#21
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1 Nomen Nescio wrote: -----BEGIN PGP SIGNED MESSAGE----- From: Mxsmanic Not that I disagree with you, but are you able to cite FAA regulations or orders that support your allegation? FAR 91.131(a)(1) (necessity of clearance) and 7710.65R 7-9-2(a) (approved phraseology). What part of the term "real pilots" confused you? I really hate to come to Two-Tonne Tony's defense here, but he is right as far as the .65 goes. There is the actual phraseology stated here. I'd also like to mention that while I am not a real pilot (yet), I do understand the reasoning to know the regs before stepping into the plane, so should that discriminate someone who knows it but hasn't had the chance to apply it in the real world yet the opportunity to answer? Lastly, while I do flightsim, I also have more common sense to think that flying a sim like MSFS *is real*. It is possible to get it close to real, but it isn't. If one refuses to believe that there is a difference, there is a problem. BL. - -- Brad Littlejohn | Email: Unix Systems Administrator, | Web + NewsMaster, BOFH.. Smeghead! ![]() PGP: 1024D/E319F0BF 6980 AAD6 7329 E9E6 D569 F620 C819 199A E319 F0BF -----BEGIN PGP SIGNATURE----- Version: GnuPG v1.4.7 (GNU/Linux) iD8DBQFGH9soyBkZmuMZ8L8RAjJuAKDZ5Feovdx41XMqnToVIp l7ue+7TQCfUO+a ZOI9qeh4gKhIymI7NPbcMjc= =EtG4 -----END PGP SIGNATURE----- |
Larry Dighera wrote:
Not that I disagree with you, but are you able to cite FAA regulations or orders that support your allegation? Curses! Why must my answers be answered! And by him, of all people! Regardless, you've got your man, Friday. Book 'em, Danno, and all that. (I'll stop now, honest) TheSmokingGnu |
On Fri, 13 Apr 2007 17:38:05 -0700, TheSmokingGnu
wrote in : Regardless, you've got your man, Friday. The issue isn't closed until Mr. McNicoll's wry analysis is indelibly etched in electrons throughout the usenetosphere. :-) |
The issue isn't closed until Mr. McNicoll's wry analysis is indelibly etched in electrons throughout the usenetosphere. :-) ObReadAs: rye analysis. Keep yer mitts off me samm'iches! ![]() TheSmokingGnu |
Mxsmanic wrote in
news ![]() Larry Dighera writes: Not that I disagree with you, but are you able to cite FAA regulations or orders that support your allegation? FAR 91.131(a)(1) (necessity of clearance) and 7710.65R 7-9-2(a) (approved phraseology). You're an idiot. Bertie |
![]() In the discussion below, I stated that there are times when a Class B clearance is implied. Can one of the ATC personnel among the readership of this newsgroup respond to that? On Fri, 13 Apr 2007 10:29:16 GMT, Larry Dighera wrote in : On Fri, 13 Apr 2007 03:18:52 GMT, Jose wrote in : Sometimes Class Bravo clearance is implied, but it's always best if you get it explicitly. When, under VFR, is a class Bravo clearance implied, such that this implied clearance can be relied on at an enforcement hearing? Perhaps 'implied' wasn't the best choice of words to use in this situation. Without knowing all the circumstances (such as LOAs, the position of the aircraft at various times, etc.) surrounding this particular incident, it's probably not possible to assert a definitive answer to your question, and I don't pretend to be knowledgeable about _all_ the regulations that address this issue. I was hoping that I wouldn't have to do the work of searching FAAO 7110.65, but here's what I found: http://www.faa.gov/regulations_polic...a/7110.65R.pdf 2-1-16. SURFACE AREAS a. Coordinate with the appropriate nonapproach control tower on an individual aircraft basis before issuing a clearance which would require flight within a surface area for which the tower has responsibility unless otherwise specified in a letter of agreement. REFERENCE- FAAO 7210.3, Letters of Agreement, Para 4-3-1. 14 CFR Section 91.127, Operating on or in the Vicinity of an Airport in Class E Airspace. P/CG Term- Surface Area. b. Coordinate with the appropriate control tower for transit authorization when you are providing radar traffic advisory service to an aircraft that will enter another facility’s airspace. NOTE- The pilot is not expected to obtain his/her own authorization through each area when in contact with a radar facility. c. Transfer communications to the appropriate facility, if required, prior to operation within a surface area for which the tower has responsibility. REFERENCE- FAAO 7110.65, Radio Communications Transfer, Para 2-1-17. FAAO 7110.65, Surface Area Restrictions, Para 3-1-11. FAAO 7110.65, Application, Para 7-6-1. 14 CFR Section 91.129, Operations in Class D Airspace. Section 9. Class B Service Area- Terminal 7-9-2. VFR AIRCRAFT IN CLASS B AIRSPACE a. VFR aircraft must obtain an ATC clearance to operate in Class B airspace. REFERENCE- FAAO 7110.65, Operational Requests, Para 2-1-18. FAAO 7110.65, Airspace Classes, Para 2-4-22. PHRASEOLOGY- CLEARED THROUGH/TO ENTER/OUT OF BRAVO AIRSPACE, 2-1-18. OPERATIONAL REQUESTS Respond to a request from another controller, a pilot or vehicle operator by one of the following verbal means: a. Restate the request in complete or abbreviated terms followed by the word “APPROVED.” The phraseology “APPROVED AS REQUESTED” may be substituted in lieu of a lengthy readback. PHRASEOLOGY- (Requested operation) APPROVED. or APPROVED AS REQUESTED. b. State restrictions followed by the word “APPROVED.” PHRASEOLOGY- (Restriction and/or additional instructions, requested operation) APPROVED. c. State the word “UNABLE” and, time permitting, a reason. PHRASEOLOGY- UNABLE (requested operation). and when necessary, (reason and/or additional instructions.) d. State the words “STAND BY.” NOTE- “STAND BY” is not an approval or denial. The controller acknowledges the request and will respond at a later time. REFERENCE- FAAO 7110.65, Traffic Advisories, Para 2-1-21. FAAO 7110.65, Route or Altitude Amendments, Para 4-2-5. FAAO 7110.65, Methods, Para 7-9-3. 5-4-5. TRANSFERRING CONTROLLER HANDOFF The transferring controller shall: a. Complete a radar handoff prior to an aircraft’s entering the airspace delegated to the receiving controller. REFERENCE- FAAO 7110.65, Coordinate Use of Airspace, Para 2-1-14. FAAO 7110.65, Control Transfer, Para 2-1-15. FAAO 7110.65, Receiving Controller Handoff, Para 5-4-6. b. Verbally obtain the receiving controller’s approval prior to making any changes to an aircraft’s flight path, altitude, or data block information while the handoff is being initiated or after acceptance, unless otherwise specified by a LOA or a facility directive. NOTE- Those en route facilities using host software that provides capability for passing interim altitude shall include the specific operations and procedures for use of this procedure in a LOA between the appropriate facilities. c. Ensure that, prior to transferring communications: 1. Potential violations of adjacent airspace and potential conflicts between aircraft in their own area of jurisdiction are resolved. 2. Necessary coordination has been accomplished with all controllers through whose area of jurisdiction the aircraft will pass prior to entering the receiving controller’s area of jurisdiction, except when such coordination is the receiving controller’s responsibility as stated in para 5-4-6, Receiving Controller Handoff, and unless otherwise specified by a LOA or a facility directive. 3. Restrictions issued to ensure separation are passed to the receiving controller. d. After transferring communications, continue to comply with the requirements of subparas c1 and 2. e. Comply with restrictions issued by the receiving controller unless otherwise coordinated. f. Comply with the provisions of para 2-1-17, Radio Communications Transfer, subparas a and b. To the extent possible, transfer communications when the transfer of radar identification has been accepted. NOTE- Before the ARTS/STARS “modify/quick look” function is used to transfer radar identification, a facility directive which specifies communication transfer points is required. g. Advise the receiving controller of pertinent information not contained in the data block or flight progress strip unless covered in a LOA or facility directive. Pertinent information includes: 1. Assigned heading. 2. Air speed restrictions. 3. Altitude information issued. 4. Observed track or deviation from the last route clearance. 5. The beacon code if different from that normally used or previously coordinated. 6. Any other pertinent information. h. Ensure that the data block is associated with the appropriate target. i. Initiate verbal coordination to verify the position of primary or nondiscrete targets when using the automated handoff functions except for intrafacility handoffs using single-sensor systems or multisensor systems operating in a mosaic RDP mode. j. Initiate verbal coordination before transferring control of a track when “CST”, “FAIL”, “NONE”, “NB”, “NX”, “IF”, or “NT” is displayed in the data block. k. Advise the receiving controller that radar monitoring is required when the aircraft is on a direct route initiated by ATC that exceeds usable NAVAID distances. l. Issue restrictions to the receiving controller which are necessary to maintain separation from other aircraft within your area of jurisdiction before releasing control of the aircraft. m. Consider the target being transferred as identified on the receiving controller’s display when the receiving controller acknowledges receipt verbally or has accepted an automated handoff. n. Accomplish the necessary coordination with any intervening controllers whose area of jurisdiction is affected by the receiving controller’s delay in the climb or the descent of an aircraft through the vertical limits of your area of jurisdiction when the receiving controller advises you of that delay before accepting the transfer of radar identification unless otherwise specified by a LOA or a facility directive. 5-4-6. RECEIVING CONTROLLER HANDOFF The receiving controller shall: a. Ensure that the target position corresponds with the position given by the transferring controller or that there is an appropriate association between an automated data block and the target being transferred before accepting a handoff. REFERENCE- FAAO 7110.65, Coordinate Use of Airspace, Para 2-1-14. FAAO 7110.65, Control Transfer, Para 2-1-15. FAAO 7110.65, Transferring Controller Handoff, Para 5-4-5. b. Issue restrictions that are needed for the aircraft to enter your sector safely before accepting the handoff. c. Comply with restrictions issued by the initiating controller unless otherwise coordinated. d. Before you issue control instructions directly to an aircraft that is within another controller’s area of jurisdiction that will change that aircraft’s heading, route, speed, altitude, or beacon code, ensure that coordination has been accomplished with each of the controllers listed below whose area of jurisdiction is affected by those instructions unless otherwise specified by a LOA or a facility directive: NOTE- Those en route facilities using host software that provides capability for passing interim altitude shall include the specific operations and procedures for use of this procedure in a LOA between the appropriate facilities. 1. The controller within whose area of jurisdiction the control instructions will be issued. 2. Any intervening controller(s) through whose area of jurisdiction the aircraft will pass. e. After accepting a handoff from another controller, confirm the identity of primary target by advising the aircraft of its position, and of a beacon target by observing a code change, an “ident” reply, or a “standby” squawk unless one of these was used during handoff. These provisions do not apply at those towers and GCAs which have been delegated the responsibility for providing radar separation within designated areas by the parent approach control facility and the aircraft identification is assured by sequencing or positioning prior to the handoff. REFERENCE- FAAO 7110.65, Approach Separation Responsibility, Para 5-9-5. f. When using appropriate equipment, consider a discrete beacon target’s identity to be confirmed when: 1. The data block associated with the target being handed off indicates the computer assigned discrete beacon code is being received, or 2. You observe the deletion of a discrete code that was displayed in the data block, or NOTE- When the aircraft generated discrete beacon code does not match the computer assigned beacon code, the code generated will be displayed in the data block. When the aircraft changes to the assigned discrete code, the code disappears from the data block. In this instance, the observance of code removal from the data block satisfies confirmation requirements. 3. You observe the numeric display of a discrete code that an aircraft has been instructed to squawk or reports squawking. g. Initiate verbal coordination prior to accepting control of a track when “CST”, “NAT”, “NT”, “NONE”, “NB”, “NX”, “OLD”, “OL”, “AMB”, “AM”, or “TU” is displayed in the data block. 1. When an automated interfacility handoff action is initiated and “AMB” or “AM” is displayed in the full data block, advise the other facility that a disparity exists between the position declared by their ... 5-4-10. PREARRANGED COORDINATION Prearranged coordination allowing aircraft under your control to enter another controller’s area of jurisdiction may only be approved provided procedures are established and published in a facility directive/LOA in accordance with FAAO 7210.3, para 3-7-7, Prearranged Coordination. NOTE- Under no circumstances may one controller permit an aircraft to enter another’s airspace without proper coordination. Coordination can be accomplished by several means; i.e., radar handoff, automated information transfer, verbal, point-out, and by prearranged coordination procedures identified in a facility directive that clearly describe the correct application. Airspace boundaries should not be permitted to become barriers to the efficient movement of traffic. In addition, complete coordination, awareness of traffic flow, and understanding of each position’s responsibility concerning penetration of another’s airspace cannot be overemphasized. REFERENCE- FAAO 7110.65, Coordinate Use of Airspace, Para 2-1-14. FAAO 7110.65, Transfer of Radar Identification, Methods, Para 5-4-3. FAAO 7110.65, Automated Information Transfer (AIT), Para 5-4-8. FAAO 7210.3, Prearranged Coordination, Para 3-7-7. I'll let you do the work of interpreting the above and continuing the search for pertinent sections.... Where's Mr. McNicoll when you need him? :-) |
![]() Larry Dighera wrote: In the discussion below, I stated that there are times when a Class B clearance is implied. Can one of the ATC personnel among the readership of this newsgroup respond to that? The FAA tells pilots that class B clearances are never implied. However many pilots have gotten off during the investigation because the controller vectored them into the class B. But it would sure be a pain in the ass to be right in this situation. |
Newps wrote:
The FAA tells pilots that class B clearances are never implied. However many pilots have gotten off during the investigation because the controller vectored them into the class B. But it would sure be a pain in the ass to be right in this situation. Almost had this just the other day. Asked for a practice ILS-34 into HPN, VFR, to a full stop. Controller said he had several IFR flights he needed to work in before us and gave us delaying vectors. A few minutes later, we're looking at the east wall of the inner ring of the NY Class B, so I got on the radio and said, "We're going to need a clearance on this heading in minute", which got us a vector in the other direction. Kind of a pity, really; I don't think I've ever flow right over my house before, and I missed the chance. The GPS really lets you get lazy. It's got all the CBAS boundaries, so I knew exactly where we were, but it doesn't have the floor altitudes. I know the floor of the outer ring is 3000, but I sure don't have memorized the floors of all the inner segments. I had to go scrambling for a sectional to figure out if we were good or not. |
#29
Roy Smith writes:
The GPS really lets you get lazy. It's got all the CBAS boundaries, so I knew exactly where we were, but it doesn't have the floor altitudes. I know the floor of the outer ring is 3000, but I sure don't have memorized the floors of all the inner segments. I had to go scrambling for a sectional to figure out if we were good or not. Which GPS was it? Some units will give you the vertical limits of the airspace as well. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#30
![]() "Larry Dighera" wrote in message ... In the discussion below, I stated that there are times when a Class B clearance is implied. Can one of the ATC personnel among the readership of this newsgroup respond to that? What is a Class B clearance? On Fri, 13 Apr 2007 10:29:16 GMT, Larry Dighera wrote in : On Fri, 13 Apr 2007 03:18:52 GMT, Jose wrote in : Sometimes Class Bravo clearance is implied, but it's always best if you get it explicitly. When, under VFR, is a class Bravo clearance implied, such that this implied clearance can be relied on at an enforcement hearing? Perhaps 'implied' wasn't the best choice of words to use in this situation. Without knowing all the circumstances (such as LOAs, the position of the aircraft at various times, etc.) surrounding this particular incident, it's probably not possible to assert a definitive answer to your question, and I don't pretend to be knowledgeable about _all_ the regulations that address this issue. I was hoping that I wouldn't have to do the work of searching FAAO 7110.65, but here's what I found: http://www.faa.gov/regulations_polic...a/7110.65R.pdf 2-1-16. SURFACE AREAS a. Coordinate with the appropriate nonapproach control tower on an individual aircraft basis before issuing a clearance which would require flight within a surface area for which the tower has responsibility unless otherwise specified in a letter of agreement. REFERENCE- FAAO 7210.3, Letters of Agreement, Para 4-3-1. 14 CFR Section 91.127, Operating on or in the Vicinity of an Airport in Class E Airspace. P/CG Term- Surface Area. b. Coordinate with the appropriate control tower for transit authorization when you are providing radar traffic advisory service to an aircraft that will enter another facility's airspace. NOTE- The pilot is not expected to obtain his/her own authorization through each area when in contact with a radar facility. c. Transfer communications to the appropriate facility, if required, prior to operation within a surface area for which the tower has responsibility. REFERENCE- FAAO 7110.65, Radio Communications Transfer, Para 2-1-17. FAAO 7110.65, Surface Area Restrictions, Para 3-1-11. FAAO 7110.65, Application, Para 7-6-1. 14 CFR Section 91.129, Operations in Class D Airspace. Section 9. Class B Service Area- Terminal 7-9-2. VFR AIRCRAFT IN CLASS B AIRSPACE a. VFR aircraft must obtain an ATC clearance to operate in Class B airspace. REFERENCE- FAAO 7110.65, Operational Requests, Para 2-1-18. FAAO 7110.65, Airspace Classes, Para 2-4-22. PHRASEOLOGY- CLEARED THROUGH/TO ENTER/OUT OF BRAVO AIRSPACE, 2-1-18. OPERATIONAL REQUESTS Respond to a request from another controller, a pilot or vehicle operator by one of the following verbal means: a. Restate the request in complete or abbreviated terms followed by the word "APPROVED." The phraseology "APPROVED AS REQUESTED" may be substituted in lieu of a lengthy readback. PHRASEOLOGY- (Requested operation) APPROVED. or APPROVED AS REQUESTED. b. State restrictions followed by the word "APPROVED." PHRASEOLOGY- (Restriction and/or additional instructions, requested operation) APPROVED. c. State the word "UNABLE" and, time permitting, a reason. PHRASEOLOGY- UNABLE (requested operation). and when necessary, (reason and/or additional instructions.) d. State the words "STAND BY." NOTE- "STAND BY" is not an approval or denial. The controller acknowledges the request and will respond at a later time. REFERENCE- FAAO 7110.65, Traffic Advisories, Para 2-1-21. FAAO 7110.65, Route or Altitude Amendments, Para 4-2-5. FAAO 7110.65, Methods, Para 7-9-3. 5-4-5. TRANSFERRING CONTROLLER HANDOFF The transferring controller shall: a. Complete a radar handoff prior to an aircraft's entering the airspace delegated to the receiving controller. REFERENCE- FAAO 7110.65, Coordinate Use of Airspace, Para 2-1-14. FAAO 7110.65, Control Transfer, Para 2-1-15. FAAO 7110.65, Receiving Controller Handoff, Para 5-4-6. b. Verbally obtain the receiving controller's approval prior to making any changes to an aircraft's flight path, altitude, or data block information while the handoff is being initiated or after acceptance, unless otherwise specified by a LOA or a facility directive. NOTE- Those en route facilities using host software that provides capability for passing interim altitude shall include the specific operations and procedures for use of this procedure in a LOA between the appropriate facilities. c. Ensure that, prior to transferring communications: 1. Potential violations of adjacent airspace and potential conflicts between aircraft in their own area of jurisdiction are resolved. 2. Necessary coordination has been accomplished with all controllers through whose area of jurisdiction the aircraft will pass prior to entering the receiving controller's area of jurisdiction, except when such coordination is the receiving controller's responsibility as stated in para 5-4-6, Receiving Controller Handoff, and unless otherwise specified by a LOA or a facility directive. 3. Restrictions issued to ensure separation are passed to the receiving controller. d. After transferring communications, continue to comply with the requirements of subparas c1 and 2. e. Comply with restrictions issued by the receiving controller unless otherwise coordinated. f. Comply with the provisions of para 2-1-17, Radio Communications Transfer, subparas a and b. To the extent possible, transfer communications when the transfer of radar identification has been accepted. NOTE- Before the ARTS/STARS "modify/quick look" function is used to transfer radar identification, a facility directive which specifies communication transfer points is required. g. Advise the receiving controller of pertinent information not contained in the data block or flight progress strip unless covered in a LOA or facility directive. Pertinent information includes: 1. Assigned heading. 2. Air speed restrictions. 3. Altitude information issued. 4. Observed track or deviation from the last route clearance. 5. The beacon code if different from that normally used or previously coordinated. 6. Any other pertinent information. h. Ensure that the data block is associated with the appropriate target. i. Initiate verbal coordination to verify the position of primary or nondiscrete targets when using the automated handoff functions except for intrafacility handoffs using single-sensor systems or multisensor systems operating in a mosaic RDP mode. j. Initiate verbal coordination before transferring control of a track when "CST", "FAIL", "NONE", "NB", "NX", "IF", or "NT" is displayed in the data block. k. Advise the receiving controller that radar monitoring is required when the aircraft is on a direct route initiated by ATC that exceeds usable NAVAID distances. l. Issue restrictions to the receiving controller which are necessary to maintain separation from other aircraft within your area of jurisdiction before releasing control of the aircraft. m. Consider the target being transferred as identified on the receiving controller's display when the receiving controller acknowledges receipt verbally or has accepted an automated handoff. n. Accomplish the necessary coordination with any intervening controllers whose area of jurisdiction is affected by the receiving controller's delay in the climb or the descent of an aircraft through the vertical limits of your area of jurisdiction when the receiving controller advises you of that delay before accepting the transfer of radar identification unless otherwise specified by a LOA or a facility directive. 5-4-6. RECEIVING CONTROLLER HANDOFF The receiving controller shall: a. Ensure that the target position corresponds with the position given by the transferring controller or that there is an appropriate association between an automated data block and the target being transferred before accepting a handoff. REFERENCE- FAAO 7110.65, Coordinate Use of Airspace, Para 2-1-14. FAAO 7110.65, Control Transfer, Para 2-1-15. FAAO 7110.65, Transferring Controller Handoff, Para 5-4-5. b. Issue restrictions that are needed for the aircraft to enter your sector safely before accepting the handoff. c. Comply with restrictions issued by the initiating controller unless otherwise coordinated. d. Before you issue control instructions directly to an aircraft that is within another controller's area of jurisdiction that will change that aircraft's heading, route, speed, altitude, or beacon code, ensure that coordination has been accomplished with each of the controllers listed below whose area of jurisdiction is affected by those instructions unless otherwise specified by a LOA or a facility directive: NOTE- Those en route facilities using host software that provides capability for passing interim altitude shall include the specific operations and procedures for use of this procedure in a LOA between the appropriate facilities. 1. The controller within whose area of jurisdiction the control instructions will be issued. 2. Any intervening controller(s) through whose area of jurisdiction the aircraft will pass. e. After accepting a handoff from another controller, confirm the identity of primary target by advising the aircraft of its position, and of a beacon target by observing a code change, an "ident" reply, or a "standby" squawk unless one of these was used during handoff. These provisions do not apply at those towers and GCAs which have been delegated the responsibility for providing radar separation within designated areas by the parent approach control facility and the aircraft identification is assured by sequencing or positioning prior to the handoff. REFERENCE- FAAO 7110.65, Approach Separation Responsibility, Para 5-9-5. f. When using appropriate equipment, consider a discrete beacon target's identity to be confirmed when: 1. The data block associated with the target being handed off indicates the computer assigned discrete beacon code is being received, or 2. You observe the deletion of a discrete code that was displayed in the data block, or NOTE- When the aircraft generated discrete beacon code does not match the computer assigned beacon code, the code generated will be displayed in the data block. When the aircraft changes to the assigned discrete code, the code disappears from the data block. In this instance, the observance of code removal from the data block satisfies confirmation requirements. 3. You observe the numeric display of a discrete code that an aircraft has been instructed to squawk or reports squawking. g. Initiate verbal coordination prior to accepting control of a track when "CST", "NAT", "NT", "NONE", "NB", "NX", "OLD", "OL", "AMB", "AM", or "TU" is displayed in the data block. 1. When an automated interfacility handoff action is initiated and "AMB" or "AM" is displayed in the full data block, advise the other facility that a disparity exists between the position declared by their ... 5-4-10. PREARRANGED COORDINATION Prearranged coordination allowing aircraft under your control to enter another controller's area of jurisdiction may only be approved provided procedures are established and published in a facility directive/LOA in accordance with FAAO 7210.3, para 3-7-7, Prearranged Coordination. NOTE- Under no circumstances may one controller permit an aircraft to enter another's airspace without proper coordination. Coordination can be accomplished by several means; i.e., radar handoff, automated information transfer, verbal, point-out, and by prearranged coordination procedures identified in a facility directive that clearly describe the correct application. Airspace boundaries should not be permitted to become barriers to the efficient movement of traffic. In addition, complete coordination, awareness of traffic flow, and understanding of each position's responsibility concerning penetration of another's airspace cannot be overemphasized. REFERENCE- FAAO 7110.65, Coordinate Use of Airspace, Para 2-1-14. FAAO 7110.65, Transfer of Radar Identification, Methods, Para 5-4-3. FAAO 7110.65, Automated Information Transfer (AIT), Para 5-4-8. FAAO 7210.3, Prearranged Coordination, Para 3-7-7. I'll let you do the work of interpreting the above and continuing the search for pertinent sections.... Where's Mr. McNicoll when you need him? :-) |
Are these Pilots Real? | DannyVit | Piloting | 11 | April 17th 11 06:02 PM |
The REAL Question Regarding 9/11 is.... | BDS | Piloting | 2 | February 23rd 06 05:30 PM |
A Question For Real Airline Pilots | Blue | Simulators | 34 | September 6th 04 01:55 AM |
Flight Simulator for Real Pilots | Charles Talleyrand | Piloting | 29 | November 29th 03 03:10 PM |
