#21
On Mar 6, 4:38 pm, "Bill Daniels" bildan@comcast-dot-net wrote:
"Tuno" wrote in message oups.com... This topic is most interesting. I was never taught the low tow, or presented with the concept at any of the 3 places I took lessons (Estrella, Seminole Lakes and Turf, 3 years ago). How is it easier for the glider driver? Wouldn't it create more work for the tug driver? Are there any enthusiasts of the low tow who are also enthusiasts of high wing loading for those good days? I've been in the "low tow" position unintentionally at max wing loading when the tug driver musta thought he was pulling a 2-33. Seems like there would be no room for error if one started out in that position, and the tug then slowed down! ~ted/2NO I probably flew hundreds of low tows at the old El Mirage Field. Gus Brigleib insisted on low tow. If you are flying a low performance glider, the technique for slack is to just push the nose lower. The glider will just move down and take the slack out. If, however, you are flying a Nimbus, it will outrun the tug pasing under it. Pulling up puts in more slack even as the glider slows down ending in a jerk. In the end, I suspect the reason Gus insisted on low tow was the TG-3's he used as trainers. It was very difficult for the instructor, sitting 8 feet or so behind the student, to see the tug while in high tow. There was a lot of rollover structure and greenhouse canopy between the front and rear cockpits. Low tow gives the instructor a great view of the tug. I really can't think of another reason for low tow. BTW, low tow seems easier only because there are fewer references, like the horizon, to help detect being out of position. If you can't tell you are out of position, it seems OK. In fact, the opposite may be true. In high tow, the tugs wingtip vortices tend to push a glider back to center position. In low tow, they tend to pull it out of position. Bill Daniels Gotta jump on this one- sorry Bill! Suggestion of moving down to take up slack is absolutely wrong. This will increase relative speed of glider and make the situation worse. The usual reason for slack is glider quickly descending and thus slightly overtaking tug. Just like what creates slack in high tow. Proper technique when you get some slack is simply slide out to the side until slack comes out. Then return to proper vertical position and move back to center. Since you are below the wake , vortices are not really and issue. One of the nice parts about low tow is that you feel the wake on the vertical tail as height warning instead of fuselage descending into wake and causing glider to want to start out of position. 2-33 drivers will recognize this scenario. BTW- we've tried top stall the tug by pulling the tail down and not been able to do it. Cheers UH |
![]() wrote in message oups.com... On Mar 6, 4:38 pm, "Bill Daniels" bildan@comcast-dot-net wrote: "Tuno" wrote in message oups.com... This topic is most interesting. I was never taught the low tow, or presented with the concept at any of the 3 places I took lessons (Estrella, Seminole Lakes and Turf, 3 years ago). How is it easier for the glider driver? Wouldn't it create more work for the tug driver? Are there any enthusiasts of the low tow who are also enthusiasts of high wing loading for those good days? I've been in the "low tow" position unintentionally at max wing loading when the tug driver musta thought he was pulling a 2-33. Seems like there would be no room for error if one started out in that position, and the tug then slowed down! ~ted/2NO I probably flew hundreds of low tows at the old El Mirage Field. Gus Brigleib insisted on low tow. If you are flying a low performance glider, the technique for slack is to just push the nose lower. The glider will just move down and take the slack out. If, however, you are flying a Nimbus, it will outrun the tug pasing under it. Pulling up puts in more slack even as the glider slows down ending in a jerk. In the end, I suspect the reason Gus insisted on low tow was the TG-3's he used as trainers. It was very difficult for the instructor, sitting 8 feet or so behind the student, to see the tug while in high tow. There was a lot of rollover structure and greenhouse canopy between the front and rear cockpits. Low tow gives the instructor a great view of the tug. I really can't think of another reason for low tow. BTW, low tow seems easier only because there are fewer references, like the horizon, to help detect being out of position. If you can't tell you are out of position, it seems OK. In fact, the opposite may be true. In high tow, the tugs wingtip vortices tend to push a glider back to center position. In low tow, they tend to pull it out of position. Bill Daniels Gotta jump on this one- sorry Bill! Suggestion of moving down to take up slack is absolutely wrong. This will increase relative speed of glider and make the situation worse. The usual reason for slack is glider quickly descending and thus slightly overtaking tug. Just like what creates slack in high tow. Proper technique when you get some slack is simply slide out to the side until slack comes out. Then return to proper vertical position and move back to center. Since you are below the wake , vortices are not really and issue. One of the nice parts about low tow is that you feel the wake on the vertical tail as height warning instead of fuselage descending into wake and causing glider to want to start out of position. 2-33 drivers will recognize this scenario. BTW- we've tried top stall the tug by pulling the tail down and not been able to do it. Cheers UH Please note that I did qualify my statement with the phrase "low performance glider". In the days I was flying low tow, it was rare to find a glider with more than 30:1. The 2-22's were about 20:1. These glilders won't accelerate as you nose down. As you point out, higher performance gliders will over run the rope. Wing tip vortices have a laminar far field effects that extends at least one tug wingspan. I did some wing tip vortex turbulence studies in the 1960's with smoke grenades on the tug wing. That was one of the results. It means that the glider is always under the influence of the two wingtip vortices coming from the tug whether the pilot can sense the turbulence or not. An interesting experiment is to position the glider to one side while in high tow. Then, keep the gliders wings exactly level with reference to the tug but otherwise allow the glider to go where it will. The glider will gently swing back to center as it is pushed by the wing tip vortex. Try that in low tow and the vortex flow will pull the glider away from center. Bill Daniels |
![]() "Graeme Cant" gcantinter@tnodedotnet wrote in message ... Vaughn Simon wrote: "Graeme Cant" gcantinter@tnodedotnet wrote in message ... In Oz it's a no-no to pop up into high tow as you release (with all due respect to Oscar's experience and SA's rules) because it's been known to initiate a kiting situation. I guess our experience is that a 'slow' move through a turbulent slipstream into high tow isn't all that easy to accomplish for ab initio and low experience pilots... That trip up (and/or down) through the wake is part of the drill for the "boxing the wake" manuver. I would never solo a student who couldn't do that. Vaughn Good. Your point is? My point is that the slow "trip through the wake" should not be a problem, even for ab initio and low experience pilots. It is something that is easily trained for and practiced. Vaughn |
Thanks, guys. I've learnt a lot from this thread: all I hoped to find
out and a lot of other valuable stuff as well. Mainly that, as a beginner at that game I'm going far too low. I see more practice in my future. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Vaughn Simon wrote:
"Graeme Cant" gcantinter@tnodedotnet wrote in message ... Vaughn Simon wrote: "Graeme Cant" gcantinter@tnodedotnet wrote in message ... In Oz it's a no-no to pop up into high tow as you release (with all due respect to Oscar's experience and SA's rules) because it's been known to initiate a kiting situation. I guess our experience is that a 'slow' move through a turbulent slipstream into high tow isn't all that easy to accomplish for ab initio and low experience pilots... That trip up (and/or down) through the wake is part of the drill for the "boxing the wake" manuver. I would never solo a student who couldn't do that. Vaughn Good. Your point is? My point is that the slow "trip through the wake" should not be a problem, even for ab initio and low experience pilots. It is something that is easily trained for and practiced. 1. In my instructing experience boxing the wake is a moderately difficult manoeuvre to carry out in a well-controlled way for ab initio and low experience pilots. Many experienced pilots botch boxing the wake on their annual check. That's why instructors set it as an exercise. I suspect that's why you set it. 2. Boxing the wake doesn't actually involve a trip directly through the slipstream. GC Vaughn |
Properly done, boxing the wake begins by a descent
through the wake, a box around the wake, and then an ascent back up through the wake. This shows the student the extremes of where one can go safely on tow. At 13:48 08 March 2007, Graeme Cant wrote: Vaughn Simon wrote: 'Graeme Cant' wrote in message ... Vaughn Simon wrote: 'Graeme Cant' wrote in message ... In Oz it's a no-no to pop up into high tow as you release (with all due respect to Oscar's experience and SA's rules) because it's been known to initiate a kiting situation. I guess our experience is that a 'slow' move through a turbulent slipstream into high tow isn't all that easy to accomplish for ab initio and low experience pilots... That trip up (and/or down) through the wake is part of the drill for the 'boxing the wake' manuver. I would never solo a student who couldn't do that. Vaughn Good. Your point is? My point is that the slow 'trip through the wake' should not be a problem, even for ab initio and low experience pilots. It is something that is easily trained for and practiced. 1. In my instructing experience boxing the wake is a moderately difficult manoeuvre to carry out in a well-controlled way for ab initio and low experience pilots. Many experienced pilots botch boxing the wake on their annual check. That's why instructors set it as an exercise. I suspect that's why you set it. 2. Boxing the wake doesn't actually involve a trip directly through the slipstream. GC Vaughn |
Nyal Williams wrote:
Properly done, boxing the wake begins by a descent through the wake, a box around the wake, and then an ascent back up through the wake. This shows the student the extremes of where one can go safely on tow. I agree and this is how I do it and teach it. But in the US, the PTS doesn't say that you have to do it this way. And, it's referenced source for the maneuver, The Soaring Flight Manual, also does not mention going through the wake. If, on a flight review, a rated pilot boxes the wake without going through it, I keep my mouth shut. But, then later I will ask for a tow transition through the wake prior to release. Tony V http://home.comcast.net/~verhulst/SOARING |
On Mar 8, 6:44 am, Graeme Cant gcantinter@tnodedotnet wrote:
1. In my instructing experience boxing the wake is a moderately difficult manoeuvre to carry out in a well-controlled way for ab initio and low experience pilots. Many experienced pilots botch boxing the wake on their annual check. That's why instructors set it as an exercise. I suspect that's why you set it. Yes. And I stress *precision* in the exercise. The point is not to get around the wake as fast as possible, it is to prove to the instructor that you have the skill to make the various transitions while maintaining control of the glider. 2. Boxing the wake doesn't actually involve a trip directly through the slipstream. Many people begin the exercise by dropping from high to low tow through the wake. This help establish the reference for where the bottom part of the box should be. -Tom |
#29
Tony Verhulst wrote:
But in the US, the PTS doesn't say that you have to do it this way. And, it's referenced source for the maneuver, The Soaring Flight Manual, also does not mention going through the wake. If, on a flight review, a rated pilot boxes the wake without going through it, I keep my mouth shut. But, then later I will ask for a tow transition through the wake prior to release. They done went and changed it agin, then: http://tinyurl.com/2fksg7 faa-h-8083-13, pp101-102 (2003) "BOXING THE WAKE "Boxing the wake is a performance maneuver designed to demonstrate a pilot’s ability to accurately maneuver the glider around the towplane’s wake during aerotow. "Boxing the wake requires flying a rectangular pattern around the towplane’s wake. _Before starting the maneuver, the glider should descend through the wake to the center low tow position as a signal to the tow pilot that the maneuver is about to begin_. The pilot uses coordinated control inputs to move the glider out to one side of the wake and holds that lower corner of the rectangle momentarily with rudder pressure. Applying back pressure to the control stick starts a vertical ascent, then rudder pressure is used to maintain equal distance from the wake. The pilot holds the wings level with the ailerons to parallel the towplane’s wings. When the glider has attained high corner position, the pilot momentarily maintains this position. "As the maneuver continues, the pilot reduces the rudder pressure and uses coordinated flight controls to bank the glider to fly along the top side of the box. The glider should proceed to the opposite corner using aileron and rudder pressure, as appropriate. The pilot maintains this position momentarily with rudder pres- sure, then begins a vertical descent by applying for- ward pressure to the control stick. Rudder pressure is used to maintain glider position at an equal distance from the wake. The pilot holds the wings level with the ailerons to parallel the towplane’s wings. When the glider has attained low corner position, the pilot momentarily maintains this position. The pilot releases the rudder pressure and, using coordinated flight controls, banks the glider to fly along the bottom side of the box until reaching the original center low tow position._From center low tow position, the pilot maneuvers the glider through the wake to the center high tow position, completing the maneuver_. "COMMON ERRORS -Performing an excessively large rectangle around the wake. • -Improper control coordination and procedure • -Abrupt or rapid changes of position." --------------------------------------------------- Jack |
#30
Adding to Tom's point, there are "locational" variations to boxing the
wake. Where I learned, we would drop down to low tow, climb right back up to high tow, then box the wake going clockwise around the wake. Where I fly now, we drop to low tow, box the wake going clockwise around the wake, then climb back up to high tow. I've heard that at some sites the wake is boxed going counter-clockwise around the wake instead of clockwise. None of these variations really matter much - as 5Z says, the whole point of the maneuver "is to prove to the instructor that you have the skill to make the various transitions while maintaining control of the glider." -John On Mar 8, 11:03 am, "5Z" wrote: Many people begin the exercise by dropping from high to low tow through the wake. This help establish the reference for where the bottom part of the box should be. -Tom |
And you thought AMARC was bad.... | Ron | Aviation Photos | 18 | February 2nd 07 05:27 AM |
Thought Police | Michael Baldwin, Bruce | Products | 0 | November 17th 06 06:58 AM |
Just when I thought I'd heard it all:-) | Dudley Henriques | Piloting | 14 | November 23rd 05 08:18 PM |
A thought on BRS | Martin Gregorie | Soaring | 47 | April 29th 04 06:34 AM |
I thought some of these are classics | goneill | Soaring | 0 | April 8th 04 10:51 AM |
