DG-300/303 owners...
Old April 19th 07, 01:18 AM posted to rec.aviation.soaring
Default DG-300/303 owners...
On Apr 18, 4:40 am, Andreas Maurer wrote:
Hi Bob,
On 17 Apr 2007 16:58:55 -0700, wrote:
Andreas, do you own a DG-300? If not maybe you'd like to buy mine.
Thank you for your kind offer, but I (respectively my club) already
own 2 DG-300...
... and the pilots who fly them regard stories about 18.000 ft cloud
base and difficulties of staying below Vne as science fiction.
ELAN seems to be the responsible party here. Are they still the same
company? My understanding is they only split off the aviation
division to form AMS but the original ELAN company is still the same.
Please correct me if I'm wrong.
I have no idea about the situation of ELAN - but I'm pretty sure that
their product liability has expired.
Bye
Andreas
Andreas,
I was only trying to make light of a difficult situation. The DG-300
is still a nice glider. It's just not as nice as it was 10 days
ago.
The airport we fly out of here is at 6,200 feet, about 1.900 meter.
On a good summer day the cloud base can be at 20,000 feet, 6.100
meter. That is only sometimes but 16,000 isn't unusual. It's the
high desert and sometimes you can go pretty fast. The science fiction
is more down by Roswell.
Bob
Old April 19th 07, 01:30 AM posted to rec.aviation.soaring
Steve Davis
You have described a $20K repair on a product
which might not be worth $20K right after the
repair. My suggestion for the rods was to try
a $2K or less repair which would allow current
users the peace of mind to continue flying their
gliders.
My understanding of the DG 300 is that
it has a very stiff wing, presumably even with
undulations in the spar caps. Since Graphlite
ships in two and three ft. dia. spools it must be
plenty flexible and it is far stronger than the
equivalent amount of fiberglass rovings. My
suggestion would be to saw several kerfs of
varying lengths and depths through the undulation
area extending for some length on either side of
the area possibly to the end of the spar stubs.
Graphlite rods could be epoxied into the kerfs,
like rebar in concrete, and they would take the
load from the rovings they butt up against.
I suppose fiberglass cloth could be wrapped and
epoxied around the spar butt to prevent the rods
from popping out, if that could happen, but I think
you would have a much stronger than designed spar
with a very stiff wing. I have heard of someone cutting
a kerf in wooden spars and putting in the Graphlite
rods
to improve the strength.
Old April 19th 07, 01:45 AM posted to rec.aviation.soaring
Tony Verhulst
ago.
But much more affordable.
Tony V.
Old April 19th 07, 02:31 AM posted to rec.aviation.soaring
Bob Kuykendall
repair.
I assume that you're replying to my post of 1:39 today - though it
doesn't appear so in the Google view of r.a.s. Please let me know if
otherwise.
Yes, in the right hands that might be a $20K repair - I know a lot of
folks who can manage that, and I'm sure they're salivating over the
fallout of this situation. But if there's lots of them to do, a
relatively modest investment in tooling can easily cut the costs down
to around a third of that, possibly less. For example, it's virtually
a no-brainer to build a scarf-router to precisely mill out the
required chunk of wing spar. And the pre-fabbed skin repair panels are
easy, the layup is dirt simple and takes about an hour to do four;
with cure cycles you could probably yield 8 per day from a single wing
mold set.
I remember when the G103 team was here fixing spar spigots. There was
a lot of hand-wringing and gnashing of teeth around a repair that
requires hacking huge chunks out of the spar stub. But in the end,
they just lined them up and churned them out, and when they were done
they all fit fine, looked like new, and no problems since.
And, yeah, if it was some dogmeat glider only worth $20K last month,
this might all be moot. But the fact is that DG300 have typically
commanded around twice that, sometimes much more for young and well-
equipped examples.
gliders.
A for effort, but I think that the modulii mismatch between the
Graphlite and the fiberglass is probably too big to make it work
practically, even if the DG is reputed to be "stiff." The axiom of
such things is that as much as you might prefer it otherwise, stresses
are transferred not to the strongest parts but to the stiffest. If you
put any Graphlite into the spar, its stiffer modulus will make it try
to take on all of the stress, or fail its glue bond trying. So you'd
basically have to put in enough Graphlite to take all of the load, and
scarf it in shallow enough to yield enough bond area to get all the
load out of the fiberglass into it. And when you're done with that,
the surgery is likely no less traumatic than if you'd just done a
repair-manual scarf.
Another thing to consider is that if you execute an innovative repair,
you are probably on the hook to validate it with test it to
destruction, or at least to the somewhat-draconian EASA standard of
6.3*1.725. Whereas with a textbook repair, you may be justified in
only testing to design load or not testing at all.
Since Graphlite
Yes, that's the way we've been buying Graphlite ribbon (not rod) for
the HP-24 and Glidair projects. Its flexibility is relative, though;
with a Young's Modulus of about 23 million it is much stiffer than the
equivalent profiles of pultruded fiberglass and is in fact 15% to 20%
stiffer than the equivalent hand-laid carbon tape or roving. For new
glider wing spar designs I think it is certainly the greatest thing
since sliced cheese, but it doesn't always play nice with others.
My
As I wrote, that might work, but it inflicts trauma on the same order
as the textbook repair, involves a pretty big modulus mismatch, and
has no track record. I'd like to see it tried, though, it'd be an
interesting experiment.
rods
Yes, I've heard of that too - I think it was on a Bowlus Baby
Albatross.
Thanks, and best regards to all
Bob K.
Old April 19th 07, 03:30 AM posted to rec.aviation.soaring
Steve Davis
Yes Bob, I was responding to your earlier post.
Thanks for your reply; there seems to be a lot
more going on in the spar than I had realized.
I was just guesstimating at the value of a DG 300
now vs. after a repair. With the current 'fix'
from DG I suspect a lot of them will just sit in
trailers not getting flown, or bought.
Also, is this a problem with both the top and
bottom spar caps of the wings or just one cap?
Thanks for your information.
Steve
repair.
- though it
let me know if
otherwise.
- I know a lot of
over the
to do, a
cut the costs down
it's virtually
out the
repair panels are
to do four;
from a single wing
mold set.
Steve Davis
Steve
repair.
- though it
let me know if
otherwise.
- I know a lot of
over the
to do, a
cut the costs down
it's virtually
out the
repair panels are
to do four;
from a single wing
mold set.
Old April 19th 07, 04:51 AM posted to rec.aviation.soaring
brianDG303
On Apr 18, 6:30 pm, Steve Davis
.. With the current 'fix'
Steve, this all came out about ten days ago. Last weekend at the field
there was quite a bit of chatter about it, and I had to answer a lot
of questions about how I was planning on dealing with my 303. And the
answer is, I'm so happy with the glider I just don't really care.
Andreas is correct, this will not affect me until I decide to sell it,
and that is some years down the line. The focus in this thread is on
how to fix the problem; my interest is on how to test at the lowest
cost. Let's say 50% of the gliders are affected, that means that the
cost to fix half the gliders is exactly nothing. While the testing
process is being worked out I'll be flying, and having fun.
As it happens, I have the last plane (DG303 # 486) ever made by ELAN,
and the 27th ACRO. It will be interesting to look back on this in a
year or two.
Old April 19th 07, 05:57 AM posted to rec.aviation.soaring
Jack
year or two.
Who made the final 25 units, and what is the source of this information?
Jack
  #29
Old April 19th 07, 06:12 AM posted to rec.aviation.soaring
Marc Ramsey
year or two.
AMS Flight made the last 25, after they bought out ELAN's aircraft
business and bought the production rights from DG Flugzeugbau...
Marc
  #30
Old April 19th 07, 07:17 AM posted to rec.aviation.soaring
Jack
And they continued the defective construction techniques,
in the same facility, probably using the same personnel?
No wonder they are staying silent.
Jack
Beech Duke Owners/ex-Owners ple help... Stanley Owning 12 June 10th 16 12:36 AM
DG-300/303 owners... Marc Ramsey Soaring 34 April 22nd 07 05:07 AM
SHK Owners [email protected] Soaring 1 February 7th 06 06:37 PM
R22 owners please help with AD 2004-06-52 rotortrash Rotorcraft 20 April 28th 04 04:33 PM
Any UH-1 owners in here? Jim Rotorcraft 7 October 6th 03 02:33 AM
