#21
![]() Tri-Pacer wrote: FSDO is not in the loop anymore as all field approvals go right to OKC now. Really ???? What FSDO do you work under? The administrative policy has changed. This is really just an extension of the changes that took place a few years ago when everybody was whining about how hard it was to get field approvals. |
![]() Newps wrote: Yes, last year. As of the last few weeks local FSDO's are out of the loop. All 337's go to OKC now and are not reviewed for airworthiness. Can you provide a citation for this, pls? It seems odd that the OP is still having discussions with avionics shop about getting field approvals when the procedure has changed. They obviously don't know about it... |
![]() Tri-Pacer wrote: Really ???? What FSDO do you work under? Here's some discussion of this subject from the Beech Owners email list. BB, I believe it has *always* been at the IA's discretion to make major alterations. The rub is that major alterations require approved data. The IA signature on a Form 337 means that the IA has inspected the alteration and found that it conforms with the approved data referenced in the Form 337. The IA has no authority to approve the data -- only an FAA employee or DER can do that. I suspect what's going on here is that FSDO folks are getting out of the data approval business, and that all alterations for which approved data does not already exist (e.g., STC) will require hiring a DER to approve the data. Essentially, approval of data will become something you pay for instead of getting free. (Nothing's free, but you know what I mean.) IMHO the loss of the FSDO proofreading function for Form 337s is no loss at all. Hopefully IA's are smart enough to figure out how to fill out a Form 337 properly without help from the FAA. (Somehow, I don't think safety is improved materially when a FSDO inspector kicks back a Form 337 for a sun visor installation because it doesn't have Instructions for Continuing Airworthiness in the proper 18-item format.) Maybe having to hire a DER for what amounts to a field approval is not such a bad idea. The DER will charge a fee for his services, but at least it won't be a guaranteed "no" (which is pretty much what most FSDOs have been doing on field approval requests in recent years). In my view, the more maintenance- and certification-related functions that can be transferred from FAA to the private sector (designees, etc.), the better. They'll cost money, but at least they'll get done. (No, I'm not in favor of privatizing ATC. g) At 06:39 PM 1/7/2007, Bob wrote: Since the FSDO has been eliminated, could it then be construed as at the signatory IA's discretion to make major alterations? BB: ----- Original Message ----- From: "carmine" carminefp at comcast.net To: "Beech-Owners at Beechcraft. Org" beech-owners at beechcraft.org Sent: Sunday, January 07, 2007 5:48 PM Subject: B: 337 Attended an IA seminar this weekend here in the Seattle area and the FSDO people made it very clear that 337's go toOklahoma and not to them. They will accept those 337's that have a cover letter asking if it's correct and acceptable. They said that Oklahoma will not be critiquing them at all. Mentioned in the past they found errors in 25 to 50 percent of those submitted locally in any given year. Cy, where did you get that impression? The change to Part 43 Appendix B which calls for Form 337s to be sent directly to OKC instead of to the local FSDO makes no distinction between 337s for major repairs and major alterations. All 337s are to be sent directly to OKC after signed off by the inspecting IA. As always, the IA may only sign the 337 if it references approved data. If the data is not approved per STC or something similar, approval of the data must be secured (from the FAA or a DER) *before* the IA signs the 337. Once the IA signs the 337, it now gets submitted directly to OKC. The FAA recently unveiled a new system whereby 337s may be filled out online and submitted electronically to OKC, which sounds to me like a huge improvement (at least in terms of 337s getting lost in the system and never showing up in the aircraft records at OKC). At 08:08 PM 1/7/2007, cgalley wrote: I believe these 337s are only for repairs not alterations. ----- Original Message ----- From: "Bob" parair at ca.rr.com To: beech-owners at beechcraft.org Sent: Sunday, January 07, 2007 8:39 PM Subject: B: 337 Since the FSDO has been eliminated, could it then be construed as at the signatory IA's discretion to make major alterations? Cy, an IA has always been able to approve a major alteration. He has never been able to approve the data for a major alteration -- only an FAA employee or DER can do that. Approval of data by the FAA or a DER must be done BEFORE the IA signs off the 337, not after. I think we have a terminology problem here. A major repair or major alteration requires two approvals -- approval of the data and approval of the work. An IA has never been permitted to do the former, and has always been permitted to do the latter. There is no change in that regard. The only purpose for the FSDO to look at a Form 337 *after* the IA signs it (approving the work) is for proofreading purposes, not approval purposes. Under the new rule, FSDOs are getting out of the proofreading business. --Mike At 08:35 PM 1/7/2007, cgalley wrote: But the IA can't approve an alteration. Maybe the person that said you have to "buy" an alteration thru a DER or DAR is right. |
![]() BB, I believe it has *always* been at the IA's discretion to make major alterations. The rub is that major alterations require approved data. Well, quite. If the alteration has approved data (eg. an STC) then the IA can sign the 337, and he then sends it straight to OK City. But if he merely has acceptable data, the most common route open to him is a Field Approval whereby he sends that data with a 337 to the FSDO, and gets them to turn that into approved data by stamping it and signing the magic box. The IA can then sign the form after completion, and send it off to OK City for filing. But that still means that the FSDO is involved in the Field Approval process. Do you still assert the Field Approvals do not involve a FSDO and go straight to OK City??? |
![]() Mike Granby wrote: Newps wrote: Yes, last year. As of the last few weeks local FSDO's are out of the loop. All 337's go to OKC now and are not reviewed for airworthiness. Can you provide a citation for this, pls? It seems odd that the OP is still having discussions with avionics shop about getting field approvals when the procedure has changed. They obviously don't know about it... Well hey, it's the Government. The memo probably hasn't made it all around the country yet. |
![]() Mike Granby wrote: BB, I believe it has *always* been at the IA's discretion to make major alterations. The rub is that major alterations require approved data. Well, quite. If the alteration has approved data (eg. an STC) then the IA can sign the 337, and he then sends it straight to OK City. But if he merely has acceptable data, the most common route open to him is a Field Approval whereby he sends that data with a 337 to the FSDO, and gets them to turn that into approved data by stamping it and signing the magic box. The IA can then sign the form after completion, and send it off to OK City for filing. But that still means that the FSDO is involved in the Field Approval process. Do you still assert the Field Approvals do not involve a FSDO and go straight to OK City??? Yes, the FSDO's are being directed not to approve data unless it's something that's pretty simple, stuff that is probably a minor alteration in the first place. What they really seem to be saying is we don't have the expertise in the field anymore so send it to our engineers in OKC or get your own DER. Which I think in the end is good. This should create a demand for DER's which will mean more of them and known stable prices. |
Folks,
Help me understand the most basic alteration/modification/addition. This "simple" category. Some conclude this device fits that category. If my IA determines that screwing a bit of plastic onto the instrument panel (using the existing mounting rails with approved hardware) constitutes nothing more than a minor alteration, can he simply make a logbook entry and sign it off? What other paperwork must he execute, if any? Once done, what happens wan an FAA critter with an attitude problem at some remote airport where I am not based comes along, peeps in the window and says "where is your paperwork for this thing"? I don't carry my logbooks. What do the regs say I have to do (produce) right there and then? Providing I follow the rules (which you just told me), what can the FAA person do according to the regs? Where possible, please point me to the chapter and verse. Where impossible, please let me know why you reached a conclusion where the regs are nonexistent or vague. Thanks, Mike |
panel (using the existing mounting rails with approved hardware) constitutes nothing more than a minor alteration, can he simply make a logbook entry and sign it off? What other paperwork must he execute, if any? Mike, I can't quote you chapter and verse -- but I know a guy who *can*. Call Tony, at McCandless Aviation in Waterloo, Iowa. He's the head of their avionics shop, and he did my installation with a logbook entry. His number is 319-232-1234 Once done, what happens wan an FAA critter with an attitude problem at some remote airport where I am not based comes along, peeps in the window and says "where is your paperwork for this thing"? I've only been ramp-checked once, but the FAA dude was only concerned about your paperwork (pilot certificate, medical) and the aircraft's basic paperwork (airworthiness cert, etc.). At no time did the guy even look at the panel, other than when he looked in the plane at me and Mary. I have a hard time imagining a situation where an inspector starts asking for STC and field approval paperwork on stuff like the AirGizmo. Hell, it would take me three hours just to show him the paperwork on all the other mods on my plane. (Let's see, wing tips, wing fillets, landing lights, flap gaps, aileron gaps, fancy pants...shoot, I'm up to three hours already!) IMO, you'd have to really pee in someone's Wheaties to get ramp checked THAT hard. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#29
![]() Mike Spera wrote: If my IA determines that screwing a bit of plastic onto the instrument panel (using the existing mounting rails with approved hardware) constitutes nothing more than a minor alteration, can he simply make a logbook entry and sign it off? That is, by definition, a minor alteration. And that is all that is required for a minor alteration. What other paperwork must he execute, if any? None. Once done, what happens wan an FAA critter with an attitude problem at some remote airport where I am not based comes along, peeps in the window and says "where is your paperwork for this thing"? Nothing happens. If he asks tell them your mechanic signed it off as a minor alteration. If he wants to look at the loogbooks the regs say they have to contact you and you two make an appointment and he can look at the logs. I would think that if you have an electronic version, I scan all mine into PDF's, you could just email them over there. I don't carry my logbooks. What do the regs say I have to do (produce) right there and then? Nuthin', relating to the maintenence. For a ramp check you have to have the AROW, just what you learned to be a private pilot. Providing I follow the rules (which you just told me), what can the FAA person do according to the regs? See above. And under no circumstances can he "ground" your plane. He can hang a tag on there stating he thinks something isn't airworthy. The most famous case is the FSDO inspector who did that on a Mooney with a Q Tip prop. But you determine if the plane is airworthy. Your mechanic is the one who gets to decide if the Air Gizmo is a minor alteration not the FAA. He may ask the FAA for guidance but when you read the mechanics bible not in a million years is the Gizmo a major alteration. Any IA who says so should lose his IA priveleges. |
#30
![]() Jay Honeck wrote: I've only been ramp-checked once, but the FAA dude was only concerned about your paperwork (pilot certificate, medical) and the aircraft's basic paperwork (airworthiness cert, etc.). At no time did the guy even look at the panel, other than when he looked in the plane at me and Mary. Along those lines find a time when the FAA is running the PACE program. This is where your local FSDO shows up at your airport and you can bring your plane and logs to them for them to inspect and they will tell you if they find anything they consider unairworthy or maybe a little suspicious. They will also inspect the plane and tell you what they think and you can also have the FSDO fly with you for an hour or so, basically give you a mini checkride. It's all nonadversarial. You can ignore what they say and fly away if you want but it's also a way to meet these people and find out they're just regular people. I did all that and pointed out all the stuff on my plane that comes up from time to time in these discussions. |
Garmin 496-XM Radio-PS Engineering Intercom Follow up... | Jay Honeck | Owning | 25 | December 9th 06 12:26 PM |
