#21
JS wrote:
306 km/hr = 190 mph = 165 knots That is an amazing feat! Yes, it is. Anyone trying to beat that record should be certain their parachute is in good shape, as the number of wings will likely total zero. Jim I am sending Klaus the $0.50 in the Berle trophy!! (Sorry...a private Tehachapi Soaring joke) Paul ZZ |
"Charles Crosby" wrote in message
... Greg Arnold wrote: When you are cruising at 20,000' to 30,000', doesn't the effect of altitude cause IAS to be substantially less than ground speed? That is indeed true. However, there are aeroelastic concerns (such as flutter) which may result in a lower indicated vne at high altitude. Charles http://home.comcast.net/~johan.larso...ride-home.html The Long Ride Home Harold Peterson This article originally appeared in the August 1, 1966 issue of Sports Illustrated. David Stevenson provided the issue of SI for scanning. ' "We're plagued with people who want to emphasize the danger," George said. "Just flying a sailplane around is safer than power flying. One fundamental safety factor is the soft landing. You have marvelous control-anywhere between a 40 degree approach with full dive breaks to 3 degrees with none. In contest or record flight, of course, you're definitely stretching a little. On a glide you may easily reach 150 mph where the placard speed is listed at 86." Placard speed is that beyond which the manufacturer makes no guarantee that things will not start coming off. ' [Quoting George Moffat. G.T.] -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
Has this flight been posted anywhere? I did not find it on OLC.
Tim |
On Dec 22, 7:57 pm, "Paul Remde" wrote: "Today, Dec 22nd 2006 at 1:00 AM UTC, Klaus Ohlmann called me on the phone just after landing to let me know he have made a 500 Km flight at 306 km/h on average in a Nimbus 4DM... this could be the first above 300 km/h and for far, the fastest glider flight made under FAI rules." So I was poking around on OLC and found a number his flights. On Dec 22, he did fly, but it was a 1000 km triangle attempt that he abandoned. Was the flight on a nother day? I found his other two claimed flights as reported by the FAI below. Congratulations! FAI has received the following Class D (Gliders) record claims : ================================================== ================== Claim number : 14380 Sub-class DO (Open Class Gliders) General Category Type of record : Speed over a triangular course of 100 km Course/location : Zapala (Argentina) Performance : 289.7 km/h Pilot : Klaus OHLMANN (Germany) Crew : FECHINO Esteban (Argentine) Glider : Schempp-Hirth Nimbus 4 DM Date: 18.12.2006 Current record : 249.09 km/h (01.12.2003 - Horacio MIRANDA, Argentina) ================================================== ================== Claim number : 14381 Sub-class DO (Open Class Gliders) General Category Type of record : Speed over an out-and-return course of 500 km Course/location : Zapala (Argentina) Performance : 275.8 km/h Pilot : Klaus OHLMANN (Germany) Crew : JANSEN David (Australia) Glider : Schempp-Hirth Nimbus 4 DM Date: 16.12.2006 Current record : 247.49 km/h (03.03.1999 - James M. PAYNE, USA) ================================================== ================== -Tom |
To average 306 he certainly exceeded that speed for much of the flight.
I too would like to understand the mods and the risk analysis for this flight. "Marc Ramsey" wrote in message m... Soarin Again wrote: At 05:42 23 December 2006, Js wrote: 306 km/hr = 190 mph = 165 knots That is an amazing feat! Yes, it is. Anyone trying to beat that record should be certain their parachute is in good shape, as the number of wings will likely total zero. Jim Does anyone know if his Nimbus 4DM has had special modifications to increase the vne at altitude, or does he just not care about operating limitations? 306 km/hr true airspeed is 200 to 220 km/hr IAS at the 20000+ foot altitudes used for these wave flights. Some gliders do require a reduction in Vne at higher altitudes, but it isn't necessarily the case that the limitation was exceeded. Marc |
On Fri, 29 Dec 2006 08:18:52 -0600, "SAM 303a"
brentDAHTsullivanATgmailDAHTcom wrote: To average 306 he certainly exceeded that speed for much of the flight. I too would like to understand the mods and the risk analysis for this flight. Klaus if flying a company-modified Nimbus 4 DM which allows a Vne of 260 km/h IAS at 6.000 meters. 260 kp/h IAS at 6.000m = 350 kp/h TAS. Bye Andreas |
Cool.
He probably bumped that limit a few times too, but I suppose that's what limits and record-setting flights are all about. "Andreas Maurer" wrote in message ... On Fri, 29 Dec 2006 08:18:52 -0600, "SAM 303a" brentDAHTsullivanATgmailDAHTcom wrote: To average 306 he certainly exceeded that speed for much of the flight. I too would like to understand the mods and the risk analysis for this flight. Klaus if flying a company-modified Nimbus 4 DM which allows a Vne of 260 km/h IAS at 6.000 meters. 260 kp/h IAS at 6.000m = 350 kp/h TAS. Bye Andreas |
Andreas Maurer schreef: On Fri, 29 Dec 2006 08:18:52 -0600, "SAM 303a" brentDAHTsullivanATgmailDAHTcom wrote: To average 306 he certainly exceeded that speed for much of the flight. I too would like to understand the mods and the risk analysis for this flight. Klaus if flying a company-modified Nimbus 4 DM which allows a Vne of 260 km/h IAS at 6.000 meters. 260 kp/h IAS at 6.000m = 350 kp/h TAS. Bye Andreas Can you explain which mods have been done? Shortened wingtips and strengthened tail boom? |
#29
On 30 Dec 2006 07:53:43 -0800, "J. Nieuwenhuize"
wrote: Can you explain which mods have been done? Shortened wingtips and strengthened tail boom? No idea - I'm pretty sure an email to Shempp Hirth will clear matters. Probably simply stiffer wings/wing flaps. Bye Andreas |
#30
On Fri, 29 Dec 2006 16:16:52 -0600, "SAM 303a"
brentDAHTsullivanATgmailDAHTcom wrote: Cool. He probably bumped that limit a few times too, Bold statement. Do you have *any* proof at all...? Bye Andreas |
| Thread Tools | |
| Display Modes | |
| Question, Diamond distance as unsuccessful triangle. | Roger | Aviation Marketplace | 1 | November 22nd 04 08:34 PM |
| Question, Diamond distance as unsuccessful triangle. | Roger | Soaring | 1 | May 13th 04 02:31 AM |
| Argentina ! | Frank Noort | Military Aviation | 0 | January 27th 04 10:47 PM |
| Flying in Argentina | Jay | Soaring | 1 | November 25th 03 05:52 AM |
| new records (Out&Return) for Delore-Fossett in Argentina | cernauta | Soaring | 0 | November 17th 03 03:06 PM |
