#21
http://www.teslamotors.com/
Theres no soul to me in that, its batteries that make it go... theres no mechanical engineering there (don't take that too literally), but in an IC engine there's movement theres combustion, there's things spinning about, in this electric motor things just are. The brilliance of it, the raw humanity behind it isn't there anymore... it's just a high tech toy. |
On Tue, 9 Jan 2007 18:12:31 -0600, "Danny Deger"
wrote in : I think the 75 hp for an hour is very close. Not enough for an airplane in my opinion. How much horsepower does a Cessna 150 equipped with a Continental O-200 power plant develop at 75% cruise power? Take a look at the chart here http://www.teslamotors.com/performance/performance.php, and notice that at ~8,000 RPM the Tesla electric motor will develop nearly 200 Hp. Now what's your opinion? |
On 9 Jan 2007 17:14:14 -0800, "
wrote in .com: http://www.teslamotors.com/ Theres no soul to me in that, its batteries that make it go... It's true, that petroleum was once alive (I'll leave the soul aspect to those who have been inculcated to need religiosity), but lithium batteries are the child of man's genius none the less. theres no mechanical engineering there (don't take that too literally), but in an IC engine there's movement theres combustion, there's things spinning about, According to information at the link above, there are about 100 "things" moving. That's one hundred times more opportunity for an internal combustion engine part to fail in flight. Or don't you find that fact significant? in this electric motor things just are. Right. One moving part, the rotor. The brilliance of it, the raw humanity behind it isn't there anymore... it's just a high tech toy. The romance is a subjective point of view. If one is a machinist, s/he probably shares your view. If one is an electrician or EE, s/he sees the beauty of simplicity and efficiency. But I understand what you mean. It's like comparing a player piano to an electronic keyboard. Something is lost to progress. |
"Larry Dighera" wrote in message
... On Tue, 09 Jan 2007 18:20:07 GMT, "Neil Gould" ... Perhaps the Tesla roadster doesn't need to develop 75 Hp during it's entire run time, and there's the issue of regenerative braking, but these things are not germane to electrically powered aircraft which typically must produce 75% rated Hp continuously in cruise flight. Unlike automobiles, aircraft not only require motive power to propel them forward, but they are not afforded the luxury of a roadway to support their weight, and I would presume aircraft drag is considerably more than an automobile. That's probably not a good assumption. From http://www.t18.net/resources/T-18%20orig%20hdbk.doc page 34 An O-290 Powered T-18 can get 20+ miles per gallon at 170+ mph true air speed Not many gasoline powered cars can match this. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
Actually, aircraft (specifically motor gliders) are far ahead!
See: http://www.nadler.com/public/Antares.html It might take a little while before the power efficiency of batteries equals the needs of a useful airplane... Kirk 66 |
Larry Dighera wrote:
If an aircraft were covered in Spectrolab* triple-junction solar cells, fuel would be free during the daylight, quiet, and pollution free. You get something like 1 kW/m^2 of energy from the sun under good conditions, like being on the equator on a clear day in the summer. I think current PV cells are somewhere around 10% to 15% efficient, so that's 100-150 watts per square meter. Google says a Cessna 182 has about 16.2 m^2 of wing area, so you might get around 1.6-2.4 kW from solar cells covering the wings. You'd get a little more from the rest of the skin, but IMHO probably not more than 50% additional, or 2.4 to 3.6 kW. That's 3.2 to 4.8 hp that the cells are contributing. Also, does the solar cell factory run on solar cells? What is the weight of the Continental O-200 complete with its manifolding, muffler, oil, and fuel? http://en.wikipedia.org/wiki/Continental_O-200 says about 170 lbs (77 kg) dry for just the engine. For an electric drive, in addition to the weight of the motor and batteries, you'll also need to figure in the weight of the inverter that changes DC into three-phase AC. Some of these inverters are air-cooled and some are liquid-cooled. http://www.wired.com/news/wiredmag/0...l?tw=rss.index Tesla has managed to produce an impractical and exorbitantly expensive vehicle just as a revolutionary new battery has appeared on the scene. I've only been involved in hybrid cars for about six years, but I've already seen a few "revolutionary new batteries" come and go. Many of these batteries turn out to be quite good at ensuring a steady flow of press releases out and money in, but never quite manage to push any actual electrons. Matt Roberds |
"things" moving. That's one hundred times more opportunity for an internal combustion engine part to fail in flight. Or don't you find that fact significant? Thats the brilliance of it... theres hundreds of moving parts, it's by no means efficient or refined, yet there are more incidents and accidents cause by the failure of natures most sofisticated creature at piloting the plane than there are incidents and accidents caused by the brute under the cowling. |
"things" moving. That's one hundred times more opportunity for an internal combustion engine part to fail in flight. Or don't you find that fact significant? I don't think my last post went through correctly so here it goes again... The brilliance of those hundreds of moving parts that fail is just in the fact that they hardly ever do... pilots and humans, some of the most sophisticated animals nature has created fail more often than engines do, the simplicity of the electric motor won't get rid of those accidents. |
#29
On Tue, 09 Jan 2007 10:19:00 -0600, James Robinson wrote in : Larry Dighera wrote: "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote: Larry Dighera wrote: http://www.teslamotors.com/ Well they say the motor weighs 70 pounds and produces 248 HP but I can't find anything about the weight of the batteries. Total weight is indicated as ~2,400 lbs (including air conditioning). Given its 1:10 power to weight ratio, I'd say, if it had wings instead of the beefy structure it requires to meet road safety standards, it would fly. It wouldn't require any fuel. Recharges fully in 3.5 hours. The batteries weigh 900 lb., and put out 75 HP for an hour. I didn't see those numbers on the Tesla Motors web site. Have you got a source for that information? There is a chart here, but it is more about marketing than engineering: http://www.teslamotors.com/performance/performance.php Your numbers seem to conflict to some degree with these: http://en.wikipedia.org/wiki/Tesla_Roadster#Battery Battery: 6,831 Lithium ion battery cells About 450 kg Full-charge time of three and a half hours ~56 kWh capacity The conversion factor for kg to lb is 2.205, so 450 kg is 992.25 lb. Therefore, it's actually closer to 1,000 lb. of batteries, according to those specs. The conversion factor for kWh to HP-hr is 1.34, so 56 kWh is the equivalent of 75.04 HP-hr Here is the page on the Tesla Motors web site that I found the comment that the batteries weighed 900 lb. http://www.teslamotors.com/blog1/ind...9&js_enabled=1 I found the 56 kWh number on another page, and simply converted it to horsepower, since those are the units that most GA pilots would be familiar with. You wouldn't get too far on that in a C150. With a C-150 gross weight of ~1,600 lbs, it's considerably lighter than the Tesla Roadster. But an aircraft wouldn't require many of the car's systems such a transmission, electric windows, heavy running gear (springs, 17" wheels and tires, disk brakes, power assist steering, etc), and the Tesla motor weighs less than 70 lbs. What is the weight of the Continental O-200 complete with its manifolding, muffler, oil, and fuel? Well, let's look at some numbers. A gasoline aero engine of that size is typically about 2 lb. per HP, so a 100 HP engine would weigh about 200 lb. I believe the O-235 is listed at 215 lb., with supplies, so it's in the ballpark. In comparison, three phase motors typically weigh about 1 lb. per horsepower. That would mean a 100 hp motor would weigh about 100 lb. I suspect that the Tesla's motor weighs less, because it is rated for less continuous duty than would be necessary on an aircraft. An automobile engine practically loafs along when on the highway at constant speed, and only needs to have power for short bursts of speed. An aircraft engine, on the other hand, operates at high power for hours on end. The fuel and tanks would also be unnecessary with an electrically-powered aircraft. A typical C-150 has something like a 26 gallon capacity. At 6 lb. per gallon, that would be 136 lb. Add roughly 20 percent to that to account for the weight of the tanks, or 27 lb, for a total of about 165 lb. for the fuel plus the tanks. The grand total being 215 + 165 = 380 lb. Some additional amount could be added for fuel lines, filters and pumps, but they would be relatively small. As a round number, lets say everything weighs 400 lb. So, if we take out the IC engine, and replace it with the batteries used in the Tesla, and an appropriate electric motor, we would take out 400 lb., and add 900 plus 100 lb. for the batteries and motor, assuming the ligher weight, plus some additional for the electrical control system an wiring. Even without the control system, we would have a net gain in weight of about 600 lb. Considering that a C150 has a usable capacity of only 370 lb. or so with full fuel, The electically-powered aircraft would already be more than 200 lb. overloaded, and we haven't even considered the pilot, passenger, or baggage. Doesn't sound too practical, does it? |
#30
Electrically powered vehicles are the only hope to reduce the transfer of wealth from the western world to the middle east, and reduce global warming. If the US doesn't find some breakthrough technology soon, we'll all be speaking Farsi before long. :-( There are alternatives that are perfectly practical, and technically feasible. They just aren't economic, or any better environmentally. One of the closest is the liquafaction of coal. We have vast supplies in North America, and it is a relatively straight-forward process to convert it to liquid fuel. (see the Fischer-Tropsch process) The Germans and South Africans used synfuels made from coal when they couldn't get cheaper petroleum products. They worked well. There are a number of environmental issues, but the biggest problem is that fuel produced from coal is somewhat more expensive than petroleum based fuels, and few will pay extra for them. OPEC knows how much synfuels are to make, and they carefully keep the price of crude below those costs, so there is little risk of a competitive supply. |
Contact Approach -- WX reporting | [email protected] | Instrument Flight Rules | 64 | December 22nd 06 01:43 PM |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | June 2nd 04 07:17 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
