FAA MAY TAKE AWAY PANEL-MOUNT OPTION FOR PORTABLE GPS
Old February 2nd 07, 02:28 PM posted to rec.aviation.piloting
Gig 601XL Builder
Default FAA MAY TAKE AWAY PANEL-MOUNT OPTION FOR PORTABLE GPS
Think your portable GPS would work great mounted to your old Cessna 172's
instrument panel? If the FAA has its way, you won't be able to mount it. The
parts-panel dock and connective wiring-needed to mount your portable GPS
would either no longer be available or be too expensive to buy. The FAA's
proposal would make it illegal for manufacturers to produce a replacement or
modification part if they know (or should know) the part would end up
installed in a certified aircraft-that is unless they obtain production
approval from the agency. But that costs tens of thousands of dollars,
something many companies can't afford. While AOPA agrees production approval
is necessary for critical parts like connecting rods and cylinders, it isn't
needed for non-critical parts like a portable GPS panel dock or traffic
detector that enhance pilot safety. See AOPA Online.
Softcomm panel mount intercom? Junk? [email protected] Owning 10 November 26th 05 06:46 AM
Panel mount for handheld Garmin GPSMap X96 series Brock Boss Owning 2 September 25th 05 01:26 AM
manual for garmin 100 panel mount. Ray Toews Home Built 1 September 11th 05 10:28 PM
Need panel mount for Delcom Radio Mark Lenox Soaring 3 June 24th 05 03:31 AM
Upgrade handheld GPS, or save for panel mount? [email protected] Owning 7 March 8th 04 03:33 PM
