Figuring out what affects my speed
Old January 20th 07, 06:53 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Default Figuring out what affects my speed
Duncan writes:
Temperature *and* pressure (ie what's the QNH?).
It was variable, being high in some spots and low in others along the
route. I couldn't tell if anything changed significantly as the
altimeter changed.
I will try some flights in warmer and clearer weather and see if I see
the same thing.
Old January 20th 07, 05:21 PM posted to rec.aviation.piloting,rec.aviation.student
Paul kgyy
The guts of it is: cold day and high pressure - you're getting a lot
more oxygen into the cylinders - vs a hot day and low pressue.
While the QNH along the route is variable, it generally doesn't vary
*much* - ie you get to another 'area' and it's an hectopascal or two up
or down. Presumably you were flying with a high QNH (well above STP
value which is 1013 hectopascals at 0' AMSL (1013.2 to be precise,
IIRC)).
Duncan
On the other hand, cold high pressure is usually descending air, so the
aircraft is sort of swimming upstream just to stay level.
Crosswind Landings... But airspeed? Jmarc99 Soaring 21 October 4th 05 07:54 PM
speed record set by scramjet - fair? Don French Piloting 55 November 28th 04 01:57 PM
Space Elevator Big John Home Built 111 July 21st 04 04:31 PM
Overweight takeoff / flight Koopas Ly Piloting 50 December 3rd 03 11:53 PM
