On Sat, 14 Apr 2007 01:05:35 -0000, Jim Logajan
wrote in : For what it is worth, my feedback on your proposed response: Larry Dighera wrote: For pilots without instrument training, flying from visual flight rules into instrument meteorological conditions is a perilous scenario. [There are a miniscule number of airmen who hold FAA certificates, that have not received any instrument training; instrument training is not required to obtain a Glider certificate. The phrase the researchers probably meant to use was 'instrument rating' not 'instrument training.' Regardless, it is true that the average life expectancy of a pilot who is not instrument rated and qualified (recent experience) is a bit over a minute when unintentionally finding himself in a cloud that totally obscures his outside reference.] I think a more appropriate rebuttal here is that other sources, such as the annual Nall Report, find that in 2005 weather related accidents accounted for only about 11% of all fatal GA accidents. By comparison, Nall claims 27% of fatal GA accidents in 2005 are due to pilot control errors during what it calls "maneuvering flight." Therefore the emphasis on VFR into VMC and lack of mention of "maneuvering flight" by the researchers as a causal factor is an improper inversion of priorities. Thank you for your insight and the source reference. I'll add your point to my critique. What is your feeling about my disclosing the hazard statistic for VFR into IMC for un-rated/not-current pilots? In 1990, the FAA amended regulations regarding background checks on pilots for alcohol-related motor vehicle convictions, requiring pilots to provide a written report of each alcohol-related traffic offense within 60 days of the conviction. Flying privileges can be suspended or revoked if a pilot has had 2 or more convictions for driving under the influence in the past 3 years. A recent cohort study indicated that a history of driving while intoxicated is a valid risk marker for general aviation pilots. After adjusting for age, sex, and flight experience, the study showed that a history of driving while intoxicated was associated with a 43% increased risk of aviation crash involvement.12 Following intensive research and interventions, the proportion of alcohol involvement in fatal general aviation crashes has decreased progressively from more than 30% in the early 1960s to about 8% today.13 I think a rebuttal may be approprihere might be: [The 2006 Nall Report found that alcohol and drugs account for only about 1.1% of all accidents in the past few years. This is again an inversion of causal priorities and places an improper emphasis on a minor causative factor. Further efforts and analysis on reducing alcohol and drug related aviation accidents is misguided effort that is better spent elsewhere.] Another good point. Thank you. [A pilot who flies without the use of shoulder restraint belts is a fool. It is curious that the researchers failed to mention ballistic parachute recovery systems like those currently mandated for the recently FAA certified Cirrus aircraft.] I don't think you can properly claim the FAA mandated the Cirrus BRS. You may be correct. It is my understanding that Cirrus chose the BRS to comply with spin recovery certification. I suppose that was Cirrus's choice of an alternate compliance method, not an FAA mandate. I'll try to rephrase it. The general aviation crash fatality rate has remained at about 19% for the past 20 years while the overall airline crash fatality rate has declined from 16% from 1986 through 1995 to 6% from 1996 through 2005.4,24 [Due to the reduction in airline operations due to the September 11, 2001 terrorist attacks, increased airport security, and general decline in airline ticket sales, that statistic may be misleading.] Their statistics look okay to me, though I'm not sure where they get the 6%. From their two NTSB references, out of 34 accidents listed for CFR 121 carriers, 3 had fatalities (~9%) and out of 1669 GA accidents, 321 had fatalities (~19%). Averaging over the last several N years may yield ~6%. Maybe they did that. The point I was attempting to make, was that during the sample period cited airline travel was diminished by the 9/11 influence, and that as a result, it is reasonable to expect the number of airline fatalities to be less than it was during a period of higher airline travel rates. Am I mission your point? The higher fatality rate for general aviation crashes may be because such aircraft are not as able to withstand impact forces and protect occupants from death and severe injury as commercial aircraft are. [A more robust airframe requires increased weight. There is a tradeoff of safety for performance.] Another objection would be that the difference in rates may be due to the nature of the accidents the two classes of flights encounter. Having two experienced pilots on board would almost certainly skew where and when accidents take place such that the impacts on the airframes are not comparable. True. In recent decades, while major airlines have improved seat strength, revised exit row configurations, and used more fire retardant materials, few improvements have been made in general aviation aircraft, in part, because federal regulations only require safety improvements for entirely new aircraft models. A corresponding policy for automobiles would have meant that Volkswagen Beetles could have been sold without seatbelts for decades after federal regulation required them in all new cars. [The Volkswagen analogy is flawed. The ubiquitous Cessna 172 aircraft have had should restraints for decades despite their first being FAA certified in the 1950s.] Typo: "shoulder restraints" not "should restraints". Thank you. I'm sure there are others too. To improve the safety of general aviation, interventions are needed to improve fuel system integrity and restraint systems, enhance general crashworthiness of small aircraft, Those are only viable measures if their added weight and cost do not so negatively impact aircraft performance and affordability so as to render General Aviation operations impractical.] Furthermore, restraints systems in many small aircraft are already superior to those found on airlines. Ummm. I don't recall seeing any shoulder restraints on airline seating. Thank you for your input. It really helps to have other points of view. |
Recently, Larry Dighera asked:
What is your feeling about my disclosing the hazard statistic for VFR into IMC for un-rated/not-current pilots? As a response to the JAMA article, I would think it is of limited value. As mentioned in my other reply, the underlying issue is bad decision making. Truly accidental VFR into IMC should be a rarity, and there few valid excuses for continuing into IMC while under VFR (I can't think of one, but allowing for the possibility that someone else can). If one sets out in weather that is so marginal, good decision making would dictate having an "out" should the weather degenerate into IMC. The "out" that VFR pilots are taught for accidental entry into IMC is the standard 180° turn to exit the IMC. Of course, that presumes that such a turn will get you out of the IMC, which may not be the case if the IMC pops up all around you. However, such a circumstance should be extremely rare, and the conditions that could lead to that event is typically knowable prior to takeoff. I'm sure you can see my bent... most of the fatal GA accidents are the result of bad decisions, and the statistics clearly support that notion. Neil |
Jim Logajan wrote: What is your feeling about my disclosing the hazard statistic for VFR into IMC for un-rated/not-current pilots? I concur with Neil Gould's response to your question. Their statistics look okay to me, though I'm not sure where they get the 6%. From their two NTSB references, out of 34 accidents listed for CFR 121 carriers, 3 had fatalities (~9%) and out of 1669 GA accidents, 321 had fatalities (~19%). Averaging over the last several N years may yield ~6%. Maybe they did that. The point I was attempting to make, was that during the sample period cited airline travel was diminished by the 9/11 influence, and that as a result, it is reasonable to expect the number of airline fatalities to be less than it was during a period of higher airline travel rates. Am I mission your point? I think my fundamental point is that their statistics are already normalized (that is, made insensitive to the changes in amount of traffic post-9/11.). So your original statement "...that statistic may be misleading," isn't necessarily accurate. However, it occurs to me the single biggest problem with their use of the fatality rate statistic is that the normalization factor, the count of all _reported_ accidents, probably isn't comparable for GA and airlines. There may be reason to suspect that the count of non-fatal GA accidents is underreported compared to airlines. Furthermore, restraints systems in many small aircraft are already superior to those found on airlines. Ummm. I don't recall seeing any shoulder restraints on airline seating. Me neither. If the fatality rate on airlines is lower than smaller aircraft, and those smaller aircraft already have superior restraints, then agitating for improvements along these lines is pretty silly of them. |
On Tue, 17 Apr 2007 01:02:46 -0000, Jim Logajan
wrote in : Larry Dighera wrote: Jim Logajan wrote: What is your feeling about my disclosing the hazard statistic for VFR into IMC for un-rated/not-current pilots? I concur with Neil Gould's response to your question. Their statistics look okay to me, though I'm not sure where they get the 6%. From their two NTSB references, out of 34 accidents listed for CFR 121 carriers, 3 had fatalities (~9%) and out of 1669 GA accidents, 321 had fatalities (~19%). Averaging over the last several N years may yield ~6%. Maybe they did that. The point I was attempting to make, was that during the sample period cited airline travel was diminished by the 9/11 influence, and that as a result, it is reasonable to expect the number of airline fatalities to be less than it was during a period of higher airline travel rates. Am I mission your point? I think my fundamental point is that their statistics are already normalized (that is, made insensitive to the changes in amount of traffic post-9/11.). So your original statement "...that statistic may be misleading," isn't necessarily accurate. Okay. I'll take your word for it, and remove this criticism. However, it occurs to me the single biggest problem with their use of the fatality rate statistic is that the normalization factor, the count of all _reported_ accidents, probably isn't comparable for GA and airlines. There may be reason to suspect that the count of non-fatal GA accidents is underreported compared to airlines. Agreed. But implicit in pointing this out is the apparent violation of Title 49--Transportation, CHAPTER VIII--NATIONAL TRANSPORTATION SAFETY BOARD, PART 830--NOTIFICATION AND REPORTING OF AIRCRAFT ACCIDENTS OR INCIDENTS AND OVERDUE AIRCRAFT, AND PRESERVATION OF AIRCRAFT WRECKAGE, MAIL, CARGO, AND RECORDS: http://www.ntsb.gov/aviation/report.htm Furthermore, restraints systems in many small aircraft are already superior to those found on airlines. Ummm. I don't recall seeing any shoulder restraints on airline seating. Me neither. If the fatality rate on airlines is lower than smaller aircraft, and those smaller aircraft already have superior restraints, then agitating for improvements along these lines is pretty silly of them. I suspect that the cascading avalanche of occupied passenger seats torn from their mountings at impact is likely to be the most significant factor in injury and death in airline accidents, and shoulder belts would be ineffective in mitigating the crushing injuries that result. But that's a guess. |
Larry,
not exactly sure what you are trying to say here, but if you are going to rebut this article you should have some references. Your opinion is nice, but facts would be better. For example you state that the author implies that GA is more inherently dangerous than the airlines. This is actually true and the statistics bear this out. Another example is where you state that the reason for more GA crashes as opossed to the airlines is because there is more GA planes. This doesnt take into account the fact that airliners fly more. There are nearly 26000 airline flights a day (This is actually up from 9/11 by a couple grand), how many GA operations are there? Does the typical GA plane spend over 300 hours a month in the air? I dont want to beleger this and I hope you get the idea. There is no doubt that this report contains some errors, but I would sugest that you rebut the report on the basis of survivability of GA crashes and not the comparison of ailines and GA fatality rates. Good luck and let us know what you come up with. |
On 13 Apr 2007 19:38:25 -0700, "K Baum" wrote in
.com: Larry, not exactly sure what you are trying to say here, but if you are going to rebut this article you should have some references. Your opinion is nice, but facts would be better. Thank you for the suggestion. I'll see what sort of supporting citations I can find. For example you state that the author implies that GA is more inherently dangerous than the airlines. This is actually true and the statistics bear this out. I don't refute that contention. I just don't believe the comparison of fatality rates between different types of aircraft operation is useful or valid. Consider the hazards involved in crop=dusting vs airline transport operations. If you strengthen the airframe, and develop fuel bladders capable of withstanding impact into a granite mountain face until you can only fill the hopper half full and still be within the weight and balance envelope, the fatality rate will always remain higher for duster operations than for airline transport operations. Another example is where you state that the reason for more GA crashes as opossed to the airlines is because there is more GA planes. This doesnt take into account the fact that airliners fly more. Huh? More? More hours? More miles? More passenger miles? There are nearly 26000 airline flights a day (This is actually up from 9/11 by a couple grand), how many GA operations are there? Does the typical GA plane spend over 300 hours a month in the air? I dont want to beleger this and I hope you get the idea. You seem to be overlooking the fact that there are over ten times as many GA aircraft as airliners: There is no doubt that this report contains some errors, but I would sugest that you rebut the report on the basis of survivability of GA crashes and not the comparison of ailines and GA fatality rates. And I would prefer the Johns Hopkins University researchers not publicly make invalid and misleading comparisons also. Thanks for the suggestion. I'll try to incorporate more of that into my rhetoric. Good luck and let us know what you come up with. .. Thank you for your input. I know I have a narrow point of view just as the researchers do. It's good to see others reactions. |
![]() Are these aeromedical people at John Hopkins? I fail to see the connection between a medical school and aviation safety. |
Andrew Sarangan writes:
Are these aeromedical people at John Hopkins? I fail to see the connection between a medical school and aviation safety. Aviation medicine. -- Transpose mxsmanic and gmail to reach me by e-mail. |
On Apr 14, 1:16 am, Mxsmanic wrote:
Andrew Sarangan writes: Are these aeromedical people at John Hopkins? I fail to see the connection between a medical school and aviation safety. Aviation medicine. Well in that case their expertise should be in physiological aspects of aviation. How did they get into the operational aspects? |
Well in that case their expertise should be in physiological aspects of aviation. How did they get into the operational aspects? I don't know. At least one of them is a pilot (Baker, I think), but that's all I know. -- Transpose mxsmanic and gmail to reach me by e-mail. |
For those in General Aviation. | Darren | Aviation Marketplace | 0 | October 7th 05 04:42 AM |
For those in General Aviation. | Darren | Instrument Flight Rules | 0 | October 7th 05 04:42 AM |
Landing Critique | Marco Leon | Piloting | 15 | September 10th 05 05:29 PM |
Naval Aviation Museum Risk | RA-5C | Naval Aviation | 7 | September 18th 04 05:41 AM |
ENHANCED AVIATION SECURITY PACKAGE ANNOUNCED (All "General Aviation Pilots" to Pay $200.00 every two years!) | www.agacf.org | Piloting | 4 | December 21st 03 09:08 PM |
