Like heat shrink tubing but not a tube.
Old March 29th 07, 07:23 PM posted to rec.aviation.homebuilt
cavelamb himself
Default Like heat shrink tubing but not a tube.
Or look around for a heat shrink Tape?
There is such a critter...
That is what I was asking about in the original post. Got a name for it or
who makes it?
Richard
Google turned up lotso hits.
Here are the top three...
http://solutions.3m.com/wps/portal/3...s/Heat_Shrink/
http://www.info-central.org/construction_heattape.shtml
http://www.shrinkit-inc.com/Shrink-wrap-heat-tape.htm
Old March 29th 07, 08:50 PM posted to rec.aviation.homebuilt
What I'm using in for is to cover the "tail" of
the swaged control wires going to the rudder and elevator. I planned to use
heat shrink tubeing but was thinking so much about putting on the Nico
collars that I forgot about it. It was the first time I'd ever done it.- Hide quoted text -
- Show quoted text -
Check West Coast Marine, The Sail boat clan use a tape that sticks to
it's self for this - and other things. Works pretty
well.................
Old March 30th 07, 06:24 PM posted to rec.aviation.homebuilt
wmbjk
On Wed, 28 Mar 2007 10:30:23 -0700, "RST Engineering"
Almost all shrink sleeving that I am aware of works on the 50% rule. That
is, it will shrink to 50% of its cold diameter. 4" will shrink to 2".
Go here http://www.mcmaster.com/, and start at catalogue page 777.
Shrink ratios up to 6:1, colors, clear, thick-wall, wrap-around etc.
Same-day shipping. But that high shrink-rate stuff is pricey.
Old April 27th 07, 09:58 PM posted to rec.aviation.homebuilt
On Mar 28, 9:20 am, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net
I need to do what heat shrink tubing would be perfect for but I can't use
the HST because the end of what I need to cover is too large. Is there an
equivalent that will allow me to wrap the item and then heat shrink it?
Look here http://www.smallparts.com/ any size you need but a local
electrical supply house will be able to sell you want you need also.
Relesable instrument tubing [email protected] Soaring 6 February 13th 07 05:38 AM
pvc tubing/sleeve source? Jim Burns Owning 4 September 28th 06 03:36 AM
pvc tubing/sleeve source? Jim Burns Home Built 4 September 28th 06 03:36 AM
Gauge of tubing??? Michael Horowitz Home Built 7 June 6th 06 01:32 PM
Tubing strength Ernest Christley Home Built 0 January 16th 04 11:43 PM
