On Feb 14, 7:06 am, Thomas Borchert
wrote: This happens with no scenery displayed (in the clouds). MSFS does calculate scenery even when showing whit. You need to turn down the detail level (and dynamic scenery - very important!). Also, check the realism settings. All but P-factor (totally unrealistic) should be high. -- Thomas Borchert (EDDH) I didn't know that scenery was still calculated even when not visible. I will dial everything down. Thanks! |
visible. I will dial everything down. Not all of it is, but some. E.g., the dynamic stuff is still calculated in the background in order to account for when a dynamic item will get close enough to be shown. Also, the cloud and scenery detail settings have an impact on how detailed the "fog" is shown, how detailed lighting effects and shadowing is. These all use a lot of CPU. And finally, even if you only see fog, the program might still "think" there is something vaguely visible through the muck - and that needs calculating, too. Oh, in case you're impressed by our resident non-expert - the above information is straight from members of the MSFS programming group, which I had the pleasure to talk to. -- Thomas Borchert (EDDH) |
On Feb 14, 5:02 pm, C J Campbell
wrote: On Tue, 13 Feb 2007 17:40:31 -0800, wrote (in article .com): On Feb 13, 7:22 pm, Mark Hansen wrote: You know using the autopilot in the simulator to just hold altitude is one thing I haven't thought about. The only autopilot I have in the 'real' plane is a single axis (heading only) which I'm not using while learning the rating. Very good idea! I would recommend becoming at least familiar with using it IFR. The examiner might expect you to use it, even. A little practice wouldn't hurt. -- Waddling Eagle World Famous Flight Instructor Actually I belong to a flying club. There are two planes that I will be using. A Warrior (no autopilot, no ADF, no DME, no GPS, no backup vacuum) and a Dakota (single axis autopilot, ADF, DME, Garmin 430 GPS, with backup vacuum). I will be using the Warrior for the check ride since no ADF means no ADF approaches ;-) After getting the rating I will probably be using the Dakota on real IFR trips just based on safety, but it's cheaper to practice in the Warrior. Plus I won't get spoiled using all those sophisticated avionics! |
avionics! Do practice GPS approaches, and all approaches with the Garmin. If you are not familiar with the box, it -will- bite you. Jose -- Humans are pack animals. Above all things, they have a deep need to follow something, be it a leader, a creed, or a mob. Whosoever fully understands this holds the world in his hands. for Email, make the obvious change in the address. |
avionics! Hmm. You won't learn how to use them, either. -- Thomas Borchert (EDDH) |
Mark Hansen writes:
Next, look into your graphics card. There may be upgraded drivers for it that will improve the performance. If not, you may want to look into a better graphics card. Flight simulators (including MSFS) are normally CPU-bound, so a faster graphics card may not make any difference. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Anyone know how to turn on the DME and set the freq? The HELP in
MSFS is completely useless, AFAIK. |
MSFS 2004 Video frame rate very slow | Greg Brown | Simulators | 1 | November 11th 05 07:24 PM |
Instrument training | xxx | Instrument Flight Rules | 79 | May 24th 05 11:04 PM |
Instrument training | xxx | Piloting | 82 | May 24th 05 11:04 PM |
"one-week" Instrument Training? | Rod S | Piloting | 7 | August 25th 04 12:03 AM |
Visual bugs in MSFS 2004 | [email protected] | Simulators | 1 | October 4th 03 06:34 PM |
