Wacko AI
Old March 2nd 07, 04:18 AM posted to rec.aviation.owning,rec.aviation.piloting
Mike Noel
Default Wacko AI
OK, we now know the problem was a pinched hose, but there is some
speculation that a failed vacuum pump can actually blow dust backwards into
the vacuum instruments. The idea is that residual vacuum at the instruments
allows the higher pressure at the failed pump to push the dust into the
vacuum instruments. There is an STCd filter that can be placed between the
instruments and the pump designed to prevent dust backflow if the pump
fails.
Best Regards,
http://photoshow.comcast.net/mikenoel
Time flies like an arrow, fruit flies like a banana.
"Morgans" wrote in message
"Dan Luke" wrote
Or the pump is shedding carbon and fouling the system?
Only if it is a pressure system, instead of a true vacuum system.
Instruments run off of vacuum so that any carbon or other debris from a
failed pump goes into the pump and out the exhaust, instead of into the
instruments or plumbing.
But you knew that and had a brain fart, right? g
Old March 2nd 07, 07:08 PM posted to rec.aviation.owning,rec.aviation.piloting
Morgans[_2_]
Default Wacko AI
"Mike Noel" wrote in message
into the vacuum instruments. The idea is that residual vacuum at the
instruments allows the higher pressure at the failed pump to push the dust
into the vacuum instruments. There is an STCd filter that can be placed
between the instruments and the pump designed to prevent dust backflow if
the pump fails.
I thought vacuum systems had a check valve that prevented backwards moving
air. No?
If not, it sounds like they should.
Old March 7th 07, 12:40 PM posted to rec.aviation.owning,rec.aviation.piloting
Ron
Default Wacko AI
My XP Hawk didn't have a filter upstream of the pump until I had to overhaul
the AH and DG, with carbon found in each instrument. I had a vac 'pump'
failure some time previously. Hopefully the filter doers the trick during my
next vac failure.
regards
Ron
dust into the vacuum instruments. There is an STCd filter that can be
placed between the instruments and the pump designed to prevent dust
backflow if the pump fails.
air. No?
Left Wing Wacko Defends Clinton/UN Bob McKellar Military Aviation 0 October 8th 03 02:44 AM
