#21
On Apr 2, 5:43 pm, "Capt. Geoffrey Thorpe" The Sea Hawk at wow way
d0t com wrote: If I were to guess (and it's just a guess) I would suspect that the long open space along the runway allows the wind to blow a little faster (less drag from buildings and stuff) and pulls down a little more cool air from higher altitudes. A similar sort of guess would be that it's the same effect as a sea breeze. The runway surface heats up and causes a cool breeze towards it. Chris, is this in the morning or afternoon? Kev |
re spending money to figure that out. I thought that was common
knowledge. Well, sometimes things that are common knowledge are incorrect. Jose Jose, you sound like your buddy MX. When I returned from luch today I walked from a concrete parking lot over about 10 feet of grass to enter the building. I did not need airborne equipment to tell me it was warmer over the concrete than it was over the grass. Well, yeah, but I wouldn't use that to make the decision as to whether or not huge piles of money should be spent to combat global warming. I think we need something from traceable, calibrated instruments with error bars on the numbers, which is what hopefully the airplane is getting. -- Jim Pennino Just to add a little more "food for thought" to the Global Warming issue: I recently heard another of those poorly attributed sotries on radio. In this case, it seems that some of the Siberian reporting stations were abandonned--so the subsequent data was merely compiled without them... As to the original question, I presume that the road near the approach end of the runway is simply in a less built-up area that the rest of Chris' Dad's morning commute. That would be nothing new; there has been a very noticeable change of temperature in less than a quarter mile--in that type of transition--for as long as I can remember. With the windows open, you can suddenly wonder if you should have brought a jacket... Peter |
I would sooner think that it is the ground in the area... is there water or
a marshy area near there? BT "Chris W" wrote in message ... My dad drives along the south side of OKC to work every day and his OAT in his car always goes a few degrees colder around the where the extended centerline for the runways would intersect the road. Then it goes right back up after he is through that area. He thinks this is because the airplanes are descending from very cold air and bringing down some of it with them. He has noted that this isn't always the case but it often is. You would think most of the traffic would be landing from the north since our winds are mostly from the south, but it seems like I see a lot of traffic coming in from the south, maybe because it is easier for the traffic from DFW to just come strait in. Anyway, any one here think it is really the case that the planes are causing the temperature to be lower on the approach end of the runway? I guess if he monitored the ATIS frequency to find out which runway was active when he drives by every day, he would have a better idea. -- Chris W KE5GIX "Protect your digital freedom and privacy, eliminate DRM, learn more at http://www.defectivebydesign.org/what_is_drm" Gift Giving Made Easy Get the gifts you want & give the gifts they want One stop wish list for any gift, from anywhere, for any occasion! http://thewishzone.com |
Is it colder at the approach end of a runway?
No. -- Tony Roberts PP-ASEL VFR OTT Night Cessna 172H C-GICE |
tony roberts wrote:
Is it colder at the approach end of a runway? No. But isn't it true, or so I've been told, that it is always cloudier over an airport than the surrounding area? :-) |
Robert M. Gary wrote:
I live near Sacramento where we have long periods of 100+ degree temps. The gov't has been doing research here on the affect of asphalt and roofs (not sure why) on temps. They fly a plane overhead in the afternoon with sensitive heat detecting equipment. They seem to believe the city is much hotter simply because of the pavement and the roofs. Don't know why they'd be studying it in Sacramento. Here in Phoenix it has long been known as the "Heat Island". Basically, asphalt, roofs and concrete absorb much more heat than dirt or grass. The result is that this excess heat is liberated slowly after the sun goes down and raises the overnight low temperature in populated areas. If you live in a rapidly expanding desert town long enough, it's easy to see. When I moved here, there were about 1.5 million people in the metro area. During the hottest part of the summer, overnight low temperatures stayed in the mid to upper 80s. Nowadays, we have about 4 million people and the overnight lows stay in the low to mid 90s at the peak of summer. Daytime temperatures haven't shown any corresponding increase. John Galban=====N4BQ (PA28-180) -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...ation/200704/1 |
On Apr 2, 5:33 pm, "Vaughn Simon"
wrote: "Marco Leon" wrote in message ... Air does not "stick" to an airframe enough to change the ambient temperature of a given area no matter how small. No, but everyone who has ever studied for their Private written knows that the wake of an aircraft is accelerated down. So the passage of an aircraft would cause a very temporary downward flow of air. Would the effect be enough to noticeably change local temperatures? I doubt it; but who the hell am I? What time of day does he go by? I could see the downwash mixing up the air, and if there is a hot surface layer this could cool it. As an example of downwash changing the temperature, I have heard helicopter pilot stories about 'frost flights' at strawberry farms. The task is to spend the night at the farm, and if the frost alarm goes off in the wee hours you have to fly low over the fields in the dark until the air is stirred up and the frost danger goes away. It apparently is very effective in preventing frost damaged berries. John Halpenny |
No. But isn't it true, or so I've been told, that it is always cloudier over an airport than the surrounding area? :-) Now that IS true ![]() Tony -- Tony Roberts PP-ASEL VFR OTT Night Cessna 172H C-GICE |
#29
On Apr 2, 9:18 pm, "John Halpenny" wrote:
On Apr 2, 5:33 pm, "Vaughn Simon" wrote: "Marco Leon" wrote in message m... Air does not "stick" to an airframe enough to change the ambient temperature of a given area no matter how small. No, but everyone who has ever studied for their Private written knows that the wake of an aircraft is accelerated down. So the passage of an aircraft would cause a very temporary downward flow of air. Would the effect be enough to noticeably change local temperatures? I doubt it; but who the hell am I? What time of day does he go by? I could see the downwash mixing up the air, and if there is a hot surface layer this could cool it. As an example of downwash changing the temperature, I have heard helicopter pilot stories about 'frost flights' at strawberry farms. The task is to spend the night at the farm, and if the frost alarm goes off in the wee hours you have to fly low over the fields in the dark until the air is stirred up and the frost danger goes away. It apparently is very effective in preventing frost damaged berries. John Halpenny This has been done with fixed-wing airplanes, too. An airliner on approach can't help but drive down air from a couple hundred feet up. Problem with that, of course, is that the OP says his dad notices this on the drive to work, presumably in the morning, and the air aloft will be warmer rather than colder at that time. The nocturnal inversion is still in play in the morning, before the surface heats up. It's that warmer air the helicopters or other craft are driving down at night into the orchards or vineyards or citrus groves. Dan |
#30
I posted this and then got busy so I am just now reading the replies. I
will try to respond to most of the replies in this message. Airport is KOKC (Will Rogers International) The location where the temperature change is noticed is SW 104th Street which is just a hair over 1 mile south of the runway 35L and 35R. We weren't thinking so much that the temperature change was due to the down wash of air following the plane as it was the fact that at 30,000 feet the plane mass (which is quite a bit in an airliner) becomes very cold and as it moves through the warmer air at the the lower altitudes near the airport, it absorbs the heat from the air and therefore leaves it colder than it was. I do suspect though that as at least one poster suggested it may be due to the fact that there isn't much development out there. If you look at the satellite map, you will see very little development for a long way south. Another reason my dad thought this might be at least partially caused by the aircraft is the fact that sometimes it is warmer there. In that case he was thinking that the planes had been sitting on the ground for some time and most of the structure was at least as warm as the ambient air, then with the engines putting out full power for about 3 miles before they cross the road, would be generating a lot of heat. So if the planes were departing on runway 17L or 17R, it wold tend to warm it up. However it could just be due to what direction the wind was blowing. South wind blowing over mostly farm land and the river a few miles south. Keeping it cool and a north wind blowing over the city, keeping it warmer. -- Chris W KE5GIX "Protect your digital freedom and privacy, eliminate DRM, learn more at http://www.defectivebydesign.org/what_is_drm" Gift Giving Made Easy Get the gifts you want & give the gifts they want One stop wish list for any gift, from anywhere, for any occasion! http://thewishzone.com |
A WHAT Ran off the End of our Runway?? | Marco Leon | Piloting | 10 | May 17th 06 02:46 AM |
Runway ID | Lakeview Bill | Piloting | 55 | October 18th 05 12:53 AM |
Runway needs of F4U and F-4 ???? | vincent p. norris | Naval Aviation | 8 | October 6th 05 07:18 PM |
Completing the Non-precision approach as a Visual Approach | John Clonts | Instrument Flight Rules | 45 | November 20th 03 05:20 AM |
Runway in Use | Sniper@SDU | Simulators | 11 | October 8th 03 10:57 AM |
