Honestly, I don't know how you guys got Newton involved.
![]() How about a (better) hypothetical? The imaginary aircraft is sitting at Imaginary Airfield (KIMG), which sits at a billiards-table-flat 50 MSL. The aircraft's static port is mounted at the centerline of the fuselage, which is 10 feet from the ground. The instrument in question is mounted 4 feet above the centerline. What will the gauge read when set to the proper barometric scale? 50, 60, or 64 feet? TheSmokingGnu |
TheSmokingGnu wrote:
Honestly, I don't know how you guys got Newton involved. ![]() How about a (better) hypothetical? The imaginary aircraft is sitting at Imaginary Airfield (KIMG), which sits at a billiards-table-flat 50 MSL. The aircraft's static port is mounted at the centerline of the fuselage, which is 10 feet from the ground. The instrument in question is mounted 4 feet above the centerline. What will the gauge read when set to the proper barometric scale? 50, 60, or 64 feet? Not enough potential aswers, you for got: Under IFR Under VFR Pass Go and collect $200 No one is going to tell me how to set my altimeter -- Jim Pennino Remove .spam.sux to reply. |
That depends on what the people in the calibration shop did to it. My understanding is that the =installation= is certified. It would be logical for the certified installation to be calibrated to the wheel height. It would be equally logical for it to be certified to the instrument height. It's an FAA certification. 'nuf said. ![]() Jose -- Get high on gasoline: fly an airplane. for Email, make the obvious change in the address. |
On Apr 3, 12:11 am, TheSmokingGnu
wrote: The imaginary aircraft is sitting at Imaginary Airfield (KIMG), which sits at a billiards-table-flat 50 MSL. The aircraft's static port is mounted at the centerline of the fuselage, which is 10 feet from the ground. The instrument in question is mounted 4 feet above the centerline. What will the gauge read when set to the proper barometric scale? 50, 60, or 64 feet? Any of the above ;-) To repeat what I posted back on March 9th... The actual altimeter test is described in FAR 43 CFR Appendix E, and allowable error varies from 20' at sea level, to much more at higher altitudes. http://www.flightsimaviation.com/dat...t_43-appE.html In theory, the instrument is calibrated on the bench to read at its own height, but can later be adjusted in the aircraft to read wheel height. Whether it should be or not, doesn't seem to be addressed in the regulations that I could find. There's an old saying, that "hell for scientists" is defined as a place where all the conditions are perfect, but none of the instruments are. Kev |
Deck height | Sean Trost | Home Built | 5 | July 16th 04 03:46 AM |
Volkslogger Calibration | Ray Lovinggood | Soaring | 5 | September 13th 03 04:56 PM |
Height records? | Paul Repacholi | Soaring | 2 | September 7th 03 03:14 PM |
Cloud Height Indicator | Bob Bristow | Home Built | 0 | August 11th 03 07:42 AM |
Seat height problem | Slav Inger | Piloting | 7 | July 22nd 03 02:31 PM |
