707 does a roll -- video
Old January 5th 07, 11:32 PM posted to rec.aviation.piloting
mike regish
Default 707 does a roll -- video
Did I hear him call it a chandelle?
mike
"Dudley Henriques" wrote in message
It was a barrel roll BTW, NOT an aileron roll, in case anyone ever asks
you. He had to keep positive pressure in the oil system.
Dudley Henriques
Old January 5th 07, 11:35 PM posted to rec.aviation.piloting
mike regish
Is it truly an entirely 1 g maneuver? It seems like you would have to pull
1+ G's at the end. The nose goes down and has to be pulle dback up, no?
mike
Well....you can do a barrel roll all the way down to 1g if you have the
right parameters set up and execute properly. As near as I can figure, to
set this up for the 380 you would need about all the sky you could get
both under you and around you!!!:-))
Dudley Henriques
Old January 6th 07, 12:29 AM posted to rec.aviation.piloting
Dudley Henriques
No it's not entirely a 1g maneuver. This comes up from time to time.
The entry to the roll initiation can either be considered or not considered
as part of the maneuver. Usually, in the classic sense at least, the entry
to the roll initiation point is considered as part of the maneuver. In this
case, you have to pull above 1g leaving level flight and as such, the g
during this phase of the roll has to be above 1g naturally.
If you have to dive to gain entry airspeed as is the case in low powered
airplanes like say a clipped winged Cub for example, the climb phase into
the roll from the entry airspeed point is also above 1g. Also, if the roll
is done in a way that requires the aircraft to be returned to level flight,
the exit phase as the nose comes back to level flight will also be above 1
g.
I should be a bit more clear when I speak peripherally on barrel rolls, as
many pilots consider them only from the level flight to level flight
scenario; where as in reality, a barrel roll can be performed from almost
any attitude of flight; most of these not requiring a return to level flight
at all....and subsequently not requiring higher entry and exit g.
When I speak of barrel rolls, I should specify that I'm not speaking of the
classic barrel roll entry and exit.
I speak ONLY of the part of the roll beginning at the initiating point where
the aircraft begins it's path through 3 dimensional roll. Because this point
can be executed from various attitudes of flight, it is this point that I
describe as being capable of being performed at various levels of positive g
down to 1g.
In other words, I only consider the aircraft in barrel roll when the flight
path is transitioning through 3 dimensional flight. I use this analogy
because in actuality, a barrel roll can be initiated from flight attitudes
other than from the classic level flight entry.
The actual roll can be performed as loosely down to 1g (I've even done them
completely unloaded) or as tight (higher positive g) as the aircraft's roll
axis through 3 dimensions will allow (in a fighter for example...a vector or
lag roll)
To clarify on your point; if a barrel roll is started from level flight and
ended at level flight, the entry and exit flight path will indeed require
positive g above 1.
Dudley Henriques
"mike regish" wrote in message
mike
Dudley Henriques
Old January 6th 07, 12:33 AM posted to rec.aviation.piloting
Dudley Henriques
It was a true barrel roll. He had to keep pressure in the scavenger pumps
and this required positive g all the way around. The g was above 1 going in
and back to level flight and at 1 through the roll. (through the roll BTW is
where I describe barrel rolls)
Dudley Henriques
mike
Dudley Henriques
Old January 6th 07, 12:42 AM posted to rec.aviation.piloting
Margy Natalie
Jay Beckman wrote:
"Danny Deger" wrote in message
http://www.orizzle.com/htm/v/020.htm
Danny Deger
I'm fairly certain that this is the actual airframe:
http://www.pbase.com/flyingphotog/image/59871070
It spent 30+ years at AMARC in Tucson, AZ before being "unpickled" and flown
to Seattle for restoration...then flown to the NASM UH Center.
Jay B
You were at Hazy in May and didn't look me up!?!?!
You can tell it's a 50's airplane just by the paint colors ;-}
Margy
Old January 6th 07, 01:35 AM posted to rec.aviation.piloting
Jay B
Danny Deger
Jay B
I could swear I "Pinged" you in advance. I seem to recall you were up
to your eyeballs in something at that time. If my travel plans for
this coming May match last May, I'll probably be able to visit again.
Air Deco? :O)
Jay B
Old January 6th 07, 01:46 AM posted to rec.aviation.piloting
Dudley Henriques
"Jay B" wrote in message
Danny Deger
flown
Jay B
Air Deco? :O)
.......and don't forget pegged wheelpants!!!
Dudley Henriques
Old January 6th 07, 01:49 AM posted to rec.aviation.piloting
Danny Deger
Yes he did. I don't understand why he said that. Maybe he did a chandelle
before he did the barrel roll and it didn't make the video
Danny Deger
  #29
Old January 6th 07, 02:25 AM posted to rec.aviation.piloting
Matt Barrow
Had a Q&A once as a guest speaker on aviation with a troop of Cub Scouts.
One of them asked me what Orville and Wilber Wright were REALLY like!!!!!!
When you flew during the war, was it the blue or the grey?
Matt
Matthew W. Barrow
Site-Fill Homes, LLC.
Montrose, CO (MTJ)
  #30
Old January 6th 07, 02:52 AM posted to rec.aviation.piloting
Dudley Henriques
"Matt Barrow" wrote in message
like!!!!!! :-))
PLEASE Matt!!! Try to be "CIVIL" here :-)))))
Dudley Henriques
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 May 1st 04 08:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 April 1st 04 08:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 March 1st 04 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 February 1st 04 07:27 AM
