Atomic Aircraft
Old December 21st 06, 03:31 PM posted to rec.aviation.piloting
Ron Natalie
Default Atomic Aircraft
Gig 601XL Builder wrote:
So the question is would a nuclear powered engine, once in space, provide
enough energy to be more efficient than a more conventional power source. I
think the answer might be yes for high earth orbit and as the craft moved
farther away from the earth gravity well it would be even more efficient.
Huh? What do you need the engine for? If it's for propulsion then
the mass is going to be important, the force needed to be applied is
proportional of the mass. If you are just using it for other power
purposes, then it doesn't necessarily make a difference.
Old December 21st 06, 03:33 PM posted to rec.aviation.piloting
On Thu, 21 Dec 2006 07:49:28 GMT, Larry Dighera wrote:
On Wed, 20 Dec 2006 14:33:32 -0600, "Danny Deger"
wrote in
"Larry Dighera" wrote in message
snip
But weight isn't an issue in the micro gravity of space ...
You can not be any more wrong about this. In space craft design, weight is
EVERYTHING.
Only during launch.
Only if you never, EVER need to use thrust again, once your booster shuts down.
If you plan on keeping a precise orbit or are charting a course to another body
in space, then you'll want to keep the weight down to minimize the expenditure
of onboard fuel. Also, if you're going to want to point the vehicle in any
particular direction, lower weight will let you get away with smaller/lighter
attitude control devices and/or use less fuel to do it.
Old December 21st 06, 04:05 PM posted to rec.aviation.piloting
Gig 601XL Builder
I think the answer might be yes for high earth orbit and as the craft
moved farther away from the earth gravity well it would be even more
efficient.
My comment was made in a world where nuke propulsion isn't going to be used
for launches in the foreseeable future. So the question was would a nuclear
propulsion unit give you enough power to make up for the added mass of the
unit. I would assume if you were going to go to the trouble of putting a
nuke in there you'd use it for all power needs from propulsion to the
lights.
Old December 21st 06, 04:09 PM posted to rec.aviation.piloting
Larry Dighera
On Thu, 21 Dec 2006 07:33:48 -0800, Ron Wanttaja
wrote in
wrote in
snip
EVERYTHING.
Only during launch.
What would you estimate the ratio between the quantity of fuel
expended during launch to the amount of fuel needed to accomplish the
things that you mention?
Old December 21st 06, 04:49 PM posted to rec.aviation.piloting
Jose[_1_]
EVERYTHING.
Only during launch.
After which mass is everything.
Jose
"There are 3 secrets to the perfect landing. Unfortunately, nobody knows
what they are." - (mike).
Old December 21st 06, 08:06 PM posted to rec.aviation.piloting
Larry Dighera
On Thu, 21 Dec 2006 16:49:42 GMT, Jose
wrote in :
EVERYTHING.
Only during launch.
It would seem that, the mass or weight become a lot more insignificant
after the Earth's gravitational field's influence on the space craft
is reduced as a result of the increased distance between the Earth and
the space craft. But that whole discussion fails to address the issue
implicit in the question of using atomic fission for propulsion of an
aerial vehicle within the Earth's atmosphere.
Apparently the weight of a conventional atomic fission reactor and its
necessary shielding, not to mention the weight of the "steam engine"
components, make the prospect of atomic aircraft all but entirely
unfeasible for terrestrial navigation. That weight limitation would
largely be overcome in a vehicle designed for use in space under
micro-gravity conditions where there is no necessity to rely upon
aerodynamic lift to support it. So if one has the power available to
boost a heavy reactor and the requisite shielding into space, if a
suitable nuclear powered rocket can be devised, the use of nuclear
propulsion may be feasible for space travel, despite its apparent
limitations for use in conventional winged aircraft operating within
However, if a small nuclear fission reactor used to power a Sterling
engine, such as those currently used in space, could be made light
enough, powerful enough and still adequately shielded, perhaps the
dream (nightmare?) of atomic aircraft would be achievable.
Here's some information about what NASA successfully has accomplished
with nuclear power:
http://www.grc.nasa.gov/WWW/tmsb/index.html
The Thermo-Mechanical Systems Branch (5490) is responsible for
planning, conducting and directing research and technology
development to advance the state-of-the-art in a variety of
thermal systems for space, aerospace, as well as non-aerospace
applications. The systems of interest include thermal energy
conversion for power systems and solar thermal propulsion systems.
The effort involves working at the component level to develop the
technology, the subsystem level to verify the performance of the
technology, and the system level to ensure that the appropriate
system level impact is achieved with the integrated technology.
System analysis is used to identify high-impact technology areas,
define the critical aspects of the technology that need to be
developed, and characterize the system level impact of the
technology. Specific technology areas of interest include:
Dynamic Power Systems: Brayton, Rankine and Stirling Convertors,
Solar Receivers and Thermal Energy Storage
Primary Solar Concentrators: Thin film, SRP and Rigid
Secondary Solar Concentrators: Refractive and Reflective
Thermal Management: Radiators, Electronics Packaging, and Heat
Pipe Technology
http://www.grc.nasa.gov/WWW/tmsb/stirling.html
Animation of a 55 We Stirling TDC
(click on image to view)
http://www.grc.nasa.gov/WWW/tmsb/sti...adisotope.html
AVAILABLE TODAY FOR TOMORROW'S NEEDS
NASA Glenn Research Center and the Department of Energy (DOE) are
developing a Stirling convertor for an advanced radioisotope power
system to provide spacecraft on-board electric power for NASA deep
space missions. Stirling is being evaluated as an alternative to
replace Radioisotope Thermoelectric Generators (RTGs) with a
high-efficiency power source. The efficiency of the Stirling
system, in excess of 20%, will reduce the necessary isotope
inventory by a factor of at least 3 compared to RTGs. Stirling is
the most developed convertor option of the advanced power concepts
under consideration [1,2].
http://www.grc.nasa.gov/WWW/tmsb/sti...ng_bckgrd.html
However, about this time NASA became interested in development of
free-piston Stirling engines for space power applications. These
engines use helium as the working fluid, drive linear alternators
to produce electricity and are hermetically sealed. These 12.5 kWe
per cylinder engines were intended for use with a nuclear reactor
power system; the Space Demonstrator Engine (or SPDE) was the
earliest 12.5 kWe per cylinder engine that was designed, built and
tested by MTI. A later engine of this size, the Component Test
Power Convertor (or CTPC), used a "Starfish" heat-pipe heater
head, instead of the pumped-loop used by the SPDE. Recently, in
the 1992-93 time period, this work was terminated due to the
termination of the related SP-100 nuclear power system work and
NASA's new emphasis on "better, faster, cheaper" systems and
missions.
http://www.spacedaily.com/news/outerplanets-00a2.html
Europa Orbiter was replanned to use a new "Sterling" nuclear
generator design which would use less plutonium
http://www.cndyorks.gn.apc.org/yspac...heed_offer.htm
Boeing, Lockheed Offer NASA Two Choices for Nuclear Power
http://powerweb.grc.nasa.gov/doc/marsairplane.html
On February 1, 1999, NASA Administrator Daniel Goldin, announced
the "Mars Airplane Micromission," which would have been the first
NASA micromission program to launch on an Ariane 5 rocket. The
flight would have the first Mars airplane arriving on the Red
Planet around December 17, 2003, the centennial of the Wright
brother's first flight. A team composed of members from four NASA
centers (Ames, Dryden, Langley, and Glenn) was formed to generate
conceptual designs for the micromission airplane.
From the information provided at those web pages, perhaps it would be
possible to deduce whether the current state of technology would
enable the development of atomic powered aircraft today.
Unfortunately, the political and environmental concerns are probably
insurmountable even if the technology is now adequate.
Old December 21st 06, 08:18 PM posted to rec.aviation.piloting
Jose[_1_]
the space craft.
The mass of a spacecraft directly impacts the energy needed to change
course and attitude, and thus the fuel required during the journey.
Rightly so. Technology may be up to the task, but nuclear reactors
increase the degree to which human error (a constant) or human evil
(also a constant) would impact the world. We are actually getting to
the point where the old cartoons of the mad scientist flying to the moon
to blow up the earth could actually come to pass, in some form.
Jose
Old December 22nd 06, 02:20 AM posted to rec.aviation.piloting
Capt. Geoffrey Thorpe
"Kev" wrote in message
Montblack wrote:
("Danny Deger" wrote)
weight
is EVERYTHING.
For getting your payload (one time) up to space, after that weight is
much
less of an issue. g
But then there was the infamous Project Orion in the '50s, which was a
spaceship designed to be pushed along by multiple atomic blasts. It
was envisioned to hold 200 crew, weigh thousands of tons, and be able
to get to Mars and back in four weeks (!!!). I think they planned to
use two Saturn V's to launch it, in case people objected to using the
atomic blasts inside the atmosphere.
http://en.wikipedia.org/wiki/Nuclear_pulse_propulsion
http://www.space.com/spacelibrary/bo...on_020709.html
Gotta love those wacky rocket scientists.
Kev
Orion was nothing
http://www.merkle.com/pluto/pluto.html
Radioactive fallout from the exhaust was a _feature_ of this thing - not a
problem!
Geoff
  #29
Old December 22nd 06, 04:46 AM posted to rec.aviation.piloting
EVERYTHING.
Only during launch.
Low...*but*: For every pound of additional fuel you'll need on orbit, you'll
burn twenty additional pounds of propellant to put it there. Ditto for every
pound of upgraded attitude control hardware. And you *cannot* refuel. Darn
right you'll design your space vehicle to minimize the consumption of on-orbit
fuel, just because it costs so much to get it up there.
You can't ignore launch weight for a spacecraft any more than you can ignore
wing design for an aircraft.
Contact Approach -- WX reporting [email protected] Instrument Flight Rules 64 December 22nd 06 01:43 PM
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 03:55 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 07:29 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 03:04 PM
