#21
In a previous article, Steve Schneider said:
Paul, what is the field elevation where you are flying? Low. 559 feet. -- Paul Tomblin http://blog.xcski.com/ "The way I see it, unless we each conform, unless we obey orders, unless we follow our leaders blindly, there is no possible way we can remain free." - John Ashcroft^W^WFrank Burns |
![]() Steve Schneider wrote: I've managed to do this once at a high altitude airport. We've flown into Big Bear (L35 eleveation 6752) many times in the Turbo Lance II. On one particular landing the engine coughed and died as we rolled off the runway. Mixture was just a bit richer than it should have been. Never had it do that at lower elevations. Hot starts are always a pain, worse so at elevation it seems -- but I did get it running again. I see this every summer. We're here at 3650 MSL and you flatlanders fly in here and go to full rich to land. Engine dies on rollout and you tie up the runway while you pour good gas after bad trying to restart your flooded beast. |
I ask because the boost pump on mine is just that. I always thought it
was part of the difference being turbocharged vs not. It is suppose to be off for TO and landing, unlike an electric pump. In low it is just used (never had to) to fix a rough engine or vapour lock. High is a massive fuel flow that will flood the engine if the mixture isn't moved almost to the cut off position. High is only to be used in even of an engine driven pump failure. The rocker switch is also gated to prevent inadvertant actifation. John Paul Tomblin wrote: In a previous article, The Visitor said: You call it a boost pump, this is a turbocharged engine? Was it on high or low? It's officially just called the "electric fuel pump", as opposed to the engine driven fuel pump, but we call it "boost pump" for short. |
Newps wrote:
Steve Schneider wrote: I've managed to do this once at a high altitude airport. We've flown into Big Bear (L35 eleveation 6752) many times in the Turbo Lance II. On one particular landing the engine coughed and died as we rolled off the runway. Mixture was just a bit richer than it should have been. Never had it do that at lower elevations. Hot starts are always a pain, worse so at elevation it seems -- but I did get it running again. I see this every summer. We're here at 3650 MSL and you flatlanders fly in here and go to full rich to land. Engine dies on rollout and you tie up the runway while you pour good gas after bad trying to restart your flooded beast. There are many 'flatlanders' who fly into high altitude airports without having had proper instruction on operating in that environment. The typical problem is the high density altitude, overloaded departure that ends up costing lives -- it happens a little too often at Big Bear. That said, in many years of flying in and out of Big Bear (we have our own tie down and keep a car at the airport, since we're up there quite regularly) I haven't seen aircraft stalled on the runway or taxiways due to a flooded engine being a common problem. In my case, I was perhaps a 1/4"-1/2" richer than normal on the mixture to keep the CHT down on a particularly hot day (the turbo Lance is known for poor engine cooling due to the cowl design), but far from full rich. However on any given day, if you wander over to the fuel pit you'll often find the un-initiated 'flatlanders' draining their battery trying in vain to restart a flooded, hot engine after fueling. When I learned to fly at NAS Alameda, the club would not permit pilots to fly into airports above some specific elevation (which I've now long forgotten) until they had logged a high altitude check out with a club instructor. My indoctrination was in a Cardinal RG at Lake Tahoe back in '81, by cracky. I know there currently are clubs down here in flatland San Diego that don't have a similar requirement, but they should. No doubt it would save some lives. Steve |
john smith wrote:
This situation hadn't occured to me, but it's one I could easily encounter with either the Arrow or the Cherokee Six I fly. Tip of the hat! I can only speak for the Arrow. Checking the POH for our plane, it calls for fuel pump on, and mixture "set". At my home field this means mixture full rich. I was taught "Pump, Red, Blue, Greens" (Fuel pump on, Mixture full Rich, Prop full forward, 3 green landing gear indicators) call out on short final. The only time I've hand any issue with this is at a high altitude airport where I had the mixture too rich (wasn't full rich but was rich enough that when I turned off at the taxiway, the engine quit). -- Jack Allison PP-ASEL-Instrument Airplane "To become a Jedi knight, you must master a single force. To become a private pilot you must strive to master four of them" - Rod Machado (Remove the obvious from address to reply via e-mail) |
Roy,
The only problem is, the damn thing says the fuel flow doesn't change one iota between full rich and "aggressively leaned" Ours does. Same engine. Guess your "aggressive" isn't aggressive enough. -- Thomas Borchert (EDDH) |
"d&tm" wrote in message
... Very interesting scenario. The procedure I was taught in the Warrior was to turn the boost pump off at 500' AGL on the climb out. . You turn it back on again during downwind landing checks ( 1000' AGL) Why would you want to turn off your fuel pump at arguably the worst possible moment to have an engine failure? Take off, don't touch a thing till 1000' AGL, then touch things gently and cautiously (I'm referring to engine controls here, not gear, flaps etc). If you're in the pattern, leave the fuel pump on the whole time. If you're really concerned about the engine pump failing and wanting to check that, land, taxi off the runway, turn off the fuel pump, and taxi back, then turn your fuel pump on again before takeoff. Hilton |
... Very interesting scenario. The procedure I was taught in the Warrior was to turn the boost pump off at 500' AGL on the climb out. . You turn it back on again during downwind landing checks ( 1000' AGL) Why would you want to turn off your fuel pump at arguably the worst possible moment to have an engine failure? Take off, don't touch a thing till 1000' AGL, then touch things gently and cautiously (I'm referring to engine controls here, not gear, flaps etc). If you're in the pattern, leave the fuel pump on the whole time. If you're really concerned about the engine pump failing and wanting to check that, land, taxi off the runway, turn off the fuel pump, and taxi back, then turn your fuel pump on again before takeoff. Hilton I too was taught to leave the pump on the whole time if you are to remain in the pattern. However, I was also taught to leave the pump on until established at cruise altitude. Mike Flyin' 8 |
#29
On Apr 4, 8:31 am, (Paul Tomblin) wrote:
I was doing my BFR last night in my club's Piper Lance (in case you're not familiar: it has retractable gear and a IO-540 fuel injected engine). We finished up with a bunch of touch and goes, demonstrating short, soft, -- Paul Tomblin http://blog.xcski.com/ You'll get access to my computer room right after you pry the Halon test key out of my cold, lifeless hands. -- Simon Travaglia What I would be interested to know is what did Maintenance find? There is zero chance in my view that you flooded an engine under combustion. I have little or no experience with the engine in the Lance but a lot with the Lyc's in a PIper Commanche (twin and single...up to the 400) and this definatly should NOT happen. Robert |
#30
In a previous article, Luke Skywalker said:
On Apr 4, 8:31 am, (Paul Tomblin) wrote: I was doing my BFR last night in my club's Piper Lance (in case you're not familiar: it has retractable gear and a IO-540 fuel injected engine). We finished up with a bunch of touch and goes, demonstrating short, soft, What I would be interested to know is what did Maintenance find? It got flown a few times before the mechanic looked at it, and he was baffled too, but whatever was wrong with it could have cleared up. It's been starting and flying fine - no roughness, no indication of fouled plugs, etc. -- Paul Tomblin http://blog.xcski.com/ I trust the cut & paste under Win2k's telnet about as far as I can comfortably spit a rat. -- John Burnham |
Naresh quit your bitching... | [email protected] | Soaring | 3 | October 15th 05 04:41 PM |
I quit..... | Beav | Rotorcraft | 5 | April 19th 05 02:16 PM |
So, can we quit making believe the man can't fly? | Marc Ramsey | Soaring | 10 | March 10th 05 06:06 PM |
600 Filipinos Quit U$ Coalition After Attack | MLenoch | Military Aviation | 0 | May 15th 04 01:01 PM |
Quit Bashing China! | Bob McKellar | Military Aviation | 12 | October 26th 03 06:06 PM |
