 10 | January 7th 04 03:47 AM |
