#21
![]() Try KBC Tools. They're on the 'Net, and have a full line of decimal reamers, which will fit almost any application. That said, I would chuck the UHMW in a four-jaw chuck on the lathe and turn the hole using a really sharp HSS bit. Dan |
![]() wrote in message ps.com... Try KBC Tools. They're on the 'Net, and have a full line of decimal reamers, which will fit almost any application. That said, I would chuck the UHMW in a four-jaw chuck on the lathe and turn the hole using a really sharp HSS bit. Dan No, ya got lost somewhere Dan. The question at this point is how do you resize a forstner bit by dressing it, and how could it possibly be the ideal bit to resize. |
![]() "Maxwell" wrote No, ya got lost somewhere Dan. The question at this point is how do you resize a forstner bit by dressing it, and how could it possibly be the ideal bit to resize. Turn down the outside, or grind down the outside. It is a relatively small height, and all solid, except for one or two small areas. -- Jim in NC |
"Morgans" wrote in message
... "Maxwell" wrote No, ya got lost somewhere Dan. The question at this point is how do you resize a forstner bit by dressing it, and how could it possibly be the ideal bit to resize. Turn down the outside, or grind down the outside. It is a relatively small height, and all solid, except for one or two small areas. -- Jim in NC You are talking about grinding the OD of one of these bad boys? http://www.woodcraft.com/family.aspx?familyid=8311 Larger pictu http://www.woodcraft.com/InhancedIma...?FamilyID=8311 -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
![]() "Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote in message news:faOdnWsiTthUryjYnZ2dnUVZ_qGjnZ2d@wideopenwest .com... "Morgans" wrote in message ... "Maxwell" wrote No, ya got lost somewhere Dan. The question at this point is how do you resize a forstner bit by dressing it, and how could it possibly be the ideal bit to resize. Turn down the outside, or grind down the outside. It is a relatively small height, and all solid, except for one or two small areas. -- Jim in NC You are talking about grinding the OD of one of these bad boys? http://www.woodcraft.com/family.aspx?familyid=8311 Larger pictu http://www.woodcraft.com/InhancedIma...?FamilyID=8311 -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. Thanks Geoff, that is the question on my mind too. If you could even find one that was 11/16, you would have to pull .030 per side off of it to get an oversized 5/8. If not, you would have to pull .060 per side off of a 3/4. I don't see how you could do it without a tool grinder. |
Maxwell wrote:
"Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote in message news:faOdnWsiTthUryjYnZ2dnUVZ_qGjnZ2d@wideopenwest .com... "Morgans" wrote in message ... "Maxwell" wrote No, ya got lost somewhere Dan. The question at this point is how do you resize a forstner bit by dressing it, and how could it possibly be the ideal bit to resize. Turn down the outside, or grind down the outside. It is a relatively small height, and all solid, except for one or two small areas. -- Jim in NC You are talking about grinding the OD of one of these bad boys? http://www.woodcraft.com/family.aspx?familyid=8311 Larger pictu http://www.woodcraft.com/InhancedIma...?FamilyID=8311 -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. Thanks Geoff, that is the question on my mind too. If you could even find one that was 11/16, you would have to pull .030 per side off of it to get an oversized 5/8. If not, you would have to pull .060 per side off of a 3/4. I don't see how you could do it without a tool grinder. If you own a bench grinder, drill press or dremel equivalent make a bracket out of sheet metal, phenolic or hardwood to hold the tool. It sounds a tad Rube Goldburgish but it can be done. I made a few for grinding lathe tools. In the case of a rotating bit you need symmetry as much as size. It seems to me you coulduse a wood block drilled to accept the tool shaft at one end and drilled to make a pivot point at the other. A simple stop like a machine screw could serve as an adjustable stop. Visit a machine shop some time, you'll see some rather clever widgets made for a one time use. You never know, they might have exactly what you are looking for. Dan, U.S. Air Force, retired |
![]() "Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote You are talking about grinding the OD of one of these bad boys? http://www.woodcraft.com/family.aspx?familyid=8311 Yep/ That's the type. Make a widget to hold a small angle grinder on its side, with a pivot and a screw for advancing the grinder a bit at a time. Make it so that it will work clamped to a drill press table. Put the drill bit in the drill press, and push the bit up and down past the spinning grinder. Advance the grinder a bit at a time, and stop to check the progress often. It works. I've done it before. I am a bit "Rube Goldbergish" at times. That comes in handy, for a homebuilder. Of course, if you know someone who works in a machine shop, he could do the job in a tenth of the time. Where's the fun in that, though? -- Jim in NC |
I have a bit of experience that bears directly on this topic.
A while back I made a bunch of linear guides for a control stick mechanism that used 5/8" steel push-pull tubes. I tried a bunch of materials before settling on Nylon. Anyhow, I found that in practice the smallest reasonable clearance hole for the 5/8" tube was 1/32" oversize - that's 0.656" decimal or 21/32" fractional. Any smaller, and the combination of crush and misalignment used up all of the margin and the tube would bind up in the guide. The 1/32" clearance didn't seem to add any appreciable slop to the system, and ran with reasoanbly low friction. Another thing to consider is the that a lot of these low-friction plastics have pretty steep thermal expansion curves. Also, some of them absorb water and swell up. If you have relatively low radial loads and you want really, really low friction, you can go with these low-cost 5/8" ID linear ball bearings from ACS: http://www.aircraftspruce.com/catalo...shrodguide.php I use a lot of them (copies of them, actually), and they're really sweet. Even with a 12-foot aluminum tube run through five of them, the friction is so low that the tube slides downhill under its own weight at angles as low as 2 degrees. Thanks, Bob K. http://www.hpaircraft.com/hp-24 |
#29
Oh, I forgot to mention:
In my experience, steel tubing tends to run a little larger than the nominal size. Commercial steel tube (the 1/16" wall stuff from the hardware store) tends to run around 0.020" over, 4130 tends to run about 0.010" over. That can make a big difference in hole clearances. Bob K. |
#30
![]() "Morgans" wrote in message ... "Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote You are talking about grinding the OD of one of these bad boys? http://www.woodcraft.com/family.aspx?familyid=8311 Yep/ That's the type. Make a widget to hold a small angle grinder on its side, with a pivot and a screw for advancing the grinder a bit at a time. Make it so that it will work clamped to a drill press table. Put the drill bit in the drill press, and push the bit up and down past the spinning grinder. Advance the grinder a bit at a time, and stop to check the progress often. It works. I've done it before. I am a bit "Rube Goldbergish" at times. That comes in handy, for a homebuilder. Of course, if you know someone who works in a machine shop, he could do the job in a tenth of the time. Where's the fun in that, though? -- Jim in NC I think you and Dan have had a little too much torpedo juice! |
Wire Strike Info | Ol Shy & Bashful | Piloting | 13 | August 18th 06 03:33 AM |
Helicopter Physics info online anywhere?? | [email protected] | Rotorcraft | 4 | April 24th 04 04:18 PM |
Mooney info | eddie | Owning | 13 | March 12th 04 06:42 PM |
POSA Carb Info and HAPI Engine Info | Bill | Home Built | 0 | March 8th 04 08:23 PM |
Starting new info site need info from the pros | MRQB | Piloting | 7 | January 5th 04 03:20 AM |
