Green Arc Red Zone
Old December 26th 06, 07:04 PM posted to rec.aviation.piloting
Bob Moore
Default Green Arc Red Zone
Morgans wrote
So, fixing the mounts and stiffening the wings was the only thing that
was changed; no different operating procedures?
The "old" Electras that I flew at Air Florida did have a speed limit
imposed by the FAA. I have forgotten just what it was...34 years ago.
Bob Moore
Old December 26th 06, 08:45 PM posted to rec.aviation.piloting
Scott Skylane
Bob Moore wrote:
The Electra (L-188) engine (Allison) always turned at 1061 RPM except at
ground idle. It had no Prop Control.
C'mon Bob, I seriously doubt the *engine* ran at 1061 RPM!
Happy Flying!
Scott Skylane
Old December 26th 06, 09:28 PM posted to rec.aviation.piloting
Morgans[_5_]
"Scott Skylane" wrote in message
Why not? It is a turbine engine, after all.
Old December 26th 06, 09:36 PM posted to rec.aviation.piloting
Matt Whiting
That would make it even more surprising. That would be extremely slow
for a turbine. It isn't bad for a large piston engine, but still on the
slow side.
Matt
Old December 26th 06, 09:40 PM posted to rec.aviation.piloting
Al G[_1_]
Happy Flying!
Scott Skylane
Well, the output shaft & prop did. As I remember there was about an 11:1
reduction from the turbine.
Al G
VP-48 Crew 6 Moffat/Adak/Agana
Old December 26th 06, 10:02 PM posted to rec.aviation.piloting
Morgans[_5_]
"Matt Whiting" wrote
That would make it even more surprising. That would be extremely slow for
a turbine. It isn't bad for a large piston engine, but still on the slow
side.
Note to self: remove egg from face. g
I finally saw it. I was looking at it and sseing 10,610 RPM, or something
like that.
Perhaps that is prop speed, at 1,061 RPM ?
Old December 26th 06, 10:19 PM posted to rec.aviation.piloting
Matt Whiting
side.
like that.
That would make a lot of sense. 1,000 RPM for a large prop would be
plenty fast.
Matt
Old December 26th 06, 11:32 PM posted to rec.aviation.piloting
Ross[_1_]
john smith wrote:
Jack Allison's discussion of the Hartzell AD for his Arrow has gotten me
to thinking.
What aircraft do you fly/have you flown/do you have first hand knowledge
of which have a red zone somewhere in the green arc of the tachometer?
For example, I know there are/were certain models of Cessna 210's that
had such markings, but I cannot remember the specific models/engine/prop
combinations.
I have a modified Cessna 172 with the Lycoming O-360-A1A engine and
Hartzel prop. I have a redline limitation between 2100 and 2250 rpm.
Really stinks.
Regards,
Ross
C-172F 180 hp
KSWI
  #29
Old December 27th 06, 04:36 AM posted to rec.aviation.piloting
john smith
Although there is red marking in the green arc, the POH for the 1979
Piper Turbo Arrow IV/PA28RT-201T, the LIMITATIONS SECTION lists the
following placards:
AVOID CONTINUOUS GROUND OPERATION 1700-2100 RPM IN CROSS/TAIL WIND OVER
10 KTS.
AVOID CONTINUOUS OPERATION 2000-2200 RPM ABOVE 32" MANIFOLD PRESSURE
I believe this applies to the two-bladed prop only and not the
three-bladed prop, but I can find nothing in the manual to support this
theory. I do not find the placards on the panel of the aircraft I fly
which has the three-bladed prop.
These two lines in the LIMITATIONS SECTION are the only place in the
POH which mention this condition.
  #30
Old December 27th 06, 01:54 PM posted to rec.aviation.piloting
Bob Moore
Obviously.... :-)
Bob Moore
Verdant green... Jay Honeck Piloting 17 July 9th 06 06:58 AM
Military Green Laser Pointer [email protected] Naval Aviation 0 July 5th 05 06:42 PM
Simple Green Pirep JJS Owning 13 May 19th 05 03:35 AM
I am in The Killing Zone Marco Rispoli Piloting 68 June 14th 04 05:16 PM
Garmin gpsmap 76s airspace zone home made maps (follow up) Gilles_Sauvagnat Soaring 0 May 13th 04 08:41 PM
