Whose airplane is it anyway?
Old March 18th 07, 08:43 PM posted to rec.aviation.homebuilt
Ernest Christley
Default Whose airplane is it anyway?
I have just been informed by the designer of the aircraft that I am
building that there is a possibility that he may not allow me to use an
alternative engine. Granted that weight and balance, as well as power
requirements must reasonably lie within allowable ranges, what is the
roll of the kit or plans manufacturer in the final homebuilt aircraft?
Will the FAA award him the power to veto my airworthiness certificate?
Old March 18th 07, 08:53 PM posted to rec.aviation.homebuilt
Morgans[_2_]
"Ernest Christley" wrote in message
requirements must reasonably lie within allowable ranges, what is the roll
of the kit or plans manufacturer in the final homebuilt aircraft? Will the
No way he can do anything other than stop supporting you, in any way.
Do you have all of your parts from him? Do you think there is anything that
you will absolutely need to ask him, from here on out, that you can not
complete the airplane without his answers?
If your answers are yes and no, then don't worry about it. All his plans
are is a suggested way to build an airplane. How you build it and what
modifications you make are entirely up to you.
It figures he would pull that crap. I always thought he was a primadonna.
Old March 18th 07, 09:29 PM posted to rec.aviation.homebuilt
Ernest Christley
He never supplied parts, and getting him to answer a technical question
has always been like pulling an eye-tooth.
Follow the plans...but the part isn't made anymore...stick to the
plans...but the measurements contradict...just stick to the plans...
I'm going to call the Greensboro FSDO tomorrow and I've sent an email to
the EAA Headquarters. The idea that I can be cut off after 5years of
building really sticks in my craw. Even the insinuation is unbearable.
Old March 18th 07, 10:07 PM posted to rec.aviation.homebuilt
Morgans[_2_]
I'm sure you need to hear it straight from the horse's mouth, so to speak,
so of course, check with those two organizations.
Rest easy tonight, and until you get your answers, that there are no
problems. Carry on, making your airplane, (making your own decisions-so it
sounds) with the knowledge that all is well.
Old March 18th 07, 11:05 PM posted to rec.aviation.homebuilt
john smith
What are you building?
Old March 18th 07, 11:10 PM posted to rec.aviation.homebuilt
Lou
Isn't this the same problem that the sonex builder
had putting in the corvair engine?
His is flying.
Lou
Old March 18th 07, 11:57 PM posted to rec.aviation.homebuilt
Morgans[_2_]
"john smith" wrote in message
It isn't me, building. It is Mr. Christley, and he is building a Dyke
Delta.
Here is a hope page of one of the Dyke Delta's builders.
www.eaa27.org/projects/maher/index.html
Old March 19th 07, 03:11 AM posted to rec.aviation.homebuilt
Ernest Christley
Dyke Delta.
http://www.ernest.isa-geek.org
Old March 19th 07, 02:57 AM posted to rec.aviation.homebuilt
Richard Isakson
"Richard Riley" wrote ...
Well, do check with them for your own peace of mind, but there ain't
nothin - and I do mean nothin - that he can do. It's faintly
theoretically possible that if you include his name in the registered
name type of your airplane he could have grounds to sue you, but it's
never happened and probably never will.
Just to be on the safe side, call it something else when you register
it.
Frankly, the big change that needs to be done to your airplane is it
needs fixed main gear and a lower ground attitude. One man's opinion,
Yet, as Lieutenant Edwards found out a great deal of care must be taken when
you're dealing with changes in the center of gravity of flying wings.
Rich
Old March 19th 07, 03:25 AM posted to rec.aviation.homebuilt
Ernest Christley
it.
Rich
I've taken painstaking care not to move the CG or change the airfoil,
sweep or angles of the wings. I have made the nosegear fixed. That
saved me 10lbs, lots of complication, and several failure modes. It may
cost me a couple kts, but I consider them kts well spent. If I knew
then what I know now, the main gear would be aluminum leaf springs.
There's lots of weight in the gear retract mechanism, but its fairly
evenly spread forward and aft of the CG.
As for changing the ground attitude...you've got to get it high enough
to put a prop on there. I do have less than 9 degrees nose-up, which is
the limit. It's just under 8, if I recall correctly.
Why Buy and Airplane? Jim Burns Piloting 8 April 12th 06 05:30 PM
Why Buy and Airplane? Jim Burns Owning 7 April 12th 06 05:30 PM
Which airplane? Ghazan Haider Owning 18 September 2nd 05 03:25 AM
What was that airplane? [email protected] Piloting 22 May 3rd 04 02:07 PM
my first airplane ! Ballan Home Built 6 April 29th 04 08:55 PM
