#21
"Stefan" wrote in message
... Mathematically: There are always two square roots which solve the equation: A positive and a negative. Physically: If you only know GS, TAS and HDG, then you don't know whether the wind blows from the let or from the right. While that statement is true, it doesn't cover all the possibilities. We're talking about the case of a single aircraft? We know its HDG, GS, TAS, but nothing else? That's only three of the six wind triangle variables. We must know at least four to get an exact answer. With only three knowns, there are a whole range of possible answers, since we don't know what the wind correction angle is without knowing a CRS. For example, for the following HDG, TAS and GS: HDG 0 TAS 120 GS 100 All the following CRS, WD an WS are valid solutions, plus many more in-between: CRS WD WS === === === 310 054 095 330 056 060 350 039 028 000 000 020 CRS=HDG 010 321 028 030 304 060 050 306 095 I think you were visualizing a triangle, and thought of the two obvious solutions. But there are a lot more. Again, use the E6B method and you'll see that any drift angle along the TAS arc contains a valid WS and WD answer. Regards, Kev |
"Chad Speer" wrote in message ups.com... Chad Speer PP-ASEL, IA ATCS, Kansas City ARTCC ************************************************** * ************************************************** * snip direction of travel speed across the ground speed through the air If you can get heading also, it is a fairly simple equation as others have posted. Danny Deger |
"Denny" wrote in message oups.com... Lots of fun to play with the formulas... But, the fly in the ointment here is that the airspeed filed by the pilot is a canned number and has nothing to do with reality... I fly IFR, I file the same airspeed - 130 kt - for all flights regardless of load, altitude, and what the power setting winds up to be... If the actual airspeed in your problem is within 15% of the filed number you will be lucky... denny Now I see why heading is not known. I agree, calculating wind on filed airspeed would not be a good idea. Maybe taking the average of many airplanes might be OK, but the difference between filed and actual can be HUGE. Danny Deger |
"Chad Speer" wrote in message ps.com... Denny wrote: ***** Lots of fun to play with the formulas... But, the fly in the ointment here is that the airspeed filed by the pilot is a canned number and has nothing to do with reality... I fly IFR, I file the same airspeed - 130 kt - for all flights regardless of load, altitude, and what the power setting winds up to be... If the actual airspeed in your problem is within 15% of the filed number you will be lucky... ***** You're right, Denny. When you get down to the piston single/twin level, there is great variation. This will be used mostly with high altitude traffic where, with the exception of an occasional turboprop, the true speeds are 400 knots plus. Most commercial operators file to the knot and, in my experience, fly within ten knots. That is probably going to be an acceptable variation, but time will tell. We will also be polling some pilots initially to determine their heading, true airspeed, and observed winds to validate our results. Chad Speer PP-ASEL, IA ATCS, Kansas City Center Each plane gives you an estimate of the head/tail wind, but no information on the cross wind. You need a way to combine all the different airplanes wind data into a single estimate of the wind. The error in filed airspeed vs. actual airspeed could be averaged out over many airplanes. I am sure a Kalman filter would work (I think :-), but it has been a while since I have worked on a Kalman Filter. The math is not trivial, and this particular filter would definately not be trivial. You could start the filter with the estimate of wind from the weather guy -- or would this be considered cheating. Danny Deger |
"d&tm" wrote in message ... "Chad Speer" wrote in message oups.com... Terry - thanks for the reply, but heading is not known. snip TAS1^2=WS^2+GS1^2-2WSGS1COS(180-ABS(WD-TR1) TAS2^2=WS^2+GS2^2-2WSGS2COS(180-ABS(WD-TR2) WHERE TAS1 AND TAS2 ARE TRUE AIRSPEEDS FOR AIRCRAFT 1 AND 2 WS = WIND SPEED WD =WIND DIRECTION IN DEGREES MAG TR1 AND TR2 ARE TRACKS MAGNETIC FOR AIRCRAFT 1 AND 2 GS1 AND GS2 ARE GROUND SPEEDS FOR AIRCRAFT 1 AND 2. (180-ABS(WD-TR) WILL GIVE YOU THE ACTUAL ANGLE BETWEEN WIND DIRECTION AND TRACK. Now we have 2 equations with 2 unknowns ( WS and WD) which should be solvable but I am stuggling to get it out. However I did a little exercise which suggests the end result may not be very useful. because small errors in the ground speeds will cause very large errors in the calculated wind speed. I think the head/tail wind portion of the estimate should be pretty good, but the crosswind component would have so much error as to be useless. We need a way to use the head/tail wind components from different airplanes, flying different headings and NOT use the less acurate crosswind estimates. I think a Kalman filter would work. Danny Deger |
Chad,
I think that some clarification of the use might help. I can imagine two scenarios: 1) enroute - in this case, you know the track and ground speed from radar. You have the filed TAS. You have no idea of the crab angle or heading. This sounds like the information you presented in your question. However, enroute, who cares what the wind correction is. I am having trouble imagining how this would help a controller - in training or not. 2) terminal - in this case, you still know the track and ground speed from radar. However, now the filed TAS is probably no longer valid since it is probably at a lower altitude than filed and used to compute the TAS. The plane may also be under speed constraints. On the other hand, the controller may be vectoring so now you have an assigned heading and maybe even an assigned speed. You also have the pressure for the area and the TAS can be computed from that and radar data. If this were an automated computation, it could be done on every plane that was given an assigned speed (or even IAS queried from the pilot) and an assigned heading (or even queried from the pilot). Now maybe not every plane can provide all of the data but certainly some could. Enough to update the calculated wind periodically. Scenario 2 seems to me the one that would make knowledge of the wind most desirable. It is also the scenario that could provide additional data and certainly provides different data than what was posed in your question. What say you? -- ------------------------------- Travis Lake N3094P PWK |
It is common for a new (or weak)
controller to turn an aircraft behind another, only to see that same aircraft pick up a bunch of speed. The turn has nearly no effect on separation, so they turn them some more. Within minutes, the turn is fifty degrees and the controller is sucking up a seat cushion. Fun to watch, but it would be nice to train that kind of stuff out of the workforce. :-) With even a close approximation of the winds, the realism is greatly enhanced. Otherwise, the what-if's are reduced to a bland simulation and utility is reduced. Do the controllers know (and have easily available, say, on the terminal) the wind speed forecasts? Would they be sufficient to greatly reduce the above scenario? Jose -- "There are 3 secrets to the perfect landing. Unfortunately, nobody knows what they are." - (mike). for Email, make the obvious change in the address. |
I really like the open discussion of Usenet
Try some of the math and CS newsgroups. You might get more traction. Jose -- "There are 3 secrets to the perfect landing. Unfortunately, nobody knows what they are." - (mike). for Email, make the obvious change in the address. |
#29
Yanno, each airplane that has GPS could transmit its data to Center, which could then sort it out. This is possibly much more useful than the Mode S ID or the N-number. Jose -- "There are 3 secrets to the perfect landing. Unfortunately, nobody knows what they are." - (mike). for Email, make the obvious change in the address. |
#30
Chad Speer wrote: This tool is basically meant to be a replay of a high altitude training session, where the trainer can say "Okay, let's see what would have happened if you had turned AAL460 fifteen left rather than descending him." As it exists now, it is really cool, but a bit unrealistic. If the winds are strong enough, a fifteen degree turn can easily add twenty knots to a groundspeed. [..] Chad, I think we need to stop and get the requirements, so we can help better. I'm guessing how the program will work: You have data from a training session. It has a recording of many aircraft movements that you can play back. Perhaps you add one new and controllable craft to the mix (AAL460 above?) and that's the one that gets vectored by the trainee, to see what kind of trouble he can get in/out of. Since all the other aircraft had been affected by wind, the controllable plane needs the same flight input. Is this a good description? If so, I'm thinking that the wind within the 2000' block you talked about, is a single fixed value for the entire training session. Would that be fair to say? If that is true, then you don't need to calculate the wind except once at the beginning. Can this be stored for later use each time? Just trying to get a handle on things, Kev |
| Thread Tools | |
| Display Modes | |
| Help with 152 math | pittss1c | Piloting | 12 | May 13th 05 02:47 PM |
| Another Math Question | Dan Nafe | Home Built | 2 | May 4th 05 02:50 AM |
| # of Aircraft Club Members - Math Formula Wanted | Rich | Owning | 3 | September 16th 04 05:08 PM |
| Math help request ? | Snead1 | Soaring | 5 | June 9th 04 12:15 AM |
| Student invents new math process | Otis Willie | Military Aviation | 29 | December 2nd 03 03:13 AM |
