"ucsdcpc" wrote in message ... Speed control is OPPOSITE to that during aerotow and gliding I'm sure if I asked this of one of our instructors the answer would be "you don't" You control the attitude, the winch driver controls the speed. Lowering the nose is the signal to the driver that you are too slow, wagging the rudder the signal for too fast. If the winch driver doesn't or cannot respond you abandon the launch. And your instructor would be wrong in most cases. Pilots who think they are controlling attitude are at risk of stalling while on the cable. We are in a transition period in winch launch where old ideas are giving way to the new. New gliders launched by new winches operate by somewhat different rules. In the modern view, the winch driver controls POWER and the pilot controls AIRSPEED. The relationship is the same as in airplanes where throttle controls power and pitch controls airspeed. As the glider leaves the ground on a winch launch. the pilot smoothly pitches up to hit a target climb airspeed. In an airplane, this would be Vy. In the typical glider, it will be between 55 and 65 knots depending somewhat on headwind. It's helpful to think of the winch driver as your flight engineer with his hands on the power levers. A modern trainer such as a ASK-21 would need a very powerful winch indeed for its pilot to be unable to control airspeed. In most cases, the entire launch will be flown with neutral elevator leaving considerable up elevator to control airspeed. An important exception is with gliders which have hooks too far forward and/or have too little up elevator authority - for example, most Schweizers. When flying these gliders the pilot will reach full up elevator before the airspeed can be controlled. Since the pilot cannot control airspeed, the winch driver has to. A further complication is that these gliders, which require the winch driver to control airspeed, will not reach more than 1/2 to 2/3's the height of the modern 2-seater with a properly positioned CG hook. This exception case also introduces complications in the event of a cable break. With the elevator positioned at full up, the glider will pitch up strongly at the cable break - sometimes beyond the point where a safe recovery can be made. In any event, a very quick and positive action will be required of the pilot. This contrasts with gliders like the ASK-21 which will continue on the same trajectory giving the pilot additional seconds to handle the cable break. Bill Daniels |
At 15:12 02 April 2007, Andreas Maurer wrote:
Hi Bill, On Fri, 30 Mar 2007 09:49:23 -0600, 'Bill Daniels' wrote: The winch should be constructed such that it is not be possible for the airspeed to increase as a result of raising the glider's nose. Otherwise, the winch should be regarded as dangerous. Is it such a problem to teach the pilot to pull the release if his airspeed exceeds the desired prameters? ![]() That is exactly what we are taught to do, but making something as counter-intuitive as 'raise nose go faster' does strike me as dangerous in the extreme - a huge amount of the the instruction from 1st flight is based around 'nose down go faster, nose up go slower'. Would you like a situation where right stick produced left bank? I doubt it. |
On 2 Apr 2007 15:31:32 GMT, Sally W
wrote: That is exactly what we are taught to do, but making something as counter-intuitive as 'raise nose go faster' does strike me as dangerous in the extreme - a huge amount of the the instruction from 1st flight is based around 'nose down go faster, nose up go slower'. I still wonder how such a rule cold be created at all. Where I fly this rule is regarded as an urban legend and student pilots are told accordingly to lower the nose if they get too slow. Bye Andreas |
| Thread Tools | |
| Display Modes | |
| Spectra cord for ground launch | ttaylor at cc.usu.edu | Soaring | 1 | September 10th 05 06:13 AM |
| Ground speed control | Roger Long | Piloting | 2 | July 7th 04 11:13 PM |
| Ground speed control with leaning | Roger Long | Piloting | 11 | June 8th 04 10:22 PM |
| Ground launch and the incremental vanishing of soaring | Mark James Boyd | Soaring | 24 | March 8th 04 11:50 PM |
| Requesting Flight Following from ground control | Yossarian | Piloting | 7 | July 19th 03 04:23 PM |
